FX7, how do I get a good DVD file from the footage?
I just videotaped a dance concert and when I transferred the video to my computer and output it to a DL DVD, the quality is nowhere near as good as a straight HDMI connection to a TV. It doesn't even look that good on the computer in Premiere elements before I output to DVD. I'm using Adobe Premiere Elements 7. I don't know if it's the project settings for the transfer, I chose HDV 1080i 30. Is Premiere Elements maybe not going to give me what I want?
thanks, Eric |
When you download your footage from your FX7 to your computer, make sure your "i.link conv" is OFF. Otherwise your footage is being downconverted to a lower resolution. See Page 70 of your operating guide.
Mike |
Thanks for that, I checked and it already was off, that must be the default setting. I'm really mystified by this. I'm not sure if I'm supposed to be using some other settings when I bring the footage into my computer. Wouldn't HDV 1080i 30 be the setting I should use for "project setting"? Or should I use the 720p 30 setting? I noticed that Premiere Elements makes mpeg2 files rather than AVI's like my regular DV camera came in as. I thought AVI's were less compressed than mpeg2 files so I'm wondering if I'm bringing the files into my computer wrong.
wow! i think eric you should take a deep breath, calm down, and RTFM.
that said, you simply connect camera to pc with firewire, use hd capture utility in prem. put video on t/l, make sure your project properties match what you've shot, then edit. what you now have on your t/l is hdv ready to be rendered out as: m2t - hdv mpeg - optimum bit rate for project (eg. 8,000,000 max) to go to dvd mp4 - for web i use vegas so i can't hold you hand through the exact steps required in elements, though i'm sure someone here will (?) but i repeat, rtfm of both the camera and elements.... leslie |
How are you expecting a dvd to be any where near as good quality as the hdv footage, sorry if i am misunderstanding something.
to this end i now make sure the roughs, tc dvd dubs, etc., that i send out or upload are encoded at a lesser rate than the final release dvd will be. that way they're always so much happier that the finished product looks so much better than the 'rushes'. leslie |
Thank you for responding. I have read the manual for the camera and elements, trying to figure this out but as is always the case for me, my question is never addressed.
I noticed that my DV DVD from my VX2100 looks much better than the FX7 DVD when played on a regular 4:3 TV. I'm probably an idiot and don't know that that's what happens when trying to play back HDV on a tube TV. But I don't know! When I play the FX7 DVD on a 1080i LCD it looks a little better, but the sharpness that I saw when the camera itself was connected via the HDMI cable was completely absent. I'm sorry for being such a newb, but can you explain what this sentence means? "use hd capture utility in prem. put video on t/l" I don't know what t/l is and I'm figuring you mean use the right project settings in Premiere Elements i.e. HDV 1080i 30 as the project setting? If so, that's what I did. Maybe I'm getting the quality I'm going to get, I just wanted to be sure I wasn't doing it wrong. If anyone here uses Premiere Elements and the FX7 I would be so grateful for some direction. Thanks, Eric |
I'm sorry, I feel like a pain. I keep thinking of new questions.
Would it be better to choose 720p 30 as my project setting for viewing a DVD on a 720p/1080i TV? Should I also be using the DV Wide project setting for DVD's that will be played on regular TV's? |
Something's up and I'm pretty sure it's in the Elements settings. If you downconvert the HDV footage out of the FX7, then that resulting DVD should look as good as the VX's. Yes, I'm suspicious of Elements and its ultimate downconversion to MPEG2. tom. |
Eric,
You might want to double check your settings. The FX-7 shoots in 1080i meaning that it's interlaced, 60 fields or will sometimes be listed as 1080 60i. 30 may be suggesting progressive scan, which may soften the video when trying to either capture or encode the interlaced to progressive. I just received my FX-7 and I'm in the process of making a DVD right now from Vegas 6. So far it looks good. So I really think it's either your input settings or output, or possibly a little of both. By the way t/l looks like it refers to timeline. I have Premiere Pro CS3 at work. I'll look at the capture settings and see what it has. |
I really should get a copy of Elements so I can check this, but in Pro you must make sure you are using a 60i preset, or else Premiere will do a horrible job of deinterlacing to 30p -- it simply throws away one field and kills your resolution, as David implied.
When I go straight from the Premiere timeline into Encore (using the Export to Encore function) and just slightly tweak the settings for higher quality, I get SD DVDs that are almost indistinguishable from Blu-Rays. Okay, you can see the difference, but even on a 65" HDTV screen it isn't dramatic. Maybe I'm just lucky in this regard. I have a variety of Sony HDV cams, and I must say that my FX7s are without a doubt the sharpest and punchiest of the bunch. Note that interlaced footage will always look bad on a PC screen, as your monitor was not designed to display interlaced material. You must view on a proper HDTV. |
Thanks, Eric |
When I select New Project in CS3, I go under the Load Preset tab, expand "HDV" and select "HDV 1080i30 (60i)." There is also an "HDV 1080p30" preset and a bunch of 720s -- don't use them.
I actually use Cineform, so there is a whole other set of presets available to me, but it's expensive and may be more than you need. There's a huge and very active Cineform forum here in the Post Production area -- you might want to check it out for some ideas. |
So Eric now you want to check your output settings. Make sure that you are not outputting progressive mpeg2, stick with interlaced mpeg2. Also check your bitrate for quality vs. size. A good rule of thumb that I have come across over the years is anything under 30 minutes go with CBR constant bitrate. Over 30 min VBR variable bitrate. Go ahead and set to multi-pass. It takes longer to encode but should yield a better video. Also I never set my max bitrate above 8.5mbs. Although you can go higher, I have read that some DVD players tend to choke on higher bitrates from burned DVDs.
Yes, I use a PS3 as my player, which lets me switch back and forth between standard DVD and an HD m2t file directly on the HDD for comparison. But even so, using my prior regular DVD player, I got really good results using PPro to edit and Nero to transcode/burn.
I got Vegas Movie Studio Platinum 9.0 and I'm in the process of trying it out. When I first started it it asked me what my content was (HDV) and what my output was eventually going to be and I chose Widescreen DVD. I'm looking at the Project Properties right now and I see that Video is set for NTSC DV Widescreen (720x480, 29.970 fps). Is this what I should have picked? I didn't see options like this in Premier Elements, or at least I didn't realize it was asking me what my final product was going to be.
I am confused. is it bringing the footage in as 1080i60 for editing and then already set to output a DVD? Thanks, Eric |
I'm not familiar with that software, but it sounds about right. I think it's just trying to simplify the steps for you. The 720-480 widescreen is correct but DVDs are mpeg2 not DV, unless it's talking about realtime output to a monitor.
DVD quality
I have not been happy with the DVD quality I have gotten from Vegas Studio Platinum 9, so I ran the same project thru Pinnacle Studio 12 and It was better. I need to check my settings, but I thought that progressive scan was better for picture quality? Maybe that is not the case....
I use upper field first and NEVER check "de-interlace."
Thanks.
I will have to stop checking de-interlace. De-interlace is required for outputting for web though, right? Will get back to you if results are better or not. |
| All times are GMT -6. The time now is 02:58 AM. |
