ok so to get the true 1080p you have to ?
so the camera is possible of 1080p. how do you get that? do you have to capture via the HDMI?
Here's what the Sony website has to say about progressive:
"Thanks to the 3 ClearVid CMOS Sensor and Enhanced Imaging Processor, the HVR-V1U supports 24p (progressive) scan, the frame rate of film and 30p (progressive) scan modes, in addition to typical 60i. The signals generated by the 3 ClearVid CMOS Sensor are processed in the progressive domain as 1920 x 1080p signals, allowing high-resolution progressive footage to be captured. "The 24p scan signals are recorded on tape as 60i signals through means of 2:3 pull-down. Similarly, a 30p scan signal is recorded as a 60i signal by dividing each frame into two fields. This allows your 24p and 30p scan footage to be played back or fed to an editing suite using the thousands of Sony HDV equipment already in use throughout the world. "Two recordings modes can be selected depending on your editing requirements for the 24p scan. "The "24" mode should be selected when a 24p (motion) look is desired on 60i material, such as for TV program content. Recordings made in this mode can be edited as typical 60i material. "The "24A" mode should be selected when the material is intended for 24p progressive editing - such as for film productions - using a nonlinear editor compatible with this mode. Recordings made in this mode can also be edited as typical 60i material." Look for PROG. SCAN in the menus. It's on page 63 of the US manual. |
You can't "get" 1080p60 "out" of the camera. The 1080p60 is only in the EIP before being turned into 1080i60 or 1080p24 or 1080p30. |
sony says the camera can do true 1080p . 1080p is 1920 × 1080
however HDV is limited to 1440 x 1080. so how do you get the 1080p when you edit. |
It's true 1080p, but the 24p settings are packaged in a 60i stream, like most other progressive-scan cameras doing 24p (JVC, Panasonic, etc.). What are you wanting to do?
Also, I don't believe 30p is in a 60i stream--it's straight 30p. heath |
The 1080 part is vertical resolution -- how many lines. They can be i or p, which is what I thought you were asking about. 1080p60 is the holy grail we're looking for, but I don't think it's actually part of the HDV spec, only 1080p24, 1080p30 and 1080i60, as Steve said. I read in two different posts by real pros -- not guys like me -- that even the highest end CineAlta cams record HD as 1440 x 1080, because the pixels aren't square. That has nothing to do with p vs. i. When you edit the 1440 is converted to 1920. Unless I'm totally wrong -- which has happened more than once. And Heath, you're probably right about 30p, but that quote ("a 30p scan signal is recorded as a 60i signal by dividing each frame into two fields") was straight from Sony, which says they just duplicate the frame into two identical fields, so I guess they're not, strictly speaking, interlaced. |
Note that you will have to carry around a PC and or MAC to capture the uncompressed stream. Another option is the AJA ioHD and a MAC Pro Laptop. It will take the HDMI and convert it into PRORES 422 and from what I have read will allow you to edit in 4:2:2 colorspace. I plan on capturing with my v1 via HDMI http://www.cineform.com/products/default.htm convert it to the Cineform NEO HD http://www.cineform.com/products/default.htm and edit in Vegas. Note: The intensity card will only do 1080i. 1920X1080 Jon Somebody correct me if I am incorrect. I haven't tested this yet, my intensity card is on the way. |
Depending on which one of the 3 shooting modes was chosen in-camera, V1 introduces a pulldown to embed 24p into 60i output; or repeats the field to embed 30p into 60i; or simply records and outputs in 60i. Note that the output is always 60i. This is for the universal compatibility with hardware/software NLEs that ARE traditionally 60i-oriented. Intensity card DOES allow you to remove 24p pulldown in real time on HDMI capture when used with Cineform Aspect HD (supposedly NEO HD too?). |
I never said it would be run and gun. It's not possible. I have 50ft HDMI cable that I will connect to my V1.
I am using a dell precision 490 with 2 xeon quad cores, 4gb of RAM, 2 SAS 15,000 drives in RAID-0 for my OS, WINDOWS XP PRO, 2 SAS 15,000 drives in RAID-0, as my edit drive and another 2 SAS 15,000 RAID-0 as my other edit drive. My favorite part of the system is the Dell 30" display. I am also looking into Convergent-Designs Nano-Connect http://www.convergent-design.com/CD_...anoConnect.htm for longer runs via HD-SDI with http://www.blackmagic-design.com/products/hd/ We shoot college and highschool football. I would like to test the Intensity card prior to the nano connect to see if the output looks good enough before investing large amounts of $$$ in nano/hd-sdi. |
I capture live HDMI from V1 via the 12ft HDMI cable.
I highly doubt that the cam's digital output is capable of pumping it through the longer cables reliably. Looks to me that 50ft won't work. But I did *not* test it myself, and I'll be happy to be proven wrong :) |
I will test it and let you know. There are plenty of hdmi extenders on the market, gefen makes a few that will give you long runs if needed. Either way, its very expensive to work in an uncompressed format. It will be nice once technology catches up. :)
When directly to HDMI or HD-SDI, isn't it will capture what the progressive chip recorded? So, through HDMI live capture of V1, it will be 1920x1980p whether 25p(in PAL) or 30p(in NTSC) I just want to know if my understanding is the correct ones... |
I never capture live with cable before, I just want to make sure I'm able to do it, since I have an understanding that GOP will suffer badly when doing a lot of camera movement. |
| All times are GMT -6. The time now is 11:30 AM. |
