Back Focus Problem
Beware. I had to send my V1U back to Sony today for warranty repair because of a back focus problem. I'm surprised because I haven't put that many hours on it since I got it in late December 06. I was surprised when an interview I shot today was soft. I was rolling as I zoomed in to get focus and it was absolutely sharp, but soft when I pulled out to frame the shot. Tests back at the office confirmed the problem. Shooting in DVCam mode.
Lee, I'm wondering whether back-focus also prevents auto-focus from working properly? Or is it only manifesting in scenarios like you described (ie zoomin-in - focusing - zoomin-out)?
Piotr
It's the same issue. Zooming in, letting AF catch the focus, switching to manual, and then zooming out to frame the shot results in soft focus. Setting the shot and invoking AF results in sharp focus. Lee |
To check backfocus switch to manual focus, zoom in on a res chart or something that will easily tell you if you're in focus or not. Focus the lens and then zoom back. The focus should remain the same. The problem comes about much more so on these cheaper lenses as they're retrofocus zooms. This means the focus has to adjusted as the focal length changes and this is done via a servo system. It might also explain why these lenses are so noisy. As you zoom in and out there's one motor driving the zoom, another one driving focus trying to compensate and even the iris is having to be moved to compensate for the changing loss of light through the lens. Probably also explains why zooming in and out a lot drains the battery a bit faster than normal. That's about the limit of my knowledge of lens design but I can see why it's so difficult to get it right. The focus servo has no feedback to tell it where focus really is, so I guess all it can do it use a look up table. That might be OK except changes in temperature affect the back focus distance as metals expand and contract. |
I find this very disturbing - I thought that one of the only ways to get an accurate focus with an HD camera like the V1 without the aid of an external monitor is to zoom in, check focus, and then zoom out again.
When working without an external monitor I find the peaking and expanded focus to be good aids in verifying focus after the shot is set. |
Don't get too excited about this. Lets wait and see what the repair center says when Lee's camera comes back. I've checked my camera and its fine. Mine was one of the first shipped back in December.
Lee, I hope it comes back ready to go to work. Chris |
I think nobody's getting excited, Chris - I checked my camera and it's also OK. My question was out of curiousity about the general nature of the phenomenon: can it develop in time during normal use in a unit that had perfect focus when leaving the factory?
It was suggested (indirectly) in Lee's original post. |
Since the VX1/VX3 -- I think -- the lens SYSTEMs are retro-focus. The focus and zoom controls send info to a computer that also inputs contrast infomation. The computer sends info to the zoom and focus servos. (Maybe also the iris.) You tell it what you want -- and the computer meets your goals. You have two choices to focus. 1) zoom in and focus. This is what you should do if you plan to at some point to zoom in. 2) if you don't plan to zoom in, or plan to zoom out, you can establish focus without zooming in. Simply focus after you have framed the scene. --------- But the neat thing is that once the computer has got AF on something -- it will track this object. (The first generation Sony's froze focus when you zoomed. Now, as Bob said, when you zoom, the computer automatically will try to keep focus.) If the object moves out of the frame, the AF will not quickly change AF until something else moves into the frame. This means you can pan from one subject to another in AF. The AF will NOT try to focus on the background between objects. Likewise, the AF ignores anything that moves in front of the lens once it has locked focus on something. I spent 4 months testing the AF -- and even at scenes that needed +9dB gain, it was very hard to fake it out. PS 1: there is actually a problem with zooming in to get focus. When you zoom in really tight on a face -- there are no hard edges to focus on. The AF and Focus Assist fail. (I think this may be way some feel they need a field monitor.) It's better to zoom in on the upper torso so arms and belt are in the frame. Remember, if you don't plan to zoom in further, the focus is fine. PS2: Up to about Z60 -- the DOF is so great you almost don't need to worry about focus. That's why AF works so well. It doesn't have very much to do. :) |
I'm no expert on lens systems, but I think that a backfocus problem could manifest as a lack of ability to infinity focus. That could be a problem whether you use manual or auto focus. Correct me if I am wrong.
Steve, since you seem to be the resident expert on V1 autofocus, how do you feel about the "focus assist" function? Am I being unfair to my camera by leaving it on manual and only pushing the momentary AF when the distance to the subject changes? Are there secrets to utilizing focus assist? |
Markus, I don't know about "focus assist", but if you really mean "AF Assist", then it works the other way around (and works perfectly well): when in AF, and you need to change the object/distance it fixed at - just turn the ring slightly and the AF will change its distance accordingly.
What yu're describing sounds more like using Push AF when in manual focus. |
One of my clients had to reshoot the first 4 hours of their shoot due to a makeup malfunction, if they'd had proper monitoring they'd probably have avoided this time loss. |
Piotr, I should have said "AF assist". I think I need to go out and practice with the AF assist before I am comfortable changing my methods. I don't want to be one of those curmudgeons that is inflexible in the way things are done, but I am also nervous about trusting the camera with focus unless I don't have any choice in the matter.
Markus, I myself only recently discovered that the AF assist function works so well. I didn't trust it before, but must admit the more I use the V1, the more capable and forgiving I find it. In fact, the auto functions work so well, that - after the initial fascination with full manual mode - I find myself more and more tending towards using them, and only revert to manual when really needed.
So my usual method of shooting with the V1 would be to set the shutter speed manually, switch to auto exposure as it can prompt me to engage ND1 or ND2 if needed with the current lighting conditions and the iris limit set to 5.6 in the menu, and only return to manual exposure if some special circumstancies (like backlit object for instance) require it. Similarly, I always start with AF on; if there is no risk of AF hunting (usually low light can cause it), I keep it that way, and use the ring to freely change the distance/object I want the AF to set to (using LOW peaking intensity, see below). Only when the object I need to stay in perfect focus does not have features that AF relies on, or it's not bright enough - I switch to manual focus (and crank up the peaking intensity - see below). I have developed my own way to ensure that a subject's features are good enough to trust the AF will find it and stick to it, while I'm still at control of where the object actually is: always use the lowest possible peaking intensity. With normal outdoors lighting conditions, I always set the peaking intensity to LOW. This way, only "true" sharp edges do peak. Of course, the lower lighting, the higher peaking intensity is appropriate. |
I appreciate everyone's response into my post. I didn't mean to cause any alarm or insinuate that this is a widespread issue with the V1. That fact that no one else on this forum has reported this issue is a good sign.
My camera arrived at Sony's repair center in New Jersey yesterday and I'll be sure to post the details when I get it back (including how quickly Sony turns it around). Also I totally agree with the idea that once framing is set you can always tweak the focus either manually or via the auto focus. A problematic back focus is not a show stopper if you're aware of it. Most of all I wanted the issue taken care of while still under warranty. Cheers, Lee |
With our little 7" Marshall or the 8" SWIT, these shots are no-brainers, but using the V-1's LCD, we almost always use the focus assist and have few probs. The eyes have it. |
Back Focus Issue Resolved
A technician from Sony called today and informed me that there was nothing wrong with the BF. He explained that the problem occurred because the Macro setting was ON. For a moment I felt stupid and then I remembered that I suspected Macro and checked the manual. On pg. 64 it says:
"Since the default setting is [ON] you can focus a subject within 80cm...." "If the default setting is Macro ON then it has to be a back focus issue," I reasoned at the time. There was nothing about Back Focus. If Macro adversely affects back focus then the default should be Macro OFF. Or at least there should be something about it in the manual. I was fooled in part because I'm used to cameras with interchangeable lenses where it's obvious when Macro in ON. Of course I still feel kind of dumb in that I should have double checked with the Macro set to OFF before I sent it back to Sony. Live and learn. By the way, they got to it quickly as it was received on Wednesday and off the bench by Saturday. |
Lee, sorry for your pain on this. I really appreciate your posting the solution. In fact, I have an interview that is soft - I usually leave Macro "off" on general principles, I wonder if I left it on for that interview.
VERY interesting info that the Macro setting invalidates some usual applications of manual focus (zoom in, focus, zoom out to your shot). |
| All times are GMT -6. The time now is 01:47 AM. |
