-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Z1 low light condition (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/114013-z1-low-light-condition.html)
Marcelo Costa February 5th, 2008 08:45 AM
Friends
I'm a wedding videographer and recently I purchased a Z1 and FX1... In a good light condition the image is great, but in low light condition... It is terrible...
Eg. when I shoot the guests dancing, using no light on the cam, and working only with DJ's lights (it changes very fast from dark to bright, one color to another...), I got a lot of squares on my video... I know that HDV, in this case Z1, works with mpeg compression, so, I believe that squares are a compression fail... So my question is, Is there any thing that I can do to solve this problem in very low light condition, specially in dance floor (fast light changes) ? Some setup on the cam or anything in the editor program (I worj Final Cut Pro 5) to minimize this fail?
Also, I can not use external light on the dance floor to fix it, I always say (or used to say) to my customers: "I do not bother the guests using external light in the dancing floor, I always try to use the environmental light, this way they do not see me when I'm shooting them, they will be more confortable"... When I worked with PD170 I did not have this problem... And I would not like to shoot my weddings using DV mode in a HDV cam... I payed more to get HDV and it is frustrating if I have to use it in DV mode to fix this problem...
In the worse situation, is that any price affordable HDV cam (like Z7 or Canon's cams) that does not have this problem ?
Thanks a lot for your attention and help.
Marcelo
Philippe Messier February 5th, 2008 08:58 AM
Hi there,
Just to clarify,...it won t change anything if you switch to DV mode on a FX1/Z1. You wont be getting a better low light performance at all. Simply, because there will be still a tons of pixel cram onto the 3 1/3 ccd... In DV mode, the camera still use those tiny pixel.
The only real option is to get a Z7 (supposedly better) or the EX1 (officially better).
Good luck
Phil
John M. McCloskey February 5th, 2008 09:13 AM
If you like having quick archiving capabilities where you can shoot and ingest and not have to dump to tape for archiving look at XDHD Cam. The time you will save is unbelievable. Just a suggestion
Tom Hardwick February 5th, 2008 10:27 AM
To say the Z1 is 'terrible' in low light is a bit much when it's just 1.5 stops behind your PD170. And you can use +18dB of gain up in the Z1 the amplifiers are so quiet - don't try doing that with a PD.
I use the little Sony 20-DW2 video light on top of my Z1 for the wedding dance. I diffuse it with a Lumiquest Mini Softbox and set the gain at something like +9dB, and the results are excellent. This is a lot cheaper than dumping the Z1 for an EX1.
Of course you have to lock the exposure (shutter, gain and iris) when shooting under disco lighting. But the 'squares' on your video? Never seen that either in HDV or DVCAM. Can you explain further?
tom.
Marcelo Costa February 5th, 2008 11:01 AM
Originally Posted by Philippe Messier (Post 820598)
Hi there,
Good luck
Phil
Ok, thanks for your help... I thought in DV mode the image should be better in dark environment, because it does not use mpeg compression, this way avoiding the squares... Thanks again.
Marcelo Costa February 5th, 2008 11:06 AM
thanks a lot, but XDHD is far way from Brazil's reality... :)
Marcelo Costa February 5th, 2008 11:56 AM
tom.
Tom, thanks a lot for your help and tips...
I have some doubts, I would be glad if you could help me...
1-) The Lumiquest Mini Softbox that you mean, is this product at BH ?
http://www.bhphotovideo.com/c/produc...i_Softbox.html
2-) Does it really fit in the 20-DW2 ? I mean if it does not drop...
3-) I already have two 20-DW2 but I think it is too spot... Using the Lumiquest, the light will be more flood ?
4-) Under disco lighting I set up my Z1 as: Iris = Open; Gain = 9db or 12db and sometimes 15db, but never 18db; Shutter = 60. Is that Ok? What do you recommend?
5-) My english is not so good, so I uploaded 2 frames that were shot on a Sweet 15 (in Brazil we have Sweet 15, not 16). The first one is ok, no squares, the second one (it is just the next frame) has the squares that I said, it appears when I have a fast change of light, and in dance floor it happens a lot (light canons, strobes...), to me looks like a HDV MPEG Compression Problem... You can donwload both frames from my site:
Frame Ok:
http://www.mnproducoes.com/square/1st_frame_ok.jpg
Frame with a lot of squares:
http://www.mnproducoes.com/square/ne..._toosquare.jpg
Thanks a lot for your help.
Marcelo
Matt Davis February 5th, 2008 12:23 PM
Disco lighting - drive in manual for everything, yes to open iris and gain (+9 dB tops). The square blocking is an HDV 'thing'.
The main cause of square blocking (very fine blocking, looking fuzzy) in Disco light is very strong colour - try desaturating the image slightly. But your images also show larger squares - 'macroblocks'. This is when too much is changing from one frame to another, and parts of the image are 'downrezzed' to make things work.
I shoot HDV, edit (in AIC, ProRez, whatever) at HD, then shrink the HD down to SD or web, so the blocks get very small and, for the most part, unnoticable.
You may want to look into holding off high gain, then using a colour correction filter (I use Colorista) to lift the brightness of the middle range of tone. I strongly recommend shooting with Black Stretch turned on (Z1 only, not FX-1).
So:
- Manual everthing
- Black stretch ON
- Shoot and edit HD, deliver SD
- De-saturate shots under strong coloured lighting
- Lift mids in post rather than pump more gain
PS: Something else you may wish to try (though I speak as a PAL user): instead of shooting 50th, I can shoot 25th and get an extra stop - the resolution is halved, but at HD downconverted, you're not going to miss much. If you must shoot by candle-light, it's a handy trick.
Robert M Wright February 5th, 2008 12:52 PM
You might try using the MSU Deblocking Filter:
http://compression.ru/video/deblocking/index_en.html
Tom Hardwick February 5th, 2008 01:35 PM
Now I see what you mean. This is a disco - a very unnatural happening in very unnatural light - they'll think you added those blocks as special effects.
Yes, that's the softbox I use. It comes with self-adhesive velcro and after a time the heat tends to make the velcro 'creep'. Not a problem in the slightest, and the diffuser remains in place and unmelted. It fits the lamp perfectly. With both filaments lit and the diffuser in place harsh shadows melt away.
It does rob you of some light, but the extra diffusion right in front of both lamps means it covers a much wider angle - useful as I use a super-wide to float with the b & g on their first dance. Best is that guests can look right into the light with no squinting - invaluable.
Follow Matt's advice re black stretch and manual everything, including the white balance. Don't worry about over or under exposure - this is an unnatural occurrence, and practically anything goes.
I don't advocate the 1/25th sec shutter speed though. You claw back a stop ok, but the stuttery look to the footage is not worth it in my view. Give it a go and decide for yourself.
For exteriors at night I often use 1/3rd sec so as to dial out the gain completely, but of course movement (camera and subject) can look odd.
tom.
Asaf Benatia February 5th, 2008 01:52 PM
and if you use Sony HVL-LBP
i know you said you can't use it, but can you test and see if you start using Sony HVL-LBP will you get a better pic on the dance floor?
Simon Denny February 5th, 2008 02:03 PM
I did a gig last night with the Z1 filming a couple of bands in a night club in Sydney, the only light was the stage lighting. The camera wanted about 12 - 18db of extra light but i only gave it 9db with the iris set to about 2.4.
When i got home and set this up through my widescreen the results looked great for the conditions.
I also use the Sony PD170 on this shoot and i gave this 3db of extra light and this also looked good.
The Z1 can handle low lighting but with all cameras grain will creep in. Get yourself a light and stick it on the camera for your wedding shoots but make sure it's a widescreen light, you will be very suprised at how good the results are from the Z1.
Regards
Simon
John M. McCloskey February 5th, 2008 02:14 PM
"- Shoot and edit HD, deliver SD"(Quote) Matt Daviss
I totally agree with Matt on this also, it is amazing the difference when edited in SD compaired to edited in HD. From what I have heard editing HDV in at DV25 you loose 60% of your raw HDV signal. Which is another question all in itself,"Why would anyone edit HDV in at DV25 for a finished project?" I have seen it and dont understand why someone would do that.
Marcelo Costa February 5th, 2008 02:28 PM
Matt, thanks a lot for your help, I really appreciate.
I'm new with HDV format and Final Cut (before I worked with PD and Premiere), so I have some doubts if you do not mind...
1-) What is AIC, ProRez ? Are these editor programs or codecs to use with Final Cut ?
Editing in Final Cut first I access Easy Setup... (under Final Cut Pro menu) and select HDV-1080i60 FireWire Basic, then I capture and edit... All my sequences has the compressor HDV 1080i60, Quality 100% and Field Dominance Upper (Odd), also Video Processing as Render in 8 bit YUV, process maximum white as white and motion filtering quality as normal.
Then to export it to SD, I export my sequence as a not self contained Quicktime movie and setting as Current Settings (it will use the settings of my sequence, as I described before), and in Compressor I use:
Video Format
File Format = MPEG-2
Video Format = NTSC
Aspect Ratio = 16:9
Field Dominance = Top First
Quality
Mode= Two pass VBR Best
Average Bit Rate= 5.5 MBPs
Maximum Bit Rate= 7.2 MBPs
Motion Estimation= Best
GOP
Gop Structure= IBBP
Closed
Gop Size = 15
Are my steps ok?
2-) Holding off High Gain, what do you mean? Work with gain as 0 or to use gain at 9db (tops) ?
Also, could you please send me the link of the plugin Colorista ? Actually to correct color and gain I use the filter Color Corrector 3 Ways (FCP default filter).
Thanks a lot for your attention, I really appreciate it.
Marcelo Costa February 5th, 2008 02:33 PM
Thanks for your tip... Should I use this program with my edited movie after compressed it to MPEG-2 (m2v) ?
Thanks again.
Marcelo Costa February 5th, 2008 02:42 PM
tom.
Thanks again Tom, you are great.
Simon Ash recommended to use a widescreen light, so, using 20-DW2 with the softbox will I get a wide light ?
Thanks again.
Marcelo Costa February 5th, 2008 02:45 PM
Regards
Simon
Thanks Simon.
As recommend, I will try to use the Sony Light 20-DW2 with Lumiquest Mini Softbox, with the softbox my light will become wide.
Regards.
Marcelo Costa February 5th, 2008 02:48 PM
Asaf, thanks a lot
Regards
Tom Hardwick February 5th, 2008 03:00 PM
There's no such thing as a 'widescreen light'. There's light, and that's it. The diffuser will spread it wider and more evenly, but with a big hit in lost light. What's good though is that you can rip off the diffuser in one second if you suddenly need more light.
Always have both filaments lit to reduce harsh shadows, as an NP-F960 runs well over an hour like this. I mount mine horizontally sometimes because it looks more 16:9, but in reality the effect is no different from vertical mounting.
I leave mine on for lots of the time at weddings - that way the guests get used to you and your light, and you're not suddenly blowing away the darkness by turning it on.
I bought an LED light last week but oh dear - far more localised lighting (like a torch) and the light is horribly green in comparison to the over-run tungsten. Of course you can white balance the green to look good, but then the people in the background are shades of purple. It's going back.
tom.
Matt Davis February 5th, 2008 03:31 PM
Lots of steps...
Originally Posted by Marcelo Costa (Post 820800)
What is AIC, ProRez ? Are these editor programs or codecs to use with Final Cut?
These are codecs that you can use when setting up your project in Final Cut Pro. You'll be shooting in HDV whatever you do, but you can choose to use one of three codecs for your edit in HD: HDV, AIC or ProRez. I find HDV fine for quick editing, but bogs down with multilayer effects, which is why I quickly switched to AIC which is great but there's a barely noticable quality loss (nobody saw it). I am now moving to ProRez now that I have the horsepower to deal with it. I can't really do Multicam in ProRez HQ, so I'm finding standard ProRez is great - but it's not as fast as AIC. If nobody was watching, and my output was SD, I might still use AIC if working against the clock (Apple Intermediate Codec - as used in iMovie HD and Final Cut Express HD).
Having shot with 60i on a Z1, select either the AIC HDV 60i Easy Setup, or the ProRez 60i Easy Setup. Now... when you come to capture, you'll need to check that the capture settings are also set to these Settings. Unless the process is done right (it's a bit like a scene from Harry Potter), the Capture settings don't seem to be kicked over to your new settings, so just check it manually. AIC 60i or ProRez from HDV 60i.
The capture will happen in a sort of Zen 'it's not really happening' way, but it's fairly robust so long as you don't try symultaneously burn a DVD, surf DVinfo.net, download software upgrades and check for email every 30 seconds.
Are my steps ok?
Do your edit in whatever, export using current settings and MAKE MOVIE SELF CONTAINED, then offer this movie to Compressor on a bed of reeds using your favourite settings (DVD 120 minutes High Quality seems to do the job for everyone), then incorporate using DVD Studio Pro. Don't let DVDSP do the compression management.
There are things to do, tweaks to make, but quite frankly, it's gilding lillies.
Holding off High Gain, what do you mean? Work with gain as 0 or to use gain at 9db (tops)?
Use up to 12 dB of gain, but remember that your Edit system is better at pulling levels around than your camera as the camera must do it real time, whilst the edit system has all the time it needs.
could you please send me the link of the plugin Colorista?
With absolute pleasure - Colorista blows the doors off all the tools in FCP, and makes Color seem like a 'Pimp My Software' ride to upgrade hell:
Here's the official home of Colorista:
http://redgiantsoftware.com/magicbulletcolorista.html
Here's the basic tutorial:
http://redgiantsoftware2.com/Downloa..._Intro_web.mov (there was a better one with a guy in an airline seat but I can't find it now)
Here's the zen of Colorista: you'll learn a lot.
http://redgiantsoftware2.com/Downloa...vanced_web.mov
After Colorista you won't. And FWIW, if you ever do green screen, don't bother with FCP controls - check out Zmatte and DVmattePro. The built-in tools of FCP are the bare bones basics and can be bettered.
Robert M Wright February 5th, 2008 04:06 PM
Thanks again.
The MSU Deblocking Filter is a filter for use with Virtual Dub. Virtual Dub is written for PCs.
Marcelo Costa February 5th, 2008 04:23 PM
tom.
Tom thanks again...
I will do your advices, thanks a lot... Just curiosity, how do you mount your light horizontally? I think it will produce a nice look for who is watching you when you are working.
In the past I had a bad led light experience, and never more... It is terrible...
Thanks again,
regards
Marcelo
Marcelo Costa February 5th, 2008 04:32 PM
Thanks again Matt, I will try to work with AIC... To save some Hard Disk space, can I capture using HDV and render the sequences with AIC?
The ProRez codec I could not find in my FCP 5, anyway, you said that you need a powerfull computer to run it, and I just have a MacBook Pro with Core2 Duo, 2.33 ghz and 2 gb ram...
Regards
Marcelo
Marcelo Costa February 5th, 2008 04:33 PM
Thanks a lot.
Regards
Marcelo
Matt Davis February 5th, 2008 04:41 PM
I've reversed the order of your questions:
The Mac is fine. It matches mine. ProRez comes with FCP version 6 (aka FCS2).
I'd use an all-AIC workflow until you switch to FCP6. Hard disks are cheap! Then you can capture HDV and opt to just do renders in ProRez. This is probably the optimal setting for MacBook Pro users.
Marcelo Costa February 5th, 2008 04:45 PM
Matt, it is me again, a last doubt, I shot the sweet 15, in HDV mode, but using Mini DV tape (not HDV tape)... When I record HDV with mini DV tape, do I get a worse image? Using HDV tape (instead of mini dv tape) should it reduce the squares blocking ?
I checked another thread before and they said that MiniDV tapes and HDV tapes are the samething... But it looks strange to me...
Thanks again.
Marcelo
Marcelo Costa February 5th, 2008 04:46 PM
Thanks again, you are the master.
Matt Davis February 5th, 2008 05:26 PM
Originally Posted by Marcelo Costa (Post 820890)
When I record HDV with mini DV tape, do I get a worse image? Using HDV tape (instead of mini dv tape) should it reduce the squares blocking?
Tape is tape. It's either reliable or it isn't reliable. If you record DV, it's just a string of 1 and 0 numbers, but if the tape is unreliable, a few 1s and 0s may go astray. That, with DV, will lead to some interesting block patterns for a frame or two (or several, or many).
If the same imperfect tape were to be used to record HDV, the same little upset may be only for a fraction of a second, but it will knock out half a second of your video (in my experience, everything freezes with no sound for half a second).
HDV master tape is the 'best bits' or prime steak of a big body of metal rust glued to plastic. DV tape isn't quite prime steak, but is good for most duties and probably may never give you problems with HDV.
Cheap tape (neck end or oxtial) will probably mess up your system with artificial additives that make pictures lock up and tape wrinkle (this is bad).
There are big debates about this, but I'll come clean and admit I use Sony Premium tapes for EVERYTHING (DV, DVCAM and HDV) and have not had a problem. No problems, just examples. I've had drop-outs (two in HDV) but they have been in a run-up and an outtake so it's not a problem yet. I've had two DVCAM tapes chew up (one Sony, one Panasonic).
Therefore I'm going tapeless. HDV takes ages to get going on tape but is instantaneous on solid state or hard disk. No dropouts, no tape mangles, no delays.
On the other hand, I used to have a non-optimal system setup that created errors/problems that looked just like tape issues, but they were just system setup issues. Now with MacBook Pro and FCP, I have no problems like that any more.
I'm aware this sounds like an optician saying 'here, use these spectacles, they work great for me' which is blatantly wrong. Just test, test and test again. And try Colorista - it's great! :)
Marcelo Costa February 5th, 2008 05:26 PM
John, it is me again, just for curiosity, why is it better to shoot in HDV, edit in HDV then convert to SD... than shoot in HDV, downconvert to SD and edit in SD ?
Thanks again
Marcelo
Kevin Shaw February 6th, 2008 12:02 AM
Try shutter = 1/30 for additional low-light response. This may result in some blurred motion but usually not too bad; you can even go to 1/15 if you don't mind a noticeably blurry look. Push the gain to at least +12 or even let it go all the way to +18. That may look grainy to you but chances are most wedding customers won't notice as much as they'd notice dark footage.
Tom Hardwick February 6th, 2008 02:25 AM
Marcelo - I mount my 20-DW2 video light horizontally off a cold shoe I've attached to the vertical bracket I've got on my Z1 - shown here:
http://www.camcorderuser.net/cpg/dis...at=10075&pos=2
I'll try and find time to put up a picture of the light in place.
tom/
Marcelo Costa February 6th, 2008 06:04 AM
thanks , I will try.
Regards
Ervin Farkas February 6th, 2008 07:17 AM
Marcelo, what exactly is you are trying to accomplish? I have shot wedding receptions where the ONLY light was candles on the tables and it looks fantastic with 9-12 dB gain even in HD (perfect down-converted to SD).
It doesn't look like you're a beginner, but I will still mention this - please don't feel offended: are you trying to make that footage look like it was shot in a normally lit place?
To call the Z1/FX1 "terrible" in low light is simply unimaginable to me... in the price category they have by far the best low light capability!
Marcelo Costa February 6th, 2008 08:32 AM
Hi Ervin, thanks for your attention, don't worry, I don't feel offended, I'm new with HDV...
I think that I wrote it badly, my problem is not really under low light condition, it under disco environment, in a disco floor, where the lights change a lot and very fast... So I'm getting a lot of square blocking as you can see on the pictures, the 1st one is ok, but the next frame, when the light changed brutally, I got this bad looking, check it:
This problem I did not have when I was shooting with DV using my PD and VX (I believe if I shoot in DV mode using Z1, I won't get these squares)... So another pros on this thread explained that it is a HDV problem, because it uses MPEG compression, so, I need to live with it, use some soft light to minimize the problem, do not push gain too much (+9db at maximum), record with shuttle like 60 maybe 30...
Thanks a lot for your attention, best regards
Marcelo
Marcelo Costa February 6th, 2008 08:14 PM
Thanks Tom. Here in Brazil we have a Disney's character that we call Professor Pardal, he is a bird that has a little robot lamp as his helper, he creates a lot of cool stuffs... Your are Professor Pardal...
We have something in common... I'm a huge fan of VX2000 too...
I saw a lot of interesting things, but one called my attention... The 20-DW2 with 2 balls joints that gives flexibility to the light... Do you have something like it that I can attach to Z1's shoe? This way I could have a a flexible light on the top of my Z1...
If yes, where can I buy it? Could you please send me the link?
Thanks, best regards.
Marcelo
Tom Hardwick February 7th, 2008 03:10 AM
Professor Pardal in auto-reply mode ...
Yes, to make your 20-DW2 lamp more 'aimable' why not fit it to one of those little hot-shoe extenders that SLR owners fit between their top mounted electronic flash guns and the camera? These you can lock in all sorts of positions to aim the light up, down or even (if you fit it in the Sony shoe at 90 degrees) sideways.
The other way is to buy a dedicated LED lamp that has pivot points in the arms that attach the little lamp housing to the battery base. I'm testing one right now. Go to
http://tnpbroadcast.co.uk/equipment.php?row=9&new=1
and look for the PRO-X XD-L32S for a look-see.
PP
Marcelo Costa February 7th, 2008 05:17 AM
PP
Tom, thank you so much for your attention... Very cool your new light, but I just bought two 20-DW2... If I buy another light probably my wife is gonna kill me...
I found 2 hot shoes as you said at BH, do you think that it is going to fit on the cam and on the light? Please, if possible check the links:
http://www.bhphotovideo.com/c/produc...e_Mount_1.html
http://www.bhphotovideo.com/c/produc...lash_Shoe.html
thanks a lot
Regards
Marcelo
Tom Hardwick February 7th, 2008 05:59 AM
Exactly right Marcelo, and I have both those shoe adapters and both work OK. You don't need the hot one - the cold one will do. Only downer is they're not 'lock-down' shoes and simply rely on friction between foot and shoe. Look for a locking one.
And don't worry - your 20-DW2 lamps are excellent at the price - much better than the LED I'm testing.
Marcelo Costa February 7th, 2008 07:17 AM
Thanks Tom.
I just do not understand what you mean by cold and hot... In your opinion, which one is the best? Hama or Kaiser (both have the same price) ?
I tried to look for a shoe with locking, but I did not find it at BH... My brother is in USA, so he will bring it to me on March...
Thanks again
Marcelo
Ervin Farkas February 7th, 2008 07:19 AM
A hot shoe has electrical contacts, a cold one does not.
