-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   re-sizing HDV images (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/37798-re-sizing-hdv-images.html)
Ali Rasheed January 14th, 2005 10:31 PM
It seems from the posts here that while the superior quality of the HDR FX1 is obvious on a HD display, there isn't that much of a difference on a standard monitor.
1)As with still images, has anyone tried resizing the HDV images to 720X576, and if so does it make them look any better than images originally shot in the SD mode?
2)Like many other digital filmmakers I too obviously want to upgrade to the affordable higher-res format, but what's the point if my customers don't own HD equipment to be able to view the difference?
Any thoughts or suggestions much appreciated.
Shealan Forshaw January 15th, 2005 06:54 AM
HDV video, resized to DV size looks better than footages orginated on a DV camera imo. Somebody posted a clip of a guy on a mountain bike, converted to mpeg2 for a DVD and the clarity was amazing. Much better than any DVCAM footage I have converted to DVD from my PD150. I would say footage converted to DV res has more of a Betacam appearance to it.
Steven Gotz January 15th, 2005 12:13 PM
I have not been able to test this theory adequately I guess. It seems to me to be about the same as an SD camcorder. I compared the footage I took with someone else's SD footage from a VX2100 and it looked virtually identical.
I suggest that the only reason to spend the extra money, and to carry a MUCH larger camcorder, is to shoot HDV in order to present HDV.
Don't be mislead. There are many people with HD equipment. And many of them would be happy to have a DVD player capable of playing T2 and Step into Liquid, alongside their wedding video. Since the DVD player is only $249, I imagine that most people with expensive HD equipment would be willing to buy it.
At worst, they might be leaning toward a Media Center PC. There are large groups of videophiles out there who want such things.
The real solution, no joke, and no offense meant to anyone, but the real solution will make itself clear as soon as the porno industry takes a stand. If they, even temporarily, decide on WM9 distributed on DVD-ROM, the sale of the AVel Linkplayer and Media Center PCs will take off like a shot!
Joel Corral January 15th, 2005 08:46 PM
no i disagree,
i have 2 HDR-FX1's and down convert all day long. and yes it looks better down converted than most other high end DV camera that includes most of the DSR's from Sony. the difference is i am mastering @ over 800 lines vs 525 lines which means i get amazing detail when the camera is in a wide shoot. and even more amazing when i am tight. and when you master to DVD from a better higher source results will be very solid. and the good side is i am ready with a HD version when "BluRay" takes off. and there a ton more benefits in post as well.
oh and you get native 16x9 ... when you shoot in 16x9 sqeeze mode with SD DV cameras you lose about 1/3 resolution. thats another plus of the HDR-FX1. :)
joel
Peter Nolan January 16th, 2005 12:09 AM
Here ya go.
The first frame was shot in HD mode, captured by Aspect HD and then opened in Photoshop and deinterlaced and resized to 1080 x 576 and saved as a jpg.
The second frame was shot in DV mode captured in Premiere Pro and the opened in photoshop, resized to 1080 x 576 (to get the aspect ratio correct) and deinterlaced and saved as a jpg.
http://www.3-ads.com/FX1-samples/hdv.jpg
http://www.3-ads.com/FX1-samples/dv.jpg
Joel Corral January 16th, 2005 09:58 AM
you can't really compare if you use jpg. you need to use like bmp.
Filip Kovcin January 16th, 2005 10:25 AM
to Peter Nolan
show us some tiffs, not jpgs. it's hard to judge this way.
filip
John Jay January 16th, 2005 01:33 PM
I cannot re-up the bike footage but instead have some proscan coverted stills at 480p 540p 720p for your viewing pleasure
the link will expire so dont be slow
they are all bitmap in the zip file
go here
http://s27.yousendit.com/d.aspx?id=1...I384P2CZLY3YQR
Steven Gotz January 16th, 2005 01:39 PM
I suppose the real trick is to shoot in HDV and capture as DV. Then shoot DV and capture as DV. Then borrow a VX2100 and shoot as DV and capture as DV.
Take one frame from each and compare.
I don't have a camcorder to compare with anymore, so someone else needs to do it.
Mike Tiffee January 16th, 2005 03:00 PM
These are TIFF files, uncompressed- not resized in any way except where noted.
I put them in order of quality in my opinion. I place 16x9 DV as higher quality than 4x3 DV because it will look better on a 16x9 set.
Full size HDV frame:
http://www.miketiffee.com/hdv/HDV16x9.tif
HDV frame resized to 720x480 in photoshop:
http://www.miketiffee.com/hdv/HDVtoDVphotoshop.tif
HDV to DV conversion via 1394:
http://www.miketiffee.com/hdv/HDVtoDV1394.tif
16x9 native DV:
http://www.miketiffee.com/hdv/DV16x9.tif
4x3 native DV:
http://www.miketiffee.com/hdv/DV4x3.tif
I have no other DV camera to compare to, but in my opinion the photoshop resized image looks much better than the 16x9 native DV image... if you look at the stop sign, you'll notice the reds are handled much better.
Frank Aalbers January 16th, 2005 05:02 PM
Well ... It allso all depends what package you use to downsize. The kind if filters you have availabe.
Here is a test that I posted in another thread.
http://home.comcast.net/~chalbers/compare_short.mov
It's 1440*1080i upper filed first FX1 footage downresed to 720*480i lower field first.
You tell me ... quality difference is very obvious.
I'll look into the footage Mike just posted
Frank
Kyle Edwards January 16th, 2005 11:50 PM
http://img102.exs.cx/my.php?loc=img102&image=d030xs.png
http://img102.exs.cx/my.php?loc=img102&image=d049vm.png
I need to get my own hosting back, imageshack turned the BMPs into PNGs. Either way, you can still see the amount of detail in both.
Which one is which? One is straight DV (16:9) and the other is HDV resized.
Joonas Kiviharju January 17th, 2005 01:48 AM
I'd bet my HDR-FX1, that the d030xs is HDV resized, and the d049vm is an example of the greatness of DV packing! My guess is purely based on the differences in Mikes images. Those DV reds were always awful.
Oh, and if my information is correct PNG does a lossles compression, so these are full quality images.
Especially thanks to Mike. Your images are very clear and informative. I've been trying to color correct some footage that I've shot, and I've been very disappointed by artifacts that appear. But your images clearly show that this only due to improper resizing incamera, and DV packing. Native HDV (or some variable compression intermediate codec) seems to be the way to go with HDV. It's all looking good now.
Filip Kovcin January 17th, 2005 03:11 AM
kyle,
tell us which is which.
maybe i didn't read properly - my question is - HOW you resize it? with camera downconverter or with photoshop or similar program?
in my opinion d049vm.png is dv
filip
Steven Gotz January 17th, 2005 10:11 AM
OK, I have decided which I like better. Now, how did you resize the HDV, and which is which.
I would prefer that d030x be the resized, but I will wait for the correct answer.
