-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   Cutting between a FX1/Z1 & a PDX10P? (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/38141-cutting-between-fx1-z1-pdx10p.html)
James Darren January 22nd, 2005 05:41 AM
Hello all,
Is it possible to up-convert a Sony PDX10P (PAL) signal to mix it with footage taken from a Sony FX1/Z1 at 1080 60i? Its for a DVD release in the US. All of the footage taken from the PDX10P is still shots (mostly outdoor with little or no movement)
How can it be done & what type of results can I expect?
Boyd Ostroff January 22nd, 2005 07:38 AM
If you're going to DVD then it seems like you will need to downconvert the FX-1 footage instead. Or are you using some sort of HD DVD format?
James Darren January 22nd, 2005 10:36 AM
hi,
sorry I should've stated...
yes the final output will be HD.
Thanks...
