-   Sony HVR-Z1 / HDR-FX1 (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/)
-   -   FX-1 and 4:3 output? (https://www.dvinfo.net/forum/sony-hvr-z1-hdr-fx1/39054-fx-1-4-3-output.html)
Jack McCann February 7th, 2005 09:35 PM
Hi,
So let me get this straight...I have a conference I am going to shoot with the FX-1 that will be broadcast to a large 4:3 screen via an LCD projector. I will just run S-video (or maybe even component if the projector handles it) out to the projector. Here's my question; can I send out a 4:3 image or do I rely on the projector to 'crop' the image?
J
Douglas Spotted Eagle February 7th, 2005 10:34 PM
Send out a 4:3 image from the FX1 or your projector will likely squeeze the image, depending on how it's set up.
Joel Corral February 7th, 2005 11:32 PM
in the menu you have to select TV>4:3. then it will automatically letterbox the picture for you!
Mike Tiffee February 7th, 2005 11:57 PM
the FX-1 only outputs a 16x9 image when shot in HDV mode. The two choices are 16x9 letterbox and 16x9 anamorphic. The Z1 includes an additional 4:3 center-cut option which crops the left and right edges of the screen.
if your projector isn't a hi-def projector, i'd shoot the footage in 4:3 DV and project it that way.. unless you want the letterbox look.
Joel Corral February 8th, 2005 12:25 AM
mike thats is not correct! i shoot all day long in HDV mode and out put to a sony monitor and i am getting a 4x3 letterbox output image. there is a option in the menu that you can change your output from 16x9 to 4x3. check it out if you have the camera.
joel
Mike Tiffee February 8th, 2005 12:48 AM
Actually, the correct term for what you're seeing is a 16x9 letterbox image. not a 4x3 letterbox image. the "16x9" refers to the aspect of the letterbox, not the display aspect ratio. 16x9 letterbox is how you show 16x9 footage on a 4:3 canvas.
Changing the output from 16x9 to 4x3 doesn't change the aspect ratio of the image to 4x3, it only letterboxes your 16x9 footage to display in full perspective on a 4x3 set.
We're both saying the same thing, just saying it differently.
Joel Corral February 8th, 2005 12:52 AM
ok thanks,
but it is a 4.3 image and thats what the poster was asking for. and indeed it does. inother words the 16x9 image will not be "sqeezed" into a 4x3 image.
joel
