Disaster!
Today is not a good day.
We just finished editing a rough copy of a short film we just shot so our musicians have something to watch while they write. The footage looks great and has always looked great on our editor's COMPUTER. Once I burned a DVD of the movie, the 'you know what' hit the fan. Every movement looks like crap. It is almost pixelated and looks real blocky. It is not a subtle motion blur like we expected, it looks HORRIBLE. Also, all of the audio sounds muddy and is very low. You have to crank the TV to even hear it, and even then it sounds like crap and there is a buzz. We monitored the audio correctly, and it recorded right. I know this because it plays back on the computer very well. Everything looks and sounds GREAT on the editor's computer but is unwatchable when burned to DVD or exported to tape. Before you ask, we shot in Cineframe24. It is my FX1 so everyone wants to kill me! Does anyone have any suggestions?? We are editing in Premiere. I appreciate any help. ...Andy |
If the movie looks good and sounds good when you see it on a HD monitor and good speakers then you just have to re-compress the mpeg file. Sometimes using too high of a bit rate would do that to the image specially on the dark areas.
What compression were you using? |
Hello!
Thanks for the reply. We actually didn't shoot in hi-def. We shot in 480i in DV wide rec. mode. (which my prof later pointed out was a stupid decision) We exported the movie from Premiere as an AVI and I brought it into iDVD to burn it. Anyone else? I need an resolution quick or I'm dead! ...Andy |
Try rendering it as an Mpeg2 file, upper field first, video only. Then render your audio as a wav file. Combine the two in your dvd authoring software as see if thats an improvement.
Let's just 'pretend' I am not completely sure how to do this.
Can you give me a quick explanation? I'm a Mac guy so I've never dealt with this kind of thing before. |
What exactly are you using to compress and author your DVDs?
Encore
I cut on AVID Xpress Pro HD and had all kinds of problems making clean DVD's--problems independent of the editing software, but rather the encoding stage. I tried Encore with fabulous results and it takes some experimentation to hit the sweet spot of bit rate, and all the other settings that are largely undocumented. I think you can download a trial of Encore--- might want to try that. Don't go crazy with high bit-rates because some players can't handle it-- I think I used 6000-7000; top end is 9000 I think. Also if there is an AC-3 option take that.
Hey guys,
Like I said I just exported the movie from Premiere as an AVI and dumped it onto my computer in an iDVD project and burned it. Plain and simple. I have never had this problem before. Cineframe24 is fake 24p so we should still be editing in 29.97fps correct? My prof thinks that the audio was recorded on a track that isn't being played back once exported. Does the FX1 record sound in hi-fi? At my school if we turn on the hi-fi on the svhs deck the sound will play back properly. I appreciate everyone's input, but I really don't think this is a compression problem. It was not recorded in hi-def. Thanks for your help, ...Andy |
In Premier go to Export, Movie, clik on settings, under file type in the General Tab select MainConcept MPEG, select Key Frame and Rendering and be sure that it says "upper field first".
And by the way the only cinefame mode that looks any good is 30. Then you have to capture as progressive....etc, etc...... The camera works best when it is set at 1080i |
Perhaps iDVD is not muxing the video/audio correctly when fed this particular AVI. (I don't know - never used iDVD before). Try encoding the video in Premiere using one of the DVD MPEG2 presets - set the audio to AC3. Then let iDVD burn *that* file. If iDVD is worth its salt it should not re-encode the already DVD compliant file (i.e. it should burn it much quicker than a plain AVI). |
Ok, I will definetely try that. Thanks guys.
Unfortunately my editor has gone home for the weekend and brought all his gear with him! Just to clarify though, we made the right choice editing in 29.97fps correct? The Sony Cineframe24 is just an effect and doesn't really record 24 frames per second? That's what I've been told so that is why we didn't edit in 24p. This is a tough way to learn a lesson! ...Andy |
Cf 24
Dear Andy,
Regardless of where the problem with the DVD is coming from I would avoid using the Cine Frame 24. I just think it is too herky-jerky and I would try the Cine Frame 30 next time. I am not trying to rub salt in your wounds or be a smart-ass, it is just a word of caution for your future projects. Sometimes things don't work out... try not to internalize it too much. There still may be an easy answer to your problem. I just spent way to much time trying to extract video from a VCD. Tried Sorenson, direct import, on and on..... I ended up shooting it off the computer screen which was OK because it was a low resolution medical camera. Problem solved. I feel better now. Take care, George |
Cine Frame 24
Is just an effect... Adam Wilt has a full discusion of his site www.adamwilt.com
Your problem could start with your original export. I edit on Avid Xpress Pro, and for DVD authoring I export from Avid to an uncompressed Quicktime. You have to have the drive space to do that, but it makes a huge difference over the normal Avid codec QT. A half hour program that may be 5 or 6 gigs will expand to about 50 gigs and take maybe an hour or two to export, but it's worth it when you do the m2v compression for the DVD. Then, when doing your DVD, check our data rate settings and use a variable data rate if you have the capability. If you have Cleaner or Sorensen, you can do your compression there and make a big difference.
You said the program looked good on your computer monitor, but what about your NTSC monitor? Assuming it looks OK in your NTSC monitor, then most likely all your problem is in your DVD encoding. I've seen some stuff shot with the CF 24 on DVD and it looked OK. However, it was shot HDV, not DV. |
Sure sounds like you got your field order reversed...
Andy
Don't panic yet. If the footage looks and sounds great on your computer, then most likely everything is fine. If your using iDVD you should export your movie from your NLE as a quiktime file and not an AVI file. This might be where your problem is. Does your footage look and sound good when played back from your FX1 on to a monitor? Also, I think in the future you should shoot in 1080i and let the camera downconvert the footage to DV. I hope this helps, Aldo |
Hey Aldo,
My editor uses Premiere on his PC to edit, so he exported the movie as an AVI. I took the AVI file and dropped it onto an iDVD project (on my mac) and burned it that way. The footage looks great when played back throught the camera, so I know that it isn't completely screwed. Nobody thinks this could be a frame rate problem? Once again, we shot with Cineframe24 and are now editing in a 29.97fps project. Is this the proper way to do this? The audio is still not playing nice. Geez, it's such a nice camera, I wish I could spend more time shooting and less on damage control. Thanks for everyone's help, I WILL get to the bottom of this. ...Andy |
IDVD does not work with AVI files. Your editor needs to provide you with a quicktime file or you need to convert the file to quicktime yourself before inporting to iDVD. This should solve your problem Andy.
Cheers, Aldo |
| All times are GMT -6. The time now is 08:56 AM. |
