Help - Exposure issue with HVR-Z1
Hi
I've been loaned a HVR-Z1 for the weekend and I'm doing as muchas I can with it in the short length of time I have it. But I'm struggling a bit with manual iris.... I've set the Auto lock mode to the middle position..... Aiming at a dark-ish scene I've opened the iris up so the scene looks OK...but then as i swing round to a brighter scene the camera appears to be closing the iris again - I would have thought that if it's in manual it should remain as i've set it - thus overexposing the brighter scene. Am I missing something? Thanx Ian |
You have to make sure that all the functions: iris, gain, shutter, are in Manual mode. You need to see their values in the viewfinder. If you can't, then press the relevant buttons until you can.
Robin |
Yep, it sounds like either the gain and/or shutter speed are changing in response to your iris adjustments. Like Robin says, if you don't see them listed on the LCD then they're on auto.
Thanx guys - you were exactly right - all settings displayed now and working as expected.
Cheers Ian |
| All times are GMT -6. The time now is 09:11 AM. |
