But I will carry on some tests to compare them on a good pro monitor and see what happens. Thanks for the tip. What were the differences you noticed? |
But you should do your own tests and decide whether the risk of dropouts is greater than any improvement the image may have. Personally, I don't think I've had any dropout issues in shooting around 80 hours of performances this way. I have used Sony premium tapes exclusively since I bought the camera. |
That doesn't mean that you might be right and what you are proposing might be even better. Today I will be shooting just with my camera, and I will use the chance to shoot in DV and HDV and see what happens Thanks for the tip. Carlos |
OK. Downconvert seems like an interesting and safe way to go.
I also talked to a friend from a production company here that records for Discovery in HDV with Z1s, and my concern for eventual dropout problems is not justified. Next concern is how I will frame for two sizes now: 16:9 and cropped for downconvert 4:3 DV. |
OK. I've done both things: gone back to HDV and add side-markers. The center mark I've kept it off, as that might activate a tendency to center things around it.
Another thing which I did was a second ASSIGN button, activating "Steadyshot" on button 2. Button 1 was already for Underscan. Now that I was back in HDV allowed me to see what Boyd was talking about. What other functions have you found practical for the ASSIGN buttons? Perhaps the latter should deserve a separate thread for people to suggest what has worked for them. |
I use:
WB OUTDR LV+ WB OUTDR LV- REC REVIEW STEADYSHOT HYPER GAIN ALLSCAN MODE |
What did you set you WB outdoor levels for? |
If your preset WB is set to OUTDOOR, you can use the WB OUTDR LV+
WB OUTDR LV- buttons to quickly adjust colour to your liking. |
Avoiding colour correction in editing saves you time in the edit, saves you time in rendering, and give you a slightly better image (any rendering can degrade your image from the original)
I think it's only there, with proper monitoring and watching the editing flow, where you can achieve a balance of the whole. |
Well, certainly you have a good point, but it depends on what you are working on. I do a lot of events where quick turn around can be important, so I try to avoid things that slow me down.
If I were doing a documentary or movie, that's a different story. Then you want to be able to experiment with looks in the editing. |
Of course I did guess that what you were talking about, and you certainly would be right for quicker turn arounds.
In my case I am and have been working on documentaries, and I got to do in editing what would have taken me lots of money to get beautiful results. What I will try to do, if possible, is to do the final tune up on a higher grade editing suite. Let's hope the budget, which I still don't know what will exactly be, will allow that. |
| All times are GMT -6. The time now is 09:03 AM. |
