There could also be SYNC, FOLLOW... Quote:
Either camera you have to have the settings correct, there are only a few options so it isn't hard to toggle through them to see what works best for you. As for transferring, I use FCP & a Lexar FW800 reader. I had a 21min clip shot in SD that transferred into FCP in about 3min! HDV is more about 3-4min of footage in FCP in 1min. But a lot of that depends on your card speed, card reader, hard drive, software & processor. |
Well to be accurate it works with a Z1 the same as a Z7 EXCEPT with a Z1 you can't record to CF cards in isolation. You must have the tape recording too. .... OR you run without tape but press the MRC1 dual button instead. This is a real issue in that I shoot fast moving sport on cache mode, and use a pan bar with remote run stop.... great with the Z7, but doing ti with the Z1 means taking fingers off the tripod to pump the MRC1 buttons during the shot (in cache mode you record the 14 seconds preceeding the pressing of run button and then finish the shot at the end of the goal etc.) This is then instant reviewed to a videowall -hence I can't record the whole game. I was thinking of buying a FX1000 to replace the Z1 but if the previous posts are correct, it has no more CF functionality than the Z1.... unless someone can assure me there is a workaround and I can use the Fx1000's run stop button without tape? PS -the manual does not mention the External Control function. PS does the relay work? and if it does not, why is it in the menu options? |
Thanks for the clarification. The FX1000 ought to perform the same as the Z1... sony.biz site says it is compatible, whilst it implies older cameras are not, yet if it does not mention External Control in the FX1000 manual, and you say it is not in the menus, so the FX1000 is as compatible as connecting any firewire camera to it. So I would get less functionality going from a Z1 to a FX1000. I have also tried to work out the difference between FOLLOW and SYNCHRO in the MRC1 menus. When connected to the Z1 it appears to make no difference. They both enable the camera run button... but both with tape running synchronously. How can FOLLOW trigger the MRC1 from a Non-ext. control camera? If it can't..what is it for? If it can... what is the difference between no-ext control and ext. control? |
The difference is that with a cam that can do EXT REC CTRL, it sends the REC signal immediately to the external unit, and enables other functions, like RELAY. With a cam like the Z1/5, there probably isn't a point to FOLLOW mode, but it has to be there for all the other cams. |
| All times are GMT -6. The time now is 07:59 PM. |
