Issues capturing from the Z5P
hi guys,
I was just trying to capture some test footage from the Z5p with Premiere Pro and it is saying "ERROR" no device orsomething like. I know the firewire is working because when i plug it in and turn it on it buzzes and loads up and then has ILINK on the LCD screen. I have been reading its a conflicting codec or seomthing like that??? Has anyone had thsi issue or know how to fix it? thanks Jason |
delete * oops sorry I posted on wrong thread..
Jason,
I was constantly battling PPro and FireWire capture with all my Sony camcorders (until I got the MRC1 and was able to ditch tape capture). I don't know if this will help you, but PPro is very picky in the order in which things are connected and turned on. And it seems to be inconsistent about its pickiness. Usually, the following scenario worked: 0. Turn off power to Z5 1. Start PPro 2. Connect FireWire cable to Z5 3. Turn on Z5 in VCR mode 4. Initiate capture. When this sequence didn't work, I would mix up the order a bit and could always get PPro to eventually recognize the camera. |
still no luck.... dam this is getting frustrating.... :(
Re: Issues capturing from the Z5P
Bumping an old thread, but I'm having a similar issue. I've shot mainly DV until now. Trying to import HDV, no luck. I shot to tape, 1080i 60fps. I changed the camera VCR to HDV & the iLink format to HDV. I also changed Premiere CS4 capture setting to HDV.
I'm just getting a blank screen in Capture saying "Device not found". Any thoughts? |
download hdvsplit.....
Thanks, I've been reading & coming across that a bit. I was hoping there was a way or glitch to avoid having to download & use a 3rd party, but I'll give it a try.
Always make sure you are making your connections with both devices powered off, then power on PC, then camcoorder. Sometimes this helps the PC see the cam over FW.
This is assuming all your Premiere project, capture and device control settings are HDV, as you've indicated they are. Edit: Quote:
You should think about the MRC1k card unit at some point, which just snaps right onto the back of the Z5. Once you go tapeless, you'll never go back. |
| All times are GMT -6. The time now is 07:02 PM. |
