Is this the best Sony FX1000 can do?
1 Attachment(s)
I'm a good way into a documentary, and I'm getting frustrated with the picture quality of this camera. I'm wondering if this is the best this camera can do, or if I'm missing something in the settings department. This sample was shot with manual focus and everything else automatic. I thought the lighting was ideal, and was hoping for better. I'm using Premiere Elements, but I've ruled that out as an issue, since I've hooked the camera up to my TV with an HDMI cable and get the same results. I'm not terribly experienced, but the last film I shot I used the Canon AE-1 and it was fantastic--you could see the pores on peoples' faces. That's what I was expecting here, and it's not even close. By the way, I'm shooting in DV, not HDV, SP, 1080/480, 24 FPS, Any feedback would be greatly welcomed.
Doug PS: I can't get the sample clip to attach. It has a blur around the face that's disconcerting (a close-up of an interview). There is detail--you can see individual strands of hair--but there's this overall lack of sharpness. Maybe someone can walk me through the attachment process. I do "manage attachments - Browse - File," but it doesn't post with my message. |
Re: Is this the best Sony FX1000 can do?
You have got to hit the "upload" button as well in the manage attachments screen, it's located on the right side.
Is there a reason you are shooting in DV? You can't expect sharp images in that setting, also a Canon ae-1 is a 30 year old photocamera. :) |
Hi Doug,
My guess would be that the "overall lack of sharpness" is actually due to a couple of factors - 1) You're shooting standard definition DV 2) Camera in AUTO mode. You should be manually setting white balance and exposure for best results, can't always trust auto. Take control to get the desired results. Pull out the manual, connect the camera to a monitor, enable info overlays to external, and then you can play with camera settings while watching live results on the monitor and you can also SEE all the settings on the big screen so you can understand what settings/changes get what results. LEARN the camera is the #1 thing. 3) You're viewing that SD footage on an HD display - it's going to look BAD because it is getting "blown up" by the display. If you watch the footage on a good SD production monitor (CRT) it should look very good (for SD footage). Of course you would need to use an analog connection to the SD display. I would recommend shooting in HDV. You can always deliver as SD later, but keep the quality up in the acquisition and editing stages. While I have shot with the FX-1000 a few times when working for another company, I did not have the opportunity to get intimate with the settings menus, but from experience with other Sony cameras, there will be some internal controls for sharpness, color, etc. that will allow some customization of the recorded image to suit your needs and taste. Thanks |
Thanks for all the replies. Indeed, the prior camera I used was a Canon XH-A1.
I have done some manual work on this project, but I am mostly all on my own--sound, camera, interview. It's an independent labor of love, and I accept it as it is. If I can let the camera do some of the work I try and let that happen. I tried to upload a clip of video, and got an error message, but I was able to upload a still (see original post). It shows my problem: close but not close enough. As for the DV, v. HDV, in the past Premiere Elements kept crashing with the HDV, and I had read in some forum or other that the DV was really equal to the HDV in small applications (TV size). I was certainly convinced of that argument by the Canon XH-A1. As it happens, I just got a new computer this week with 10 gigs of RAM and plenty of memory, so maybe it's time to reconsider the argument. I just shot a short bit of HDV, and it looks much better. (One side issue: Premiere Elements only seems to have a setting for HDV 30. I've been shooting at 24 fps.) There is another issue about shifting to HDV after having already shot 10 hours of tape (another 20 to go, I estimate) but obviously this film is going to have rough edges. I hope the story is strong enough to compensate. I appreciate feedback to any and all of these issues. I'm in a bit of a desert here. Thanks again, Doug |
Hi Doug,
Let's back up a bit - when you were shooting DV, was it 4:3 or 16:9, and was that also 24p? I just scanned through the entire FX-1000 manual and while it does say the cameras offers 24p, I could not verify if that was only in HDV mode, or DV mode as well. Thanks |
1 Attachment(s)
Jeff,
Thanks for your response. The camera can do 24 p in SD or HD. It's Premiere Elements that only has a 30p setting for HDV. My guess is that there are workarounds. I've done some experimenting and looking over my footage, and considered the feedback I've received here, and this is where I think I am. I'm attaching a piece of a shoot that first concerned me. This was a challenging situation. I thought I was good because I was in a shaded spot, but a building not far away was reflecting late afternoon sun very strongly. Obviously a dedicated camera guy would have helped out a lot here. This was manual focus and everything else auto. Other shots that were concerning me were wide angle establishing shots with lots of scenery and these were not only not as sharp as I would like them to have been, but seemed to "shimmer" unpleasantly. These were all auto, and now I see that was probably automatic focus figuring things out. I can stop that hereafter. So you can see I consider myself much stronger at the storytelling part of documentary than the technical parts, but I'm eager to learn. I guess the outstanding question now is, with 10 hours already shot, should I switch to HDV now? Many thanks, Doug |
My very first suggestion would be to buy a NLE that is up to the task. Edit, just saw your videosample, it's a interlaced file, not progressive, how can that be if you say you edited in a progressive (30p) setting and if the source material is 24p? Can you maybe attach a very short file that came right out of the camera, so without anything done to it, even a second long will do, just to see if it's a 24p file. |
The FX1000 records a 24p frame rate in a 30i stream. A true 24p stream must be extracted from the DV or HDV 30i recording. The pulldown inserted by the camera to record the 24p in the 30i stream can cause artifacts that looks like flickering. Especially with moving objects or when panning.
So there is nothing you can do to prevent these kind of artifacts? In the video I also seem to see interlacing artifacts, are those "normal" as well? Then I think it would be a better choice just to film in 60i, no?
Not all the artifacts are "real" in that they are caused by how the video is packaged.
The interlacing artifacts are due to the pulldown. You can get rid of them by extracting the 24p video from the 30i stream. I suspect the video will look better if you do the extraction. |
1 Attachment(s)
I'm very interested in this discussion, though I'm afraid parts of it are too technical for me to fully grasp.
I don't know how to get you a clip without running it through PE. But do I understand you to say a higher end software system would do better with these files than PE? I have run the images directly from the camera to my TV--a 32 inch HD--and they look the same to me as what PE is producing. I only have two progressive scan options on the camera, 24 and 30. Would the 30 yield sharper images? Finally, I'm attaching a sample of the clip in which I saw what I tried to describe as "shimmer." To be honest I've been looking at this stuff too closely for too long, now. I really appreciate you guys telling me what you are seeing. The "flickering" Chris mentions, especially when objects are moving, is exactly what I am seeing. Oh, and Chris, how can I do that extraction?. My enduring thanks. Doug |
For me to show you what it would look like with the pulldown removed I'll need an original clip from the camera. Once you run it through your editing software and render it out as a MPEG file that changes things in a way that keeps it from working.
If you have dropbox you can send me a link to a file you upload to trackgeeks at gmail. I can do the extraction and see if that takes care of what you are seeing. If you need to go our and record a few second clip of a pan that should be fine. |
Doug,
By your own admission, the technical stuff is not your strong suit, so out of curiosity I would ask what prompted you to shoot in 24p? That just adds another layer of complexity to the whole deal. |
Yea but not everyone knows about this stuff till it starts to bite them.
We all start not knowing. Doug is certainly getting a crash course right now. |
As they say, a "little" knowledge is a dangerous thing. I read in a number of places that 24p produced a more filmic look. I didn't realize that it would create problems on this end. I shot today in HDV 30 and will soon see if there's a difference.
Chris, I've also downloaded Dropbox, so I hope to send you those clips tomorrow. Life is the great teacher. My subject involves kids in poverty. They deal with worse. Thanks, guys. Doug |
Sounds good Doug. You will get it figured out. We will help as much as we can.
I should mention that my comments are not meant to be critical; rather, it helps to understand the motivations and thoughts of the poster in order to help come up with a viable workflow solution.
Doug, it will be best not to mix frame rates. As you already have a great deal of footage shot at 24p, maybe stay with that then. If you start mixing frames rates in the timeline, the "look" will be different. Thanks |
Jeff,
I didn't take any offense. Quite the opposite, I appreciate the conversation more than I can say. And you hit on the crux of the matter. I have some material in the 24p that I think is very strong, and so I would certainly like to stay with it and keep the look consistent. I must say, I sure like the look of the 30p footage I shot yesterday. Of course it was in HDV as well--and I have to make the same decision there: stay with DV from here on out for consistency, or switch to HDV. Chris, I'm still stuck on how to send you a clip. It looks to me like I need to produce a file to put into Dropbox. I can't figure out how to produce a file direct from camera and not use Elements. Just out of curiosity, is the extraction process your are proposing something that a pro NLE would do? Thanks again for your encouragement, patience and help. Doug |
Yea, I can remove the pulldown when I bring the media into Media Composer.
Have you tried a capture using Windows Moviemaker? That will capture DV straight to disk. Recording Video into Windows Movie Maker (Part 1 of 3) And its free. |
Chris,
I think I'm making progress. Movie Maker gave me an error reading. I researched it on a forum, and was lead to WinDV. WinDV couldn't read the device. Before I got too far into that problem, I noticed that it was going to save the file as an .avi. PE does that. So I went ahead and saved the file through PE (it also saves in Windows format, so I did that too), and I now have them both in Dropbox. Now, for sharing with you . . . I've found links to your e-mail, but not your e-mail itself. Once I have that, this will be done, and I will have learned something new! Thanks, Doug |
I think we are on the verge of getting things straightened out for Doug. Progress was made today.
Just another voice here.... the FX doesn't really actually shoot anything but 60i, and that is what you should always shoot with this cam. 24p only mimics the worst aspects of film, and 30p is good for web but nothing else, and that's being converted anyway. In the future, shoot everything 60i and convert in post. And move up to Premiere Pro. All your problems will be solved. (The Z5 does actually shoot real 24p and 30p if for some mysterious reason you actually like or need these frame rates.)
Fort the moment, however, you are stuck with these oddball frame rates so you will have to stick with them unless you can find some artistic justification for changing midstream. |
The FX does shoot true 24p (23.97 actually) but it can't record it directly to tape since 24p isn't a part of the DV or HDV standard.
The trick is to properly remove the pulldown and assemble the progressive frames from the 30i stream. I've done it on a sample clip Doug provided and he was very pleased with the results. |
Well, it's a bit of a semantic issue as it can't record it, as you've noted, so you can't get true 24 or 30p out of the cam. It shoots 24p over 60i, as you've noted, so it's a little silly to say it shoots it but can't record it. Can it be "reassembled" into the real thing? Apparently so, but why go through all that when 24p almost always looks worse than 60i? (Just read all the threads started by people wondering why their 24p looks so terrible.)
I can see now that my mistake was shooting in 24 p, and once I did that PE was an unsuitable software program.
Chris has offered a glimmer of hope that I might run all my tape through some third party program, but that seems to be pretty unwieldy, especially since this is neither the part of filmmaking I do best, nor enjoy most. More chance for error and frustration. I downloaded a trial of Premiere Pro, and I see I can export in DV 24 p. Problem solved, right? (Except for the difficult conversation with my wife.) I'd hoped I could import in the right setting, but I don't see this option amongst the presets. It's been an education, and I appreciate everyone's input. Doug |
1 Attachment(s)
Sure, the presets exist. Once you start a new project and name it, Premiere gives you a choice of formats, either DV 24p or HDV 1080 24p. Just click on the appropriate format and it will drop down. Choose what you want and you are off to the races.
| All times are GMT -6. The time now is 02:22 PM. |
