some hvr-z7 info needed urgently
I am planning to buy hvr-z7e this days, and I have some questions:
- What is the radius of lens filter? I need this info to be shure, because I have some stuff from my Fx-1 left (wide lens, Letus pro 35 with adapter for Fx1)... - What is the resolution of final avi or m2t clip when recording 3s, 6sec and 9 sec of slow motion video? - What are advantages of DVcam recording, and is there a size difference of clips recorded as DV or as DVCAM on CF card? - Because od focus, zoom and iris rings can this camcorder be used with pro camera cranes with ring controlers? - Does this camera have Lanc adapter? - What type of usable color correction can be done on camera? |
tnx
Tnx,
I also need some real responds from users....if any of them is here.... |
RTFM mate. :) |
Just about all of this is in the manual.....
- What is the radius of lens filter? I need this info to be shure, because I have some stuff from my Fx-1 left (wide lens, Letus pro 35 with adapter for Fx1)... 72mm outer - What is the resolution of final avi or m2t clip when recording 3s, 6sec and 9 sec of slow motion video? not a clue, but is this supposed to be different? the spec for hdv is 1440x1080 - how and why would it be different? - What are advantages of DVcam recording, and is there a size difference of clips recorded as DV or as DVCAM on CF card? dvcam has a faster recording rate and minimized dropouts. 63 minutes dv is about 43 minutes for dvcam - Because od focus, zoom and iris rings can this camcorder be used with pro camera cranes with ring controlers? yes, if you're referring to follow focus, and others...i've used it with those as well as on a jib of mine via lanc - Does this camera have Lanc adapter? yes; multipin on lens and 1/8" on camera back - What type of usable color correction can be done on camera?[/QUOTE] preset, custom, and dial by temp. |
tnx
tnx a lot!
I will revert back when I try z7 in my hands |
This feature needs to be used with tape and does not work with the CF card alone. |
So is the slo mo really a gimmick?
Hi so is the slo mo really a gimmick on the HVR Z7 if we are honest with ourselves, say comparing to dedicated high end cameras such as a Phantom V12 ( but comes at a price for a mere 1200 pounds sterling/day to rent not including insurance etc or VAT)
Francis |
first impressions
I have it in my hands!!!
It is just just great as I thought! The supplied lens works great, it has a good servo zoom, manual controls are so easy to operate, progressive 1080 look so great, light sensitivity and the whole picture is so fresh! I have bought camera with supplied sony 8Gb Compact flash card, it is working without any problems...I just want to say that this camera is so great, and it is a top in HDV/DV production. I will post U some clips soon..... |
| All times are GMT -6. The time now is 09:35 AM. |
