-   Sony HVR-Z7 / HVR-S270 (https://www.dvinfo.net/forum/sony-hvr-z7-hvr-s270/)
-   -   Z7U CF File Joining (https://www.dvinfo.net/forum/sony-hvr-z7-hvr-s270/130039-z7u-cf-file-joining.html)
Rodger Smith September 11th, 2008 09:24 AM
Z7U CF File Joining
We do a lot of multi-camera (TV shows & weddings) and multi-sync is IMPORTANT to us and at present cannot use the CF unit because of the 3.96Gb file size limit and wondered if anyone knows of software or a hack that will join these files together seemlessly outside the camera both quickly and easily without data risk?
For background I know I can load them into a sequence and export them as a single clip which will join them but that isn't going to save me time over just capturing from three or four tapes. Someone said there is a file joiner that works seemlessly and I've looked and cannot find. I must be searching for the "wrong" label or keyword. So if anyone knows of a safe fix on this I'd be most interested. This would ultimately result in me buying two more of these cameras :o)
John Knight September 11th, 2008 03:16 PM
Hi Rodger,
Try this:
http://www.dvinfo.net//conf/sony-hvr...r-utility.html
Rodger Smith September 11th, 2008 03:52 PM
Originally Posted by John Knight (Post 933455)
I do believe that is the little animal I'm lookin for :o) Will give it a try this evening.
Jason LeFrense September 11th, 2008 06:11 PM
I use mpeg streamclip you can join your clips with this app and its free. I use for FCP because I still can't get FCP to recognize the sony CF cards.
Rodger Smith September 11th, 2008 10:43 PM
Wow, it works. The utility doesn't actually install it just runs from the .exe file. Thus I parked it in a My Documents folder and created a ShortCut for the Desktop.
It does load a lot slower than just copy/paste. And I mean a lot slower. Probably increases the transfer time by at least 2x. Just a guess but perhaps I'll run a test. Thought about maybe copy/paste the folder over first but then just messing with it for a couple minutes it's obvious that it A. looks for a drive and B. looks for a compact flash, not just data. Also, word to the wise . . don't change the name of the folder that's on the CF from the camera, I did just for identity so I could load some more things onto the card to transfer to that computer and the utility could not find the card/file at all . . the file has to be named Video and on a Compact Flash and on a drive letter. Wow. So, guessing I couldn't creat a partition for off loading and transferring cuz it probably is going to look for CF. Oh well, at least I gotz maself one big ole file :o)
