-   Sony NXCAM / AVCHD Camcorders (https://www.dvinfo.net/forum/sony-nxcam-avchd-camcorders/)
-   -   AX2000 Rainbow effect in viewfinder (https://www.dvinfo.net/forum/sony-nxcam-avchd-camcorders/486805-ax2000-rainbow-effect-viewfinder.html)
Sebastian Alvarez November 1st, 2010 07:57 AM
Originally Posted by Bob Hart (Post 1584009)
Sony perhaps should have upfront made it plain that the particular design has a characteristic, which if observed, is "normal" in an easily found disclaimer statement in the promotional flyers,
It is a bit like "rolling shutter" and CMOS sensors. The consumer becomes the crash-test dummy owner of a product which cannot be returned because it is performing to specification.
At the price points, people will accept that consumer-prosumer gear will not perform at the level of a Panavision Genesis. However people also like to be able to make informed decisions.
Bob,
of course Sony should have put a warning about that, or even a better idea, not use that technology at all. Rolling shutter is annoying as well, but sometimes there are ways to avoid its side effects (although beats me why they moved away from CCDs). With this, you're screwed, unless you never blink (in which case you wouldn't be human) and you never pan or tilt the camera.
That's my biggest problem there. If this was a defect inherent to consumer and prosumer gear, I wouldn't be so upset, but I haven't seen this in my entire life even in the cheapest consumer MiniDV camcorders that you buy at Walmart, or even in my Panasonic HMC40, which you would say it's a prosumer camera. So why would Sony use this obviously bad technology when there are other technologies to use in viewfinders that wouldn't cause a problem to anybody whatsoever?
