can fs100 do time-lapse?
i thought i read somewhere that someone was bashing the fs100 because it didn't have a dedicated time-lapse feature.
can the fs100 do time-lapse? thanks in advance. be well rob smalltalk productions |
Re: can fs100 do time-lapse?
As far as I know, it will do 1 frame per second, as part of its S&Q. But it cant go lower then that. I've heard of cameras that can go down to 1 frame a day if you wanted. So it can do timelapse, but there isn't great control.
FS100 Timelapse, Tokina 11-16 f2.8 F-mount, MTF Adaptor - Sony NEX-FS100 Super 35mm User Group on Vimeo http://m.youtube.com/index?desktop_u...?v=nkv9VEgeTe8 http://m.youtube.com/index?desktop_u...?v=56DrIFHHQw0 |
There is a misleading/'marketing' video which is on Youtube which
may be the basis of these claims. This is a video produced by Panasonic to promote the AF100. In it, they talk about '50 additional features that the AF100 has, that the FS100 does NOT have.' Some of them are misleading. For example, one of the claimed features of the AF100 that the FS100 is lacking is 'interval recording'. Now, I'm not sure how they decided this, as the FS100 certainly HAS interval recording. The AF100 has more 'variable frame rates' but the FS100 can certainly do 'interval recording'. Your options may be more limited, but the 1fps stuff is pretty much the standard for timelapse, although as others pointed out, there may times you want to use something different like 1 frame per hour.....which the AF100 doesn't do either. Some of the claims on the video are just a blatant falsehood, for example, another claimed 'advantage' the AF100 has over the FS100 is a 'speaker'. As an owner of the FS100, I can tell you the FS100 has this 'feature' as well, unless I just got a 'special' FS100. There are a few more like 'zoom position indicator' and so on, which they claim the FS100 doesn't have, but in fact, it does. So bottom line is, there is truth, lies, and marketing. Don't always believe that the last one is totally either one of the other two.....it usually falls somewhere between. |
| All times are GMT -6. The time now is 08:20 AM. |
