-   Sony NXCAM NEX-FS100 CineAlta (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/)
-   -   LA-EA1 and Sal1650 lens (https://www.dvinfo.net/forum/sony-nxcam-nex-fs100-cinealta/509663-la-ea1-sal1650-lens.html)
Piotr Wozniacki August 4th, 2012 07:22 AM
Re: LA-EA1 and Sal1650 lens
Originally Posted by Chris Joy (Post 1746881)
What about auto ISO?
Hush :) Most of us FS100 users use it in auto mode sometimes, but few are ready to admit :)
Derran Rootring August 4th, 2012 09:16 AM
Haha, I'm ready to admit I've tried it when using the Tokina lens and Novoflex adapter on the Steadicam, but somehow it doesn't feel right. :)
Piotr Wozniacki August 5th, 2012 05:39 AM
Well, I guess that while making their decision on ND filtering NOT to be built-in the FS100 camera, Sony's engineers assumed two things:
- many of FS100 users would be coming from the DSLR market
- most of non-NEX lenses to be used with the FS100 would be photo lenses
Now - in still photography, ISO (gain) just like shutter speed are as good exposure-controlling tools as the aperture and external ND filters are. It's only video which - especially when made with the elusive "cinematic look" in mind - requires constant (manually set) shutter speed, and (to a lesser degree) ISO/gain. The reason being obvious: when making 24-60 frames per seconds, and for a huge number of seconds in a row, we should make the "look" of all those consecutive frames as consistent as only possible, as well as the cadence (or movement sensation) pretty constant.
But, let's face it: with the FS100 camera which is virtually noise-free even at high gain/ISO settings, fixed gain within a take is not such an important factor any more. And as for the shutter speed, well...this is even more embarrassing to admit than auto-ISO, but many of us do compensate for the lack of internal ND-filtering with the shutter speed varying considerably from scene to scene, or even used in auto mode :)
And I must tell you that - as much a pixel-peeping measurebator as I am - I found I can get away with it more often than not... Of course, in a fully controlled environment I will always go with the 180 deg shutter as per the book, using the arsenal of my matte box/screwed-on fixed or variable types of ND filters. Similarly, I'll use lighting to avoid using gain at all...
But in run&gun, or stabilizer, kind of shooting? Yes - I do admit: it often happens that I'm using the ISO and/or shutter speed in auto mode! So far, none of my clients ever noticed :)
PS. I'd add that even in some controlled circumstances, e.g. when I'm after those "beauty shots" with shallow DOF, I'd open up and fix the aperture rather than anything else!
Chris Joy August 6th, 2012 07:31 AM
The ISO levels on the FS are so clean throughout most of the range, I don't have any problem using auto ISO and a vari-ND filter to control exposure as much as aperture. Unless going for a specific look I usually don't mess with the shutter speed. I shoot 30 & 60p because I haven't been able to get 24p looking smooth enough on the FS, it also helps to lower the exposure a bit when shooting at large apertures since the base ISO is so stinkin' high on the FS.
