50i or 60i setting help please
Why SONY FS700 has only 25 fps and 50 fps setting option in Europe (PAL 50i)? Every cheap photo camera as Nicon, Canon, atc. have 24, 25, 30, 60 fps possibility even in EU, why not FS700? What is the reason?
What is the difference between 24 nad 25 fps shooting (which is possible only in USA)? What happenes if I set the camera to 60i (NTSC) in Europe? I will also appreciate links to more detailed explanation. |
Re: 50i or 60i setting help please
You can switch between European frame rates (25, 50) and NTSC/American frame rates (24, 30 - actually 29.97, and 60 - actually 59.98 or thereabouts).
It's good to have the 'frames per second' and the local supply of electricity match up - so shooting 24 fps in Europe with a 1/48th shutter speed can make some lighting 'pulse' a little. However, if you're shooting for the web, most (almost all) computers have screens that refresh every 60th of a second, so if you shoot 24, 25 or 50 fps for computer display, it won't be as smooth as shooting 30 or 60 fps. But if you want to take an NTSC production and show it on European TV, 29.97 sucks. 24fps can be tweaked to 25fps with a little work on the audio. Sony are trying to 'protect the innocent' - don't shoot 25fps in the states, don't think you can get away with 29.97 in France unless you carefully check your lighting. So there's this big MF switch - 'do you want to shoot NTSC or PAL? If you don't know, we'll limit your choices so things don't screw up.' Yes, you can shoot 29.97 in Europe - I do this a lot, and there's good reason to do so. Maybe more so in the future. You can shoot 25fps in the States, but watch out for fluorescent lighitng, which will pulse. You can shoot 24fps but you must obey the cine rules for camera movement to avoid judder. And so on. You really can do anything, but you have to jump through those 'are you sure, because it could look crap' hoops. |
Whoah. Just caught a huge issue with your Title - INTERLACED?
You're shooting INTERLACED? Why? Interlacing is for old-school Cathode Ray Tube monitors - dead dinosaurs of the display world. If you interlace your video, edit it, then output it for use on computers, or dumb video systems, you are in for a truck load of hurt. You should be shooting HD in Progressive mode. Why? If you shoot in 1080i50/60 (interlaced), all motion will have each virtual frame split so all the odd lines are from the first part, the even lines from the second part, of your individual frame. Anything (ANYTHING) that moves will be recorded with godawful mouse-teeth edges that contain so much detail that they will steal bandwidth from your picture quality in order to render the even/odd mismatched lines accurately. If you SCALE that image onto a 720p monitor (or any PC laptop screen quite frankly), those mouseteeth edges get blocky and 'fugly' (google it). Horrible. So, you have to 'de-interlace' - most screens do this, and simply throw away every other line. So your 1080 HD image is now composed of 540 lines vertically. That's pretty much SD. Or... It does some expensive image processing and loses 25% of the resolution - so your 1080i image is actually displayed at 768 lines, which is so close to 720p that you may as well have shot in 720p in the first place. Interlace is a hideous nasty cheat that made TV work in its infancy. There are very specific reasons why broadcast HD TV is using 1080i, but material must be shot at 1080psf, and only credit rolls are mandatorily created at 1080i because the broadcast world is moving to 1080p50/60 and there's not quite enough bandwidth on the planet (yet) to make it work. It will be soon. And if that paragraph didn't make any sense, please - pretty please with sugar on top - shoot progressive. :-) |
thank you very much
Thank you very much! Not interlaced - there is no reason to lower the quality. 50i or 60i was ment 50hz or 60hz. My question was not about interlaced or progressive but about PAL/NTSC setting and shooting possibilities. DSLR film makers set their cameras to 24 fps in EU but it is not possible on FS700, I also wanted to know the difference
If we shoot 50p for sport it's usually for slo-mo in post but in the program it gets rendered out to good old 'i' Chris Young CYV Productions Sydney |
If your issue is with that last aspect ( having to use different cards for 25p and 24p shooting), then I agree. It's a major pain in the bum. I'd like it to be fixed in the firmware update, by I doubt it will be as I don't believe Sony really listen to everyday users, just the select few who they deem to be 'thought leaders' or whatever the hell the term is. |
thank you!
When I know my audience will be web/computer screen based, I'm beginning to favour 29.97/30 origination even in PAL-land. Just watch those screens and Fluorescents. |
A big part of the reason for the need to switch between PAL and NTSC area is due to playback and monitoring. To playback/monitor 24p (23.976p) the camera needs to be in NTSC area mode as the camera output must operate at 60i or 30p to correctly play back 24p material to the many monitors and TV sets. 24p is normally played back as 30p/60i with "Pull Up" padding frames/fields added to get from 24fps to 30fps. While you can playback/monitor at 24fps without pull-up a lot of devices don't accept this as a standard signal, instead needing 30fps.
As there is no formal standard to play back 24p within the PAL (or more correctly 25fps) system, if you shoot at 24fps to play it back or monitor it you would need to switch the output to NTSC mode to play/monitor your footage with most TV's and monitors, hence the need to set the camera to the correct base frame rate (25fps or 30fps, PAL or NTSC area). Cheap cameras and DSLR's don't care about proper standards, they just tend to output everything wrapped up in a 60i stream. |
If you'd looked at a certain large sporting event this summer, you'd have seen a great deal of programming originating as 1080i/25........ :-) When the recent standards were being set for HD transmission, "50 images per second" meant either 720p/50 (when you got progressive frames) or 1080i/25 (when you got interlaced fields). And one of the reasons for most stations going with 1080i/25 was that it directly gave "smooth motion" for news, sport, but (via psf, as you say) could also carry 1080p/25 for such as drama. If they had gone with 720p/50, it wouldn't have been too bad for such as sport, etc but would have been the worst of all worlds when "film look" was specified - effectively 720p/25. Yes, 1080p/50 will make increasing sense for acquisition, and can be used to derive equally good 1080i/25 or 1080p/25 as appropriate. Unfortunately it's not in the spec of current home HD receivers, so forget about it for transmission to home for the foreseeable future. |
Thanks all for your soothing words over 50i.
A couple of points I'd like to raise in my defence: 1) BBC has always said that it's the intention to broadcast HD in 1080p50 - but in the interrim, things are being broadcast at 50i to keep compatibility. So, all material is shot in either 1080p50 or 1080psf25 (eww, about to be spanked by the lurkers for not saying 50psf - but you know what I mean), and it's only credit rolls that happen in 1080i50 - because anything else looks rubbish. My 'mock shock & horror' was only to suggest that if you own an FS100/700, its main party trick is to film in 50p, not 50i. Since the Olympics, I've been on 3 assignments that stipulated 50/60p at 1080 - all of them corporate, BTW. NB: regarding 1080i/25 (or whatever we call the 25psf output of the new C100), I predict we shall continue to hear tears before bedtime for quite a while yet. |
usually it doesn't ask a lot to switch a camera from ntsc to pal, On some caemra, it is just a matter of flipping a bit in memory.
For some low cost camera, they cut corners by skipping few extra component that would be useless for most users. But the real reason is probably purely commercial. Cameras are cheaper on some place (especially in Noth Amerac, than in europe or Australia for example. So it is a way to cut grey market, Other camera makers just use serial number to sort region. Sony plays a strange game, because they often release a camera with 2 models , one for consumer and another for pro market, the only difference being the XLR plugs and the capacity to shoot 24 and 50/60. |
There was, of course, the JVC trick of shooting XDCAM in QuickTime wrappers - was that what you were thinking of? |
It's a shame if Canon have gone over to AVCHD too - lord knows what they were thinking of when they came up with that standard, as it certainly wasn't pro filmamkers. Must have been the crack talking... |
AVCHD is an industry standard way of encoding using H264 and includes very specific frame sizes and frame rates and codec levels, as well as standard wrappers like mts which also contain metadata about the file. H264 in a quick time wrapper can be anything, any size, any bit rate any level and this can lead to poor quality decoding as the decoder may not be able to determine the correct codec level or which of the many H264 coding enhancements have been used. All the AVC versions of H264 are designed for video camera applications with the ability to use high level features like uncompressed PCM audio and/or Intra frame encoding that are not included in normal H264. AVC Includes AVCHD, AVC Intra and the new XAVC which goes up to 4K at high frame and bit rates not normally part of the H264 specifications.
SEE, see!!! This is why it's rubbish. It's too complicated. I used to like it when you could fix a car with a pair of nylon stockings, now everything needs to be plugged in to a sodding computer.
This stupid database system causes no end of trouble. Why couldn't you just include all the relevant data for codec, frame size etc within the video file itself? Then you wouldn't have the problem where one dodgy video file messes up a whole card. I've had clients call up to say they can't import a card because the folder structure is messed up - so they've had to buy Clipwrap to sort it! Then, the other day, my FS700 got itself in a right old funk: every time I put it in slow-mo it would just freeze. I couldn't even turn it off without pulling the battery. Drove me mad that did. Eventually managed to work out a combination of settings that wouldn't freeze, but was forced to record the slo mo in 60p rather than 24p like I wanted. Grrr. Stupid computers. Bring back film I say, I could understand all those cogs. |
I remember being asked about a system based on a Focus "Firestore" being evaluated, with an eye to easier on set logging. The proposal was for a basic Firestore type hard drive recorder to be wireless fed with logging text from a laptop, the logging data to be incorporated into the video file. The more I thought about it, the more potential problems came up. What about text typed between shots? Should that be embedded in the preceeding or following file? If the preceeding (which would be more logical) then how could that be implemented? How could the reliability of the text be guaranteed? Compatability of these files within other equipment? Frankly, it was an example of taking the wrong approach to a problem. Far better to do it the other way round. Form local log files on the PC, and send data from camera to PC (not the other way round) - timecode and possibly whether or not the camera was running. The only extra hardware then needed was a one-way timecode link, together with software to embed it into the text. Simple (hence cheap) and better than the previously proposed system - the log files remain separate (albeit linked) to the video/audio and small in size, hence easily e-mailed etc separate from the main video/audio. It would also be quite resilent to loss of the camera/logging link if continuous timecode was being recorded, as long as the receiver would freerun in absence of signal. Sorry for the digression, but as basic principle it's a good idea to embed some basic metadata in the same file as video/audio, but also a good idea to keep much separate - as long as the two are properly linked! |
| All times are GMT -6. The time now is 05:06 PM. |
