-   Sony VX2100 / PD170 / PDX10 Companion (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/)
-   -   Get Your Super-Battery for DSR-250 (https://www.dvinfo.net/forum/sony-vx2100-pd170-pdx10-companion/23035-get-your-super-battery-dsr-250-a.html)
Law Tyler March 16th, 2004 06:25 PM
Well, I have both the VX-2100 and DSR-250, always wish there is a battery that would go just as long as the 960 for the VX-2100 on the DSR-250, so that I never have to worry about battery running out (happened with the regular BP-L40).
I just got it!
The Sony BP-M100. NiMH instead of Li.
Some of us talked about it here, but nobody seems to own one.
This baby is 3 times the weight of the regular BP-L40, believe it when it imply it can go 8 hours or longer. 20% taller and 50% thicker, boy, this is a battery on steriod.
This thing is going to be on my DSR-250 all the time, from now on.
Too bad I just had a full day with my new BP-L60 for a 6-hour wedding (not taping all the time), and it worked out fine, used only 50% of the juice, according to the battery indicator.
But the new battery has much more weight, better counter-balance the camera, and NEVER run out before I do, ha, ha.
I rather have one of these than two of the standard BP-L40.
Jun Galinato March 16th, 2004 11:21 PM
I use Anton Bauer Hytron 120, more than 8 hours without using the LCD.
Law Tyler March 17th, 2004 07:02 AM
Good for you.
I never think of using the other brands as they seem to always require some kind of adaptor. If I am going to have several shoulder-mount cameras, then fine, worth the effort, but I probably will just have one in the long run.
I wouldn't touch NiCd also.
Now with the BL-P60 and BL-M100, I am set to do two weddings a day without worrying about batteries.
I had a couple incidents whereby the BL-P40 run out on me in the midst of an event. They should just give people the BL-M100 as the standard package instead of two BL-P40's.
