Waiting for VX3000
I want true 16:9 plus low light capability plus low smear and no camera seems to provide these things at the moment in the prosumer range. I thought the PDX10 or MX500 might but they seem to have fatal tradeoffs because of their smaller CCD's.
I might wait for the next VX version, hope it's not too long Jim |
You may have to wait until you can afford a DSR-570WS.
All of those things are mutually incompatible in low-end cameras exactly because they require larger CCDs. And lens. As the lens gets larger to support larger CCDs, they get more expensive. Really fast I'm amazed that the PD-150/VX-2000 have lower noise in really low-light conditions than the DSR-300. |
Thanks Mike,
I already own a DSR500WS and it is a great cam. I just wanted a backup/handheld cam to compliment my existing unit. We are shooting 16:9 fairly extensively so this feature is important as is low light and low smear. Have we hit the technology wall? I hope not. The VX uses larger chips than the MX500/0 and PDX10 so the next model may be able to incorporate higher density chips of the same size as the existing VX2000 chips that will allow for true 16:9 with comparably reduced smear and lower light capability. I reckon this would be a great cam that would completely dominate the prosumer market if it's possible. Jim |
The difficult part is the higher chip-count for 16:9. Requires a different lens, etc. Which would no-doubt raise the price.
It will be interesting. If you are shooting a DSR-500 now, you aren't doing many weddings and other small stuff. What is your target audience/market? |
Mike I provide imaging services in a research lab which has demand for video at all levels from PowerPoint to web to corporate to broadcast. Great job!
Jim |
You might want to take a look at the camera head systems that can do 16:9. You know, the ones that are a small box with a lens attached.
I think you could feed a portable VTR from one of those and have even more maneuver room than with a PD-150. Or even a lipstick camera. I have one that was formerly used for a microscope. Changed the lens and it is great for use in limited space applications. |
| All times are GMT -6. The time now is 08:20 PM. |
