Omega Broadcast: F55 Swish Pans
This footage is 50mb/sec. Should be 422 8bit, 1920 x 1080 59.94. It shjould be like PMW-100/160/200 footage in terms of the codec. The F55 is touting a global shutter. Ingest and see for yourself.
We are taking footage / test requests. The R5 recorder (AXSR5) as well as media (AXS512S24), This is a 90mb zipped file of the SXS card contents. http://www.mediafire.com/?2c99bvpmxbe9lx0 |
Re: Omega Broadcast: F55 Swish Pans
Can we get samples at higher shutter speeds, please? The motion blur is making it tough in some of the test shots to determine skew. The shots with higher mm lens counts is very tough to determine skew because of the blur.
A spinning wheel with lines might also be a good test for skew. Also, flash photography is what we'd like to see to see if there's flash banding. Edit: Went to a local dealer with the F55, set the shutter angle to 5.6 degrees, Set it to XAVC 1080p60, 18db gain, and surely enough, freezing the video during a rapid pan does not exhibit rolling shutter. However, I believe the OLED displays I saw the footage on during motion exhibited rolling scanning. When I froze the recording, the straight lines were indeed straight. |
A desk fan would reveal rolling shutter. The fan blades will be distorted if there is any..... which there isn't on the F55 as each photosite on the sensor has a separate memory cell into which the exposed frame is read so that the read out scan can take place in the background, thus eliminating the skew. The sensor, although CMOS operates and is read much more like a CCD. The memory cells take up space on the sensor which is why it's less sensitive than the F5.
We got out a fan and attached a focus chart to it. There are four clips, shutter speed 4000, 2000, 500 and 120. This footage was recorded 50mb/sec to a SBS-16G1B (SXS-1) card. It should be 422 8bit, 1920 x 1080 59.94 and like PMW-100/160/200 footage in terms of the codec. HyperGamma 7, 3200k, ISO8000.
This is a 580mb zipped file of the SXS card contents. http://www.mediafire.com/?q3bx26p23tr0y3f |
Re: Omega Broadcast: Shutter test with fan
The video is on youtube now. It's easier to watch there than downloading and ingesting the footage yourself.
you will buy an f55, look into my eyes, you will buy an f55 HA!
1st clip proves without a doubt it's a global shutter. The later clips are overexposed so it's harder to tell until the wheel spins down.
A side by side comparison with an F3 rolling alongside the F55 can prove it further. Add photography flash to the same test, and the results will be even more definitive. |
Your photo flashes in footage. As requested.
This is S-Log2, ISO 1250, 1/48 shutter, 3200 degrees kelvin. The second shot has camera flashes so you can see how it handles that interference. This camera may not be used to shoot weddings, where camera flashes are prevalent, but red carpet premieres and other activities will have flashes. There is a black, white and grey card in the shot. It was recorded to a SXS Pro+ card and the file is 275mb. http://www.mediafire.com/?fjakq2fn4agawzw Also - there is some discussion on this here: Re: F5/F55 frame grabs and footage thread - Sony Community and here: XDCAM-USER.COM • View topic - Omega Broadcast: F55 Swish Pans |
Ok. Here is all the footage in one place and explained.
This footage is courtesy of Omega Broadcast. We are a stocking Sony F5 and F55 dealer. 817 West Howard Lane Austin, Texas 78753 Phone: (512) 251-7778 Email: sales@omegabroadcast.com Omega offers New, Used, BSTOCK, and Demo video equipment Sales, Rentals, and Production Services. Our sales and rental inventory includes a wide variety of broadcast video, lighting, grip, and audio equipment. Production services range from video production, studio facilities, editing, duplication and format conversion. Omega is an authorized dealer for Sony, Panasonic, JVC and Canon, as well as many other Professional Video and Audio Manufacturers. >>> File name: OmegaBroadcast_F55_03012013_testOriginalMedia We got out out a fan and attached a focus chart to it. There are four clips, shutter speed 4000, 2000, 500 and 120. This footage was recorded 50mb/sec to a SBS-16G1B (SXS-1) card. It should be 422 8bit, 1920 x 1080 59.94 and like PMW-100/160/200 footage in terms of the codec. HyperGamma 7, 3200k, ISO8000. This is a 580mb zipped file of the SXS card contents: http://www.mediafire.com/?q3bx26p23tr0y3f >>> File name: OmegaBroadcast_F55_SLog2_SGamut4kOriginalMedia This is S-Log2, ISO 1250, 1/48 shutter, 3200 degrees kelvin. Lens is the Fujinon 19-90. The second shot has camera flashes so you can see how it handles that interference. Someone on the forum DVinfo.net requested this. This camera may not be used to shoot weddings, where camera flashes are prevalent, but red carpet premieres and other activities will have flashes. There is a black, white and grey card in the shot. It was recorded to a SXS Pro+ card and the file is 275mb: http://www.mediafire.com/?fjakq2fn4agawzw >>> File name: OmegaBroadcast_F55_4kRawClipsOriginalMedia 4K RAW from the R5 recorder, 2GB. This is a shot of a staffer with the white, black and gray card and then some swish panning. It is one shot approximately 20 second long: http://www.mediafire.com/?an486t2if9h1vvr >>> File name: OmegaBroadcast_F55_3_4kClipsOriginalMedia Got the SXS Pro + card and shot 4K 23.98, HG7, 1250 ISO, 48 shutter and 5500 degrees kelvin. There are 3 five second shots here. All outdoors, shots are medium, close and wide. It is 458MB: http://www.mediafire.com/?loccm7mrsis5183 >>> File name: OmegaBroadcast_Cineshops_F55_SwishPansOriginalMedia F55 Swish Pans. This footage is 50mb/sec. Should be 422 8bit, 1920 x 1080 59.94. It should be like PMW-100/160/200 footage in terms of the codec. The F55 is touting a global shutter. Ingest and see for yourself. Lens is the Fujinon 19-90 wide and then zoomed in. This is a 90mb zipped file of the SXS card contents: http://www.mediafire.com/?2c99bvpmxbe9lx0 Shutter test with a spinning focus chart is posted to youtube. Shutter test of the Sony F55 - YouTube |
| All times are GMT -6. The time now is 11:12 AM. |
