Alternative to Clip viewer?
After reading the manual to Clip viewer I have not been able to figure out a way to play all the clips on a card or in a folder in sequence. I would like to be able to hit play, lean back and watch the whole "tape" of recordings after a days shoot.
Now - has anyone found a good way of doing this without importing into editing software? The only way I have come close is by dragging all of the mp4-files to VLC-player but then I don't get any audio. |
Playing all the clips
David Schmerin www.GotFootageHD.com |
So if you play back out of the camera, the component video outs don't carry a signal?
I was going to suggest playing back out of the camera to a consumer DVD recorder using component video out. EDIT: I just checked the manual and the component video outs (and composite) work during playback. I believe I also read that if you play the first clip, the second one plays and so on to the end of the tape. I guess you would have to get a headphone to RCA cable to run audio out of the camera. So until Sony makes an SxS player (like Panny's P2 field player) then that's how it's done. |
Thank you guys! I am aware of all the possibilities of playback from the camera (yes Andrew, the component output works as well as SDI).
What I am talking about is playback of clips already dumped to a harddrive. Apart from the very latest recorded material all of my footage will be on harddrive. Also, hooking up the camera for playback is not a good every day solution. Using the computer for playback is also for me the only way to watch the clips att full quality on my 24" 1920x1200 LCD-screen. Although I can connect it through component as well that does not give me image quality near that of computer playback. Today I realised I can also use Zoom Player to play back mp4-clips if I change the extension to .ts but zoom player does not give me audio either. Does anyone know if the audio actually is embedded in the mp4-file or if it is stored in a separate file? |
The way I do it is :
-copy the files (MP4 + data) to an external hard drive (from a MacBookPro 17") - drop the MP4 file to VLC (or the the VLC playlist to have them all the way to the end) (get VLC here : http://www.videolan.org/ ). You won't get any sound ad VLC does not know how to get it from the MP4 file. - use FFMPEG to get the video (mpeg2) and audio (wave) out of the MP4 file, then see the movie. You will need twice the disk space though... I'm in the process of writing a script (sheel or applescript) to automaticaly dump the files from the SxS to a harddrive, and maybe extract the files to a .mov with both video and sound. Maybe also generate a playlist file and open it in VLC... I'll post when it's done. |
What I am looking for is some kind of player that lets you build a playlist and that recognizes both video and audio. Maybe this is something that the geeks involved in the HTPC-world can answer? There is an application called graph edit that I don't really get that is supposed to let you analyse and choose codecs for both audio and video in a clip. |
Buy SpeedEdit v1.5 from Newtek for a few hundred euro's.
Drop the clip on the storyboard or timeline and hit spacebar to start playback. It will playback both mxf and mp4 files, including audio. Converting with FFMPEG first (to any high bandwidth non-long-GOP format) will give even better results. VLC player will playback both file formats on the fly. FFMPEG is great for conversion to uncompressed or (lossless) compressed formats. VirtualDub is great for upsampling from 4:2:0 to 4:4:4 colorspace. Great for chroma keying, color timing or mastering. AviSynth is great for converting interlaced PAL or NTSC to progressive double frame-rate (50 fps PAL and 59,94 fps NTSC) to make it more compatible with 1080p50, 720p50, 1080p60, 720p60. |
Ola try mplayer. I can't try it now its Tiger only in OSX but there is win32 verisons at:
http://www.mplayerhq.hu/ |
Thank you! |
Ola, does the program allow for say output through a Black Magic intensity card so we can play to a TV
Thanks Paul |
/ola |
http://www.fa.uni-tuebingen.de/dmx4m...et_language=en |
| All times are GMT -6. The time now is 04:16 PM. |
