-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Do I need a card reader (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/117006-do-i-need-card-reader.html)
Buba Kastorski March 14th, 2008 07:03 PM
Hi guis, quick question to lucky EX1 owners, do I need a card reader , or there is straight download fom SxS to hard drive via ilink or USB available?
Many thanks!
Jason Bodnar March 14th, 2008 07:20 PM
You do not need a card reader...You can dump the footage by way of USB directly from the camera, if you use iLink it will only be SP footage. The best way is to have a Laptop with Express card slot then you can just transfer it this way which is the fastest. I may pic up a card reader at some point to have in the studio but a price drop would need to happen before I order one...That is if they ever become available.
Steven Thomas March 14th, 2008 07:21 PM
When you plug the USB into your computer, the EX1 memory cards will show up as drives on your computer. Just like a thumb drive.
The reader is expensive, but I really like using it. It's a lot easier to deal with just the cards. You don't have to grab you camera just to view your clips.
Jon Carlson March 14th, 2008 08:01 PM
USB is slower to transfer than the Express34 slot. If you have a laptop with that slot, it's your best bet for transfer.
Buba Kastorski March 14th, 2008 08:17 PM
Many many many thanks guys,
sure xspress card slot on laptop would be nice, but mine doesn't have it , just a few months back when I bought it, didn't think hard enough :-(
thanks again
Dave Menard March 14th, 2008 08:35 PM
I purchased the card reader after the 5th time I picked up the camera forgetting it was still plugged into my G5 tower. I destroyed the USB jack on the camera in this manner.
$250 well spent.
Dan Wells March 15th, 2008 10:27 PM
I'm planning to buy the card reader right away, because I don't like the flimsy cover on the USB port - it looks like it will break off immediately. Why can't Sony look at the rubber port covers on digital SLRs in the same price range as the EX1, and put something similar on their $6000+ camera? For that matter, why is a camera in this price range using a USB data port instead of FW800? The only FireWire port on the EX1 is the FW400 port used for video out, which they haven't enabled for data transfer. Even stranger to me is the fact that the only card reader they offer is ALSO USB only... With these superfast cards, shouldn't they be interested in putting out a faster card reader? I would assume that most of us edit on a desktop or workstation (although possibly using a laptop for field transfers), and that very few people's desktops have ExpressCard slots... Am I wrong?
-Dan
Piotr Wozniacki March 16th, 2008 03:51 AM
Dan, you are absolutely right. I have already injured my USB port because of the complicated access; also it's not fast enough. Therefore I have found and ordered a reader like this:
http://www.synchrotech.com/products-...-drive_03.html
I do have an ExpressCard reader on my laptop, but used to download through USB to the main editing PC, anyway... What a hassle!
I'll report how the reader is performing soon.
Alister Chapman March 16th, 2008 06:09 AM
Ah-ha, so I'm not the only one to have damaged the USB port because you can't see a cable plugged into it. Picked up the EX forgetting it was plugged in and broke the USB socket.
Piotr Wozniacki March 16th, 2008 06:39 AM
No, you're not alone in this, Alister :). See here:
http://www.dvinfo.net/conf/showthread.php?t=116444
...if you care to scroll down a bit, you will even see the damage I've done (though for quite another reason).
Buba Kastorski March 16th, 2008 12:44 PM
wow, for sure that's gonna happen to me sooner or later;
I wonder if this
http://www.synchrotech.com/product-u...t_adapter.html
would be cheaper solution, compare to original one, and it doesn't need power adapter,
Dan Wells March 16th, 2008 01:11 PM
That won't work with the SxS cards, because it only passes the USB signal through. ExpressCards actually have two different signal types - USB and PCI Express. The fast ones (like SxS cards) use the PCI Express signal, while a slow card can use the USB signal. Of course, if you're building a USB card reader, it's awfully tempting to only read the USB signal, because you don't have to convert anything - simply wire the USB lines on the card straight to the same pins on the computer's USB port - cheap, simple and doesn't take any power. If you want to read high-speed Express cards, though, you have to convert the PCI Express coming off the card to USB (or whatever else your reader wants - I'd love to see FW800 or eSata) , because the fast cards don't have anything hooked up to the USB signal wires - they expect to be read by a PCI Express controller.
The Sony card reader is actually a somewhat complicated little box containing a PCI Express to USB bridge, which explains its need for power, and at least part of its price. It still shouldn't be as expensive as it is, though - removable hard drive chassis with a SATA to FireWire bridge sell for about $100 (fixed hard drive enclosures aren't really a fair comparison, because, although they contain a bridge, they aren't designed to have things plugged and unplugged from them). The Sony reader should probably cost somewhere between $75 and $125, but they know they've got us over a barrel (and they aren't making very many of them, which always makes things more expensive).
-Dan
Craig Seeman March 16th, 2008 05:53 PM
These might be closer
http://www.synchrotech.com/products-...-drive_02.html
They even link to SxS driver.
Apparently the issue is on Mac one MUST reboot the computer to recognize the device after changing the card.
On Windows on has to find new hardware after changing card.
They do mention, regarding the 2nd device, that they are working on resolving Mac issues. The first device is more attractive as a reader though.
Dan Wells March 16th, 2008 10:13 PM
This will certainly work - those of us on the Mac have to deal with the fact that it's an internal device that needs access to the front of the computer to insert cards, which will require modification to the case of a Mac Pro - the simplest way would probably be to use the second optical bay (the one most of have marked in our heads "reserved for Blu-Ray burner when Apple gets around to updating DVD Studio Pro"), and either remove/stick permanently in the down position the aluminum door to that bay or Dremel out a hole in the door. Someone really creative could use one of the INTERNAL hard drive bays and Dremel the access port in the side panel of the Mac Pro! Why can't these people make an external version of this thing - all it would take is rerouting the cable to the back of the interface card and tossing the reader in an external hard drive housing?
It shouldn't be a problem for most PCs, since almost all PCs have an accessible bay left (and those that don't tend to have a bay taken up by something obsolete like a CD-ROM drive or a 3.5 inch floppy drive) - this thing is 3.5 inches, but they sell a 5.25 inch adapter on the same page.
The unit they make without a drive bay component solves one problem on the Mac, but creates another. It puts the slot on the BACK of the Mac Pro - how many of us have our 65 pound Macs set up so the back is easy to reach? I know that mine is under a desk with a couple of hard drives on top of it, and I suspect that's about average. Before you think "I'll just turn it around permanently", imagine reaching the DVD burner with the computer mounted backwards. The slot version just about commits users to have the 2 foot deep computer placed in a strange position, taking up a lot of extra space, in order to have access to both the front and back panels.
Please, Steve Jobs, let us have a 3.5 inch bay without a door on the next Mac Pro - we'll promise not to put a floppy drive in it (legend has it that the exposed bays were removed from tower Macs to keep people from foiling Steve's dream of a floppy-free world). Most Mac Pros sell to photographers and videographers - both of whom would promptly put a media reader of some type (whether it was SxS, P2, Compact Flash or some combo device) in a spare bay. Barring an extra bay marring the sleek lines of the Mac, Apple could put a media reader in themselves, at least as an option - something that did ExpressCard (SxS), PC card (P2), CompactFlash and SD wouldn't be terribly hard to do, and it would get a lot of use.
-Dan
Piotr Wozniacki March 19th, 2008 08:59 AM
OK, so I have just installed the "PCI Express to ExpressCard 34|54 Drive
Read-Writer Front" device (see http://www.synchrotech.com/products-...drive_03.html). However, I'm disappointed that neither under Windows XP, nor Vista is the device hot-swappable with Sony SxS cards:(
Once I remove a card, upon another insertion it cannot be seen (Windows says I need to format it before use). I have to use Device Manager to manually UNINSTALL the device first, then SCAN FOR HARDWARE CHANGES each time after re-inserting an SxS card.
If somebody finds a way to automatically unmount/remount SxS cards, I'm all ears...
PS. I think I did saw a reference to some automation script for uninstalling/reinstalling a device, that can spare digging into the Control Panel each time.
John Hewat March 19th, 2008 06:17 PM
Originally Posted by Piotr Wozniacki (Post 844955)
... the "PCI Express to ExpressCard 34|54 Drive Read-Writer Front" device ... is the device hot-swappable with Sony SxS cards:
I think I could probably live with that. I much prefer the idea of it being inside the computer to being another peice of USB hardware sitting on the desk like the Sony one.
And it's substantially cheaper.
My only question Piotr about what you said is do you have to have the SxS card in the drive during start-up for it to be recognised? Or can you insert it whenever?
Robert M Wright March 19th, 2008 06:32 PM
One of these might be worth trying:
http://www.newegg.com/Product/Produc...e=Add-On+Cards
I don't have an EX1, but I believe those card readers should work with SxS cards. Should be full speed too.
Piotr Wozniacki March 20th, 2008 01:50 AM
Yep, I can live with it, John. And no, it's not necessary to boot with the card in - just insert it any time and use Device Manager to scan for hw changes.
Piotr Wozniacki March 20th, 2008 04:22 AM
After another thought, I tend to think the need for hardware scanning is not related to the Synchrotech device, but the Sony SxS driver implemenation. The reader is visible to the system all the time; the problem is that with an SxS card removal, Windows doesn't "refresh" the device which "thinks" it's still holding the card - therefore, when you re-insert even the same card (or another one - no difference), Windows gets lost and suggest formatting it before use... Only removing the device as a whole, and scanning for it again with the new card inserted, will make it accessible to Windows.
So, I guess this is another point on the update wishlist... But then again, with the laptop ExpressCard reader there is no such problem at all - you can "safely remove" an SxS card, and on iserting another it's properly visible to the system.
Piotr Wozniacki March 21st, 2008 04:43 AM
FWIW,
After installing SP1 over my Vista x64, the SxS driver causes system crashes and cannot be used at all. Has anyone managed to harness it?
Edit: I managed to solve the problem - not quite sure why, but downloading the same driver version (!!!) and re-installing it helped.
Bob Pascucci March 21st, 2008 09:36 AM
SxS card reader
Maybe I'm just being too simple here, but I just installed the card reader software on my (fairly old) office PC running Windows XP and I've not had any real difficulty swapping cards. The system seems to treat a card as any other disk in a removable-disk drive - if I change cards, all I have to do is "refresh" the card reader, and the files on the new card appear and are ready for use.
Piotr Wozniacki March 21st, 2008 09:38 AM
Bob, are you talking SxS cards? Or some other ExpressCards (presumably using USB)?
Bob Pascucci March 21st, 2008 10:26 AM
card reader
I'm talking SxS cards - the Sony card reader is connected via USB. Clips show up in the "source" panel of the card reader software (I'm using the version that came with the camera - I have not gone to the web to update it). Once I've finished transferring files from one card, I simply swap cards, click on the drive icon to be sure that's the active drive (just like you would in Windows Explorer) and then click "refresh" in the View menu. The clips on the new card appear and are ready for use.
Piotr Wozniacki March 21st, 2008 11:41 AM
Oh, you mean the Sony reader - yes, this one is hot-swappable, but only offers USB2.0 speed. The discussion here is about the PCIe->ExpressCard adapter/readers, that use much (several times) faster PCIe connectivity.
Michael H. Stevens March 21st, 2008 01:12 PM
Surely you either have or you need a current laptop for collecting fields data so use the built in express card reader.
Bill Ravens March 21st, 2008 01:15 PM
surely?
ohhh, puhleeeze!!
Michael H. Stevens March 21st, 2008 01:31 PM
Originally Posted by Bill Ravens (Post 846274)
surely?
ohhh, puhleeeze!!
Bill: Stop calling me Shirly.
