-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Missing Timecode....and "media needs to be restored" (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/122205-missing-timecode-media-needs-restored.html)
Benjamin Eckstein May 22nd, 2008 02:18 PM
I have been shooting this week with fellow DVinfo user Bill Parker on his documentary and we have run into our cards giving us the "Media Needs to be restored" display. I just did a search and people seemed to find it when dealing with offload to a computer via USB and the camera (which we aren't doing). It isn't a REAL problem in that when you say execute all the data appears, but what gives. I was using my cards in his cam and now I get it on my cam too with those cards.
Problem number 2.....maybe this is connected.....who knows. We shot an interview today and transferred footage in Clip Browser then when viewing clips in XDCAM transfer a few of the clips show no timecode, or halfway through the timecode display will just show dashes. On those clips the clip shows up with Part 1, Part 2, etc in the subclip window. Then when you import the clips into Final Cut the timecode appears, but.......what gives. Anybody seen this?
BE
Andrew Hollister May 22nd, 2008 11:00 PM
media needs to be restored...
if I remember correctly I got that message when I ejected the card improperly - I deleted clips and removed card before emptying trash?
Bill Parker May 23rd, 2008 04:09 AM
Just to follow up on what Ben said, the time code on our first clip started at 00:48:10:00 on the card and in the Clip Browser. In XDCAM Transfer, that same clip starts at 01:01:58:15. Has anyone run into this before? The camera was set to tc regen. There also appear to be gaps in the time code between clips. That shouldn't happen in tc regen, no?
Incidentally, I recently upgraded to XDCAM Transfer 2.7. I don't know if that has any bearing on anything.
Thanks.
Craig Seeman May 23rd, 2008 06:36 AM
What you describe with TC is something I saw in Transfer Tool 2.1 but not since. It seemed Transfer Tools was having problems with Clock Time Code as well as Drop Frame Time code. That's been fine for me in 2.5.1 and 2.7 though.
There was also an issue in 2.1 with 24 and 25fps material and certain types of Time Code (possibly also Clock Time at those frame rates). Those were fixed in 2.5.1 I believe.
When I get "Restore Media" on a given card, after Transfer, I Format rather than just Delete Clips on that card.
It does seem that 2.7 is slow in loading the time code. In List View it starts with dashes and they go down the list and become numbers.
I haven't seen any changes in time codes though. I do suspect there's been a change in how it looks at and loads time code though but I think that's a fix for previous TC issues.
Please list details about the TC you had it set to. Regen is a start but was it DF or NDF? What Frame Rate?
Bill Parker May 23rd, 2008 07:26 AM
We shot in 1080p, 24p - NDF. We both had clips that were missing time code in XDCAM transfer, but not in Clip Browser or in FCP. There was only one clip where XDCAM Transfer changed the time code that was on the original clip. I don't suppose it really matters because i can edit with it - it's just weird.
Daniel Weber May 23rd, 2008 08:43 AM
I had a strange one last weekend on a shoot.
In the middle of the shoot I got an error message telling me the camera couldn't write to the card any more. The card was almost empty.
I lost everything I had shot. I switched slots and got the message again.
I then formated the first card and the rest of the shoot went well.
I am scared of it happening again though.
I have gotten the repair message and it never harmed the footage.
It has only happened once though.
Daniel Weber
Bill Parker May 23rd, 2008 08:57 AM
Once is a lot.
