-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Power options: PAG batteries? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/123242-power-options-pag-batteries.html)
Piotr Wozniacki June 10th, 2008 02:36 AM
Originally Posted by Bruce Rawlings (Post 889610)
I will chase them next week. I offered to send them my charger cable but they wanted to do it properly and get a product that all could have easily.
Hi Bruce
Did you talk to PAG about the cable?
Roger Hagelaar June 10th, 2008 02:42 AM
Hey Bob, did you find those locally or did you need to order from O/S??
R.
John Peterson June 10th, 2008 05:59 AM
Originally Posted by Alex Dolgin (Post 890651)
You are almost there... you are correct that the amp hours do not change, but it is 7800mah@7.2V for the largest Sony L battery. So connecting 2 of them together gets you a 7800mah@14.4V battery. The U60 is only 4000mah@14.4V. Using 2 Sony L batteries, a camera will run almost 2x long as on the U60.
HTH
Thank you for correcting your error above claiming that the watt hours increase when two batteries are connected in series.
As far as your statement that the largest L-battery is 7800 mAh, the largest L battery (as I stated earlier) is the NP-F970. I am looking right at the back of one as we speak and it says 47.5 Wh which converts to 6600 mAh and not 7800 mAh as you stated. A quick check of the Sony website confirms this:
http://www.sonystyle.com/webapp/wcs/...0788&langId=-1
Sony does not list a higher capacity L battery than the NP-F970 unless you know of another one they don't list.
Wh = Ah x V
Ah = Wh / V
Thus 47.5 Wh / 7.2 V = 6.6 Ah To convert to mAh multiply by 1000 to get 6.6 x 1000 = 6600 mAh for the NP-F970.
As far as the mAh or Wh for one application (load) (camera) being directly comparable to another I disagree. The discharge characteristics are different for each application depending upon the load and the battery combined with it. That is why my BP-U60 lasts only four hours in my EX1 and my NP-F970 lasts eight to ten hours in my VX2000 with the LCD closed in both cases. Maybe you should test two if them in your voltage doubler hooked up to an EX1 before you make some of these claims.
John
Sebastien Thomas June 10th, 2008 06:42 AM
Originally Posted by Piotr Wozniacki (Post 889602)
Thanks Bruce - are you still in touch with them? Because if the only reason for not providing their customers with the right cable is the connector being difficult to get, with no other reasons for their batteries to not work properly with the EX1 DC-in - I guess I would be willing to cut the cable of my EX1 charger, fit it with XLR connectors, and use an XLR to PP90 adapter cable in order to plug it into my PAGlocks...
Did something like that some time ago :
http://www.lecentre.net/blog/archives/242
now I can power the EX1 from external 12v, like another power source, a battery or a car plug (turn off the EX1 when starting the car as the voltage can drop down so the camera turns off).
Bruce Rawlings June 10th, 2008 08:54 AM
Have just spoken to PAG. They now have cables with EX1 connectors in stock. I am using L95s and ZL50s with a V Lock PAG plate and cable with female XLR plug. My EX1 cable will be male XLR to EX1 connector. Do not know the price yet but you can contact PAG for a costing on your particular wants.
Piotr Wozniacki June 10th, 2008 09:10 AM
Thanks Bruce - what I need is PP90 - to - EX1, 1-m cable; hope they have it as well.
Alex Dolgin June 10th, 2008 11:46 AM
Wh = Ah x V
Ah = Wh / V
John
John, the last thing I wanted is to get into an argument with you. What I write here is factually true, you can verify that by reading up a bit more online or in the textbooks.
As far as the largest Sony battery, while Sony does not make 7800mah L batteries, some 3d party vendors do, like this Lenmar http://www.huntsphotoandvideo.com/de...ductid=LIS970P is listed at 7800mah. We actually tested this particular model, it truely delivers what promised. But the point here was not who makes the largest battery, the number I used was just for the reference to illustrate how math works here.
