-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Extending EX1's Component cable? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/133455-extending-ex1s-component-cable.html)
Alex Raskin September 18th, 2008 09:53 AM
I'd rather not use a fat 3-wire extension on RCA side, but instead extend the slim cable with proprietary Sony connector.
This is needed to be able to move the HD monitor with analog input farther from the camera itself.
Is there such thing as 6 or 10ft extension for EX1's Component out?
Gints Klimanis September 18th, 2008 12:35 PM
Haven't seen one. But I'm looking for a right angle adapter for that kind of connector the placement of the jack and the protruding wire interfere with handheld (well, shoulder mounted) operation. The manual calls it a component mini-D connector.
Leonard Levy September 18th, 2008 01:27 PM
You can buy 3 wire RCA extensions that are not heavy like the BNC's I see around - 15 or 25'.
They are inexpensive and pretty convenient.
i buy them at my local electronics store but they are on the web - Electronics Plus. Must be plenty of other places though.
Gints Klimanis September 18th, 2008 03:47 PM
Yeah, but he stated he wanted a longer mini-D cable.
******* WHOAH !!! The PSP cables do not have the correct connector after handling one of these at BestBuy *****
Somewhat related, a right angle connector helps with the space problem if you want to handhold (shoulder mount) the camera with a portable monitor. Here is one from BestBuy:
Sony - Component A/V Cable for PSP
Sony - Component A/V Cable for PSP - 98550
I'm planning to get that cable and cutoff the "A" Tip-Ring-Sleeve connector so that it fits in my Sony EX1. You can see it better in the larger image.
More choices for additional cords. There
INTEC G6828 PLAYSTATION(R) P 2000 SYSTEM COMPONENT A/V CABLE
http://www.amazon.com/INTEC-G6828-PL...1775956&sr=1-6
Alex Raskin September 26th, 2008 07:09 AM
Finally got a great working, slim 6ft extension cable at svideo.com.
It has female RCA on one end, and male on the other - so no additional adapters needed to extend the original Sony cable from the RCA side.
They also have 12ft ones.
Looks great - black, excellent quality. Less than $13 with free shipping.
Picture quality is great - w 6ft extension cable length that I have.
