-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1 or Z7U im ready ... (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/135595-ex1-z7u-im-ready.html)
Ron Williams October 10th, 2008 07:54 PM
ok i FINALLY got the green light to pull the trigger on a new cam[thanks wifey]... i was there all ready to hit submit my order to B&H for the EX1 ... then i started surfing and ran across the Z7U ... now im stuck in a quandry ... EX1 or Z7U of course there is a $1100 price difference but id like some feed back on the pro's and cons of the two. will be making some kind of decission within the next couple of days and since this will be my only cam for a while need to make a healthy wise decission. I shoot weddings / church events and on occasion music videos and looking into going into short film and documentary. Had a HVX-200 and sold it a while back and now ready to get back into the game. all suggestions are certainly welcome
thx in advance
Tim Lenz October 10th, 2008 08:01 PM
Ron,
I was in the exact same boat you are now. What I am doing, is getting an EX1 for my primary camera and then 2 Z5s that are coming out in December. These Z5s are basically the same camera as the Z7U, minus the interchangeable lens and are expected to be $1000 cheaper than the Z7s. They are expected to be even cheaper but you need to buy the CF recorder separate which is expected to result in $1000 cheaper than the Z7 for basically the same cam minus the interchangeable lens. If you haven't seen the other posts about using the SD cards instead of the expensive SxS cards in the EX1, be sure to take a look since you will save alot of money. Instead of a 16GB SxS for $850 you can buy a 16GB SD card for $60 that will record the same amount of footage. (search for Cards that will & will not work with EX1 & EX3)
Ron Williams October 10th, 2008 08:07 PM
ok that does shead some light on the matter ... what are the advantages of SxS cards over the CF cards?
Tim Lenz October 10th, 2008 08:24 PM
Check out this page that has been so graciously put together summarizing the results several people have done testing what works and what doesn't. http://www.dvinfo.net/conf/sony-xdca...sxs-cards.html
I have an EX1 on the way so if others want to jump in please do. My understanding is that while both will record HQ, the SD cards with the Kensington adapter will not record so mo. Another difference is the SxS cards can be downloaded via an expresscard slot much faster than the SD cards. Also, the use of the SD cards with the adapter will not allow you to clsoe the media door on the EX1.
Ron Williams October 11th, 2008 07:52 AM
i think what im gonna do is take a field trip to B&H on sunday and get a hands on with both cameras providing they have them out and working. Kinda leaning towards the EX1 for now but that can change. Going to aruba in 2 weeks and want to bring along for a music video shoot on those clean beaches.
Scott Hayes October 11th, 2008 08:15 AM
Be prepared to pop an extra $500 on two BP-U60 batteries to get you through the day on a wedding shoot. One won't be enough. Now that there are alternatives to the SxS cards,
the EX1 is the way to go. a couple of 32gb Ultra IIs and your shooting all day on those suckers. I suggest buying a 1TB drive for backing up your media as well. One drive for working project files, one drive for storage in case of failure. I am going out today on my second wedding shoot with the EX1. Not having to capture tapes is priceless.
Ron Williams October 11th, 2008 08:47 AM
wow so i take it that the battery life is not that great .... seems that i have been seeing posts about a firmware upgrade that helps a lil for battery life? I wonder if since i will be getting in next few days if cams already have that firmware installed would hate to buy cam and then have to ship it right out for upgrade . that would bite ...
Brian Rhodes October 11th, 2008 09:01 AM
Ron I have owned both cam shot several weddings side by side. The EX1 as an overall better image Quality, although I think the build quality is better on the Z7 it feels more solid. I sold my Z7 and now own two EX1'S and yes you are going to need those extended life batteries.
Steven Thomas October 11th, 2008 09:12 AM
Actually, the BP-U60 is good for 4HRS.
They are excellent and a very good buy at $240.
I remember spending over $800 for an IDX charger and battery for my JVC HD100 camera.
Tyler Franco October 11th, 2008 11:02 AM
What's your editing system? Yes, it does make a big difference because if you are on a Mac with FCP you will have to do transcoding and other hassle full things to get those .m2t files that the Z7 records to CF cards into FCP. On the other hand, FCP and the EX1 work together like a dream come true.
My opinion either way... go with the EX1!
Ron Williams October 11th, 2008 12:51 PM
i have a 8 core mac and mac book pro 2.33 ghz and will be editing using FCP 6.0 ... so your saying that the Z7 is more difficult to edit than the EX1?
Tyler Franco October 11th, 2008 01:24 PM
With your system, yes. You can't just drop in the native .m2t files that the the Z7 saves to the CF card into FCP and start editing. You will have to use software to do lengthy transcoding of the .m2t to a .mov file. (Many people use MPEG Streamclip)
You can't just drop the .mp4 files the EX1 shoots right into FCP either. However, Sony provides a great piece of software with the camera that integrates wonderfully with FCP, called the XDCAM Transfer tool. This will read the video files from the EX1 and QUICKLY (short clips take seconds) place them in a nice clean .mov wrapper to drop right into FCP and start editing.
For this reason alone, I'd go with the EX1. This ease of use with FCP was a driving factor in my EX1 purchase.
Ron Williams October 13th, 2008 10:35 AM
ok... lo and behold .. i went to B&H sunday and got hands on with the EX1 i gotta say i am impressed but check this out me being me went over and started playing around with the EX3 and MAN now of course im now juggling thoughts of do i go EX1 or EX3 now ... the interchangeable lens is not a big seller for me due to i dont seeing the need to spend $$$$ for lens no time soon...i am now leaning on the EX3 side slightly now ok somebody please give me what the pro and con are of plunking down another $1800 ... i knew i shoulda kept my butt home .. lol
Perrone Ford October 13th, 2008 11:34 AM
Based on what you said you're doing, I can't see ANY reason to plunk down another $1800 for an EX3. Now what I COULD see is you buying an EX1, a 35mm adapter, and then being able to buy nearly any lens you want. That might work out nicely.
Glen Elliott October 14th, 2008 12:23 AM
Scott I'll be calling you this week. I'm thinking about plunking down some cash on 2 EX-1s and ditching the XH-A1s (not that I'm unhappy with the quality)...just can't stand capturing dozens and dozens of tapes....not to mention occasional drop-outs.
Scott Hayes October 14th, 2008 05:19 AM
give me a ring! tapeless capture is awesome!
Ron Williams October 14th, 2008 07:41 AM
yea thanks for bringing back down to reality ... i guess the only plus side for me getting the EX3 was for more comfy shooting hand held due to somewhat shoulder support of the EX3 otherwise the time code and genlock thing i guess only has benefits if your using more that one camera? forgive me but i am still really new to the video part ive been doing digital stills for the past 4-5 years using a Nikon D3 and D300 now but i need to expand. I have taken the apple's FCP classes and have become certified in editing so now im going after the shooting aspect.
you know what i have another question i ordered a sony SR12 cause i didnt think i was gonna be able to pull of getting the EX1 in time before i left for aruba and wanted to try shooting a music video there on the beach and i am still thinking of bringing the SR12 with me since it is so small i can carry around and possibly use for B-roll footage my question is would the footage look the same from both cameras ? i mean im gonna use HD on both but if i use some quick footage from SR12 would you be able to tell.
Ron Williams October 15th, 2008 07:20 AM
Ok ive tossed and turned all night ... between EX1 and EX3 even tho i do have the means to get the EX3 i think im gonna just stick with my original plans and stay with the EX1 even tho i know ill be doing alot of hand held work and the semi-shoulder would have been nice.
Scott Hayes October 15th, 2008 07:22 AM
get yourself a cheapo shoulder mount.
Ron Williams October 15th, 2008 07:27 AM
yep scott thats exactly what i plan on doing i saw that B&H has an anton Bauer
Anton Bauer | STASIS FLEX for EX1 Shoulder Mount Camera | B&H
any opinions on this or any suggestions on one?
Perrone Ford October 15th, 2008 07:34 AM
Ron,
There is one other very compelling reason to go EX3, and least in my view. And that is if you decide to record dual system. If you plan to, or might want to record audio separately from the camera, then the timecode features could really save you some time.
This is something I am dealing with now, but the camera flash method is probably going to work out ok for me.
Scott Hayes October 15th, 2008 07:41 AM
ack, way too expensive. I had an original stasis, and it was the biggest pos. I sent it back immediately upon opening the box. perhaps a dv multirig pro or something like that.
I prefer a monopod.
Ron Williams October 15th, 2008 09:19 AM
ok thats good to know about the stasis ... when i was in B&H the sales guy was big on the fig rig ... looked ok but seem like it would be a bit awkward ...
Tyler Franco October 15th, 2008 11:29 AM
I've got the fig rig... and have hardly used it. It's too cumbersome to handle the camera controls with it.
Perrone Ford October 15th, 2008 11:39 AM
Wanna send it to me? I've played with one once, but I think it would REALLY work for some of the stuff I do. I've been toying with the idea of getting one.
Ron Williams October 15th, 2008 12:11 PM
ok well i pulled the trigger on the EX1 ... question how do you check to see if it has the latest firmware? when i was purchasing the salesman assured me that he was gonna pull one that just came in yesterday and that it should have the updated version. but for me seeing is believing so id like to check to make sure
