Next step from the EX1
Looking for advice on the next step up from the Sony XDCAM EX1. I love the EX1 and will keep it working hard for my business.
I am just beginning the search for the next camera to add to my business. Better picture quality is always my goal. I know the next price jump is big so the more I learn the better spent my hard earned dollars will work for me in the near future. Spring time is when I plan on making the next step. |
I suppose a 355 Xdcam will be the next step or if you can go all the way a 700 Xdcam 422.
Ex-3 may be an option but it will not give you much more than the EX-1 |
Gary all cameras on my list along with the Panasonic cameras. I do not know if the XDCAM 3** series is worth the step up for picture quality but that is one of the many things I am trying to find out first hand. The XDCAM 422 700 now 2/3" HD is a definite big step up. Not sure the EX3 picture quality is much better for the added cost. There are of course other reasons but my first check on the list is picture quality then I will narrow down one more time.
Off the top of my head would be the PDW-700 or any other 2/3" chip HD camera.
Though you need to pay a lot for this upgrade in comparison. Larger cameras are much more expensive as you know and if you are working well with the EX-1 (rolling shutter does not affect your shooting) then I would wonder how much of an improvement you would see for the extra $15,000+? Will your clients notice? Just playing the devil's advocate. |
Tim is correct. You're already shooting with 1/2 imagers. The next step is going to be 2/3. But the accessories you have to add are going to get pricey. The 2/3 cameras are all going to want high end batteries, chargers, lenses, and viewfinders.
-gb- |
Maybe get a glidecam or a new software package or something. Seems the EX cameras can look like HDV or a motion picture depending on how you use it.
Why not go with the XDR Flash or Nano Flash with your EX1 and get the quality jump with higher bit rates/less compression? That's the nice thing about the EX1 at this price that you have the option to bypass the default codec. Otherwise, maybe a RED ONE shooting RAW might be good bump.
Stepping up might mean renting vs. owning.
There are numerous cameras available that would move you up from an EX1. The beauty of the EX1 is its value for money. Getting into a Red One or one of the higher end pro Panny or Sony cams will easily add tens of thousands of dollars. As everyone knows, lenses cost as much or more than the cameras themselves, so getting to $40,000 and beyond is easy to do. Spending the money is the hard part.
If your projects support a purchase, then by all means, it makes sense (in general). However, you have to look at the option of renting vs. owning if it means say a $40k camera package vs. renting the same camera for $2000 per week. Also, rental houses will let you run tests and this would be my first step (if I wanted a better image than your current EX1) in deciding what camera fit the needs of the project. Then I'd decide whether to buy it or rent it. Another consideration might be a DOF adapter and still lenses to give your EX1 more of the look of 35mm. This would effect the biggest change for the least amount of money. We all love to own the gear, but in the end, it's what we put on the screen that matters. The EX1 can do a great job in the right hands. But if you need something beyond, you will have to make a move. If it is only a single feature film, then renting would most likely make more sense than buying, but you have to evaluate a lot of factors to make this decision. One last thing to consider, with technology creep ever lurking, renting cutting edge technology is a safer business decision than locking yourself in to today's "latest and greatest" by purchasing it. No telling what the next NAB will reveal. |
REd Scarlet?! after its re-design. 3K - $3000 but better?
Late 2009?! Luckily, Sony sees this and will respond at NAB most likely.
Paul,
I have both EX-1 and F-350 (which should be almost identical with F-355 picturewise). I use the EX-1 for 90% of my work. F-350 is with me when my client "expect" to see a bigger camera, but my personal opinion is that the picture from EX-1 is better due to its light sensivity. The next step for me will be PDW-700 or even better a Panasonic HPX2100, I really like the picture tonality of the Panasonics. You should read this: Five more useful things to buy than a new camera | Simon Wyndham - Video equipment reviews, tutorials, and news. Bjorn |
Thanks for all the input. Let me give a few more reasons for looking at better picture quality. I have a few clients that are requesting 2/3" HD cameras. Yes they love the EX1 but know and see the difference and pay for the 2/3" camera. Is this all of my clients no. And will it be worth the investment well that is part of my research. $40,000 is what I was thinking it would cost to go 2/3" HD so the numbers John suggest are the same I have found in my early research.
I agree the F350 is a great camera but 2/3" is the next step to really see the difference. I have not read the five more things to buy I will read it now been out on a shoot all morning. I am just starting to research Red. I agree renting is a great next step prior to buying. I will use that as a tool to see what I would buy. There are times I am gone for 6 weeks on a shoot then back a week then gone a month so owning is more cost effective for me in the long run. 35mm adapters are not going to work for me on most of my shoots. I need to grab stuff fast and set up and break down very fast. Glide cam will also not work for my shooting and software I am dialed and always upgrading. "Why not go with the XDR Flash or Nano Flash with your EX1 and get the quality jump with higher bit rates/less compression?" Now this is a great idea and one that has not been on my radar. I will look into this further and see what I can learn. Thanks again and please keep the ideas coming. |
The XDR Flash looks like a great next move. 100Mbpsec 422 on four 32GB cards now this needs further inspection. Is anyone using this system?
Well I answered this question by finding out they are not on the market yet. Looks like a great option when they hit the market. Sorry I just got so excited when I read the Specs on the unit. |
Bjorn I read the five more useful things to buy then a new camera. All make sense and I have most covered.
I did buy recently the following which is on its way: Zylight - Intelligent LED Lighting But just so you don't think I am just trying to spend money I really have a few of my best clients asking for a better picture. And a few TV stations I work with love the EX1 footage in HD so it is hard to please all. I did contact one client about the XDR Flash footage and he liked what he was hearing but oh well only time will tell there. |
Get a Sony F35.
Interesting Andrew at a cost of? Have you used this camera?
1 Attachment(s)
Information gathering: A quick google, you'll see a nice video on Fresh DV (Fresh TV) and Adam Wilt did a bang up comparison between the EX1, Red, and F23 (23 was the predecessor to the 35) at ProVideo Coalition.com with images like the one attached For what its worth, my suggestion was to give you the top end of it, which is what you, or anyone here should be striving for... the tops. Hey, why the hell not, right? My other suggesting, would be the Red One, which if you buy now $17.5k (base price for the body) gets you a free trade-up to an Epic when they are released. Epic being the 5K bad ass. I have priced out a Red kit, and its around $90-100k Honestly, beyond resolution, I don't see where Red is that much of a step up from the EX, but I suppose it is. Now the F23/35 that's a serious step up. And if you can afford it, read: your clients will appreciate it and pay for it, then go for it. |
Thanks Andrew yes we all should be striving for the F35. But for now it is out of my range and I would buy a dome for the helicopter before I would spend that much on a camera.
Thanks for the link to Adam Wilt's review I will check that out when I have some free time today. As for the Red One we have talked about renting that camera when the time is right. |
Well I took a step in the right direction today and ordered XDR Flash.
With most of my work shooting fast moving subjects this seems like a good step. So if this solves my problem of clients and me noticing artifacts and motion blur well then I can move on to other areas to refine.
Question between the EX1 and EX3: Is the lens on the EX1 the same quality as the lens on the EX3? Having the options to change on the EX3 is nice and I know I passed by this thought earlier when the EX3 was mentioned. But with a portable SDI 100Mbps 422 capture would the EX3 glass be better? |
| All times are GMT -6. The time now is 05:02 PM. |
