I am only suggesting playing with the aperture so that the poster can convince himself that his shadows aren't above the left wall. I am not suggesting that intentionally under-exposing is a way to increase dynamic range.
However, in keeping with my original comment, to maximize dynamic range on the EX1, first thing is to use a gain setting of 0 dB. If this is too hot, use an ND filter. Now, maximizing dynamic range is frought with problems, like leaving no headroom for exposure errors. Great for well controlled(aka well lighted) stage, but, not so great for run and gun. In the case of run and gun, I would try one of George Strother's presets. |
yep.... that would be it
Thanks for the advice, Bill, yes I've tested the left 'wall' by reducing the aperture to closed. The brick wall is still there, just like on the right side with certain PP and Gain-3. Any clues? I'll also test out using Photoshop on an image. Regarding using 0 gain rather than -3 gain, am I hitting a brick wall anyway with -3 Gain, just sooner with -3? Also am I trading off more noise at the 0 gain setting? It seems like everybody recommends -3 gain setting, but, really, what are the advantages? Thanks for yours and everybody's input. |
On the contrary, the way the gain is defined during manufacturing, the voltage that produces the lowest noise is 0 dB. Other gain values, above or below, should increase noise.
Looking at the left edge of the histogram on my EX1, I notice that zero signal corresponds to a position on the histogram that is about 1/16-1/8 inch to the right of the left frame edge around the histogram window.Perhaps you're assuming that the display should extend all the way to the left frame, when, in fact, it does not. You can test this by turning on the TestBar pattern and notice where zero is. |
Keith...
Dunno why I wasn't thinking when I answered you, yesterday. The brick wall, on the left of the displayed histogram, can be moved left or right by the BLACK setting in the Picture Profile menu, under BLACK. Note that the default setting of '0' gives you some small amount above RGB16. I found that setting '-8' is pretty close to an RGB of 16. A setting of '-16- seems to be the lowest my camera will go before it starts to crush the blacks, according to my Waveform Monitor. |
I just played around with a lot of picture profiles and gain level with the Black level and nothing I do will move the left brick wall all the way to the left when I close the iris. It's as if this is just an unused portion of the histogram. Bill or anybody else, if you can get the left brick wall to go all the way please let me know. Or maybe I shouldn't worry about it --however I figure I'm throwing away some detail in the shadows. My aim is to be able to squeeze every bit of available latitude I can. Thanks all.
| All times are GMT -6. The time now is 06:12 PM. |
