I should say I'm looking at EX1 Paper Manual. Is that the EX3 Manual you're referring? I just want to make sure we don't drive people crazy looking in the wrong manual. I suspect much of the basic information is similar but obviously in different places in each.
I could be wrong, but....
The manual says a 10% range on Zebra 1. That's plus or minus 5% from whatever you have set.. At least in my camera, if I set Zebra 1 at 95% I get zebras in the range from 90% to 100% (as measured by the brightness display). I don't often have people as the main subjects, so I'm more concerned about blowing out highlight detail. That's why I have Zebra 1 set at 95%. Pete |
i'm still not 100% what exposure "compression" is. could someone elaborate? thanks. Happy New Year! |
My manual says ±10% not 10% range. Setting Zebra 1 to 107 can trigger at 97. Setting Zebra 1 to 95 can trigger at 85.
The exact wording in my EX1 Manual page 41: To display a zebra pattern in the area of ±10% centering the video level set with "Zebra Level." My translation: The number you set Zebra 1 to is the middle of the range. That range starts -10% and ends +10% Setting zebra to 95 would be 85-105 range. This is different than Zebra 2 which is locked to 100% and only displays over that number. from the manual on Zebra 2: To display a zebra pattern for the video level over 100%. So, if you want zebra 1 to start displaying at 95% set zebra 1 to 105%. Zebra 1 is the CENTER of it's ±10% range. Zebra 2 wont display until it hits 100% (there's no under to the range). It would nice to have a zebra trigger point at 107% since anything below that still has data that can be used/rescued/not clipped. Quote:
Craig, I know what the manual says. I'm pointing out that MY camera doesn't work that way. Set at 95% I get zebras in areas that range from 90% to 100%, as measured by the Brightness Level Indication in the viewfinder.
Please try yours and let me know how yours works. Whether my camera is unique (doubtful) or the manual's writers were less than clear (more likely) is not a problem for me. I like the smaller range. Zebra's covering 20% of the exposure range would not be much use to me. Set at 95%. I can tell what parts of the image will be very light gray to white without blowing. Pete |
| All times are GMT -6. The time now is 06:39 AM. |
