-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX3 newbie 2 questions (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/141998-ex3-newbie-2-questions.html)
Enrique Orozco Robles January 20th, 2009 09:09 PM
Starting to "play" with the EX3... really amazing camera and very happy with it.... sorry for my english....
1.- There es no 15 shutter speed ... coming from JVC HD110 maybe I'm missing something that I don't really need (the JVC now seems to me not very light sensitive compared to the EX3)... but anyway 30 speed (shutter off) is the minimum ? (besides jumping to SLS modes...)
2.- For MxR/SDHC combo users: I'm beggining to let the adapters always in the camera and just taking out the SDHC cards for transfering to my systems (with USB "cheap" adapters to connect to PCs) .... what do you think ?? do I need to take out the whole combo ?? safest way ??
Kind regards
Bruce Rawlings January 21st, 2009 01:24 AM
I think you will find other posts that indicate the best way is to remove the combo before changing the SDHC card. The camera system can easily get confused so why look for trouble? I use MxR adapters and Transcend 16gb class 6 cards with great success.
Nick Wilson January 21st, 2009 03:13 AM
If what you are after is 1/15 shutter speed, SLS 2 frames on a 30fps format will give you 1/15. Remember that shutter needs to be on for SLS to work.
Ted OMalley January 21st, 2009 02:14 PM
I NEVER remove the adapters (mine are the Kensingtons) unless I'm planning to use slo-mo. However, I power-down the camera and remove the card when I change it. I've found that I can remove and replace one SDHC card with no problems, but the camera gets confused if I remove a second one.
Andrew Stone January 21st, 2009 09:27 PM
I did a four and a half hour continuous shoot. Did not turn the camera off once, using exclusively SDHC cards. I had one small ID problem the whole afternoon which was fixed by a "reformat card" action. I, of course, took out one card at a time as they filled up.
