-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   Good News for IR contamination problem (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/466739-good-news-ir-contamination-problem.html)
Dave Morrison October 30th, 2009 11:18 AM
Keep us posted, Ronn. I'd love to send them both of my invoices.
Markus Klatt October 30th, 2009 11:20 AM
@Andy
Thanks a lot!
The comparison EX1 / EX1R without filter looks as if the EX1R would even a little brighter. Did you use same gain and iris settings? Does the EX1R have at leat exactly the same sensitivity (with same noise) as EX1R?
Thanks again,
Markus
Vincent Oliver October 30th, 2009 11:28 AM
Originally Posted by Andy Shipsides (Post 1440232)
The good news is that they have eliminated this problem in the EX1R and 350.
Andy
The bad news for most of us is that we already have the EX1 or EX3, together with the IR problem
Andy Shipsides October 30th, 2009 02:17 PM
Originally Posted by Markus Klatt (Post 1440277)
@Andy
Thanks a lot!
Thanks again,
Markus
Markus
Good question. I didn't notice that it was any faster because I was just testing the IR issue and eye balling exposure. I reviewed the two clips in the Clip Browser and I can see that the EX1 was set at a F2.2 and shutter of 89 degrees. The EX1R is at a F2.5 and at a shutter of 103 degrees. They were both on STD3 gamma and at 0db Gain. So it does look like the EX1R is a bit more sensitive and the noise level is right about the same.
Peter Eggleston October 30th, 2009 03:19 PM
Originally Posted by Dave Morrison (Post 1440255)
Awww Peter, had I known you were in the market for a 486, I would have sold you mine! ;-)
I'll probably get another anyway, as I keep a spare protection filter in my camera bag in case of accidents, and a second IR cut would make more sense than having to go back to an ordinary UV ;->
I might take the opportunity to get a Tiffen instead though - as people have said, they're relatively well priced. Never having tried one I've nothing against them except earlier reports on this forum: a greater overall colour cast, mid-greys may be tinted green even after a WB, and a one stop loss.
I need as much sensitivity as I can get as I record underground a lot and don't like to use any more than 9dB gain. What I like about the 486 is that it has so little attenuation at visible frequencies that on auto iris the ring hardly moves when you put the filter in front of the camera.
I would be very interested if someone could post EX1/3 shots of a greyscale or a Munsell/Macbeth colour chart, with and without the Tiffen but with the camera on one preset colour temperature for both, to see what it is doing...
Ed Kukla October 30th, 2009 03:31 PM
No tiffen T1 IR filter for the Fujinon W/A zoom lens. I'll have to tape on a 4X4 to the lens hood.
Piotr Wozniacki October 31st, 2009 06:10 AM
Well, if your shutter is reported wildly with values like 89 or 103 degrees, you must have been using some auto settings (either full auto, or at least auto shutter with TLCS). Hence this is not a conclusive or fair comparison. Also, considering the EX1R was F2.5 and 103 degrees, this makes a higher exposure than the EX1's combination of F2.2/89 degrees.
BTW, the Acquisition tab of the new Clip Browser is a fun to watch - especially when, for testing purposes, you set the camera to Auto everything... Sudden changes in ATW measurements, focus hunting - really educative!
Andy Shipsides October 31st, 2009 08:27 AM
It wasn't full auto anything... just set to 23.98p with a second based shutter. But doing the math 89 degrees =1/97 and 103 = 1/83, which is equally as strange. Perhaps the flicker reduce feature was doing something as well. So Piotr I'd have to agree that something is not right.
I do love the Acquisition tab though, fun to watch the settings as they change.
