-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1 Audio? (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/469561-ex1-audio.html)
Steve Kalle December 21st, 2009 02:57 PM
Chad, how do you have the NTG 3 routed to both channels? (I am about to order a NTG 3 to replace my NTG 2 so I can get the Blimp for $1)
Dave Morrison December 21st, 2009 05:34 PM
Not Chad, but I believe you use the Audio Input menu to select Mic 1 as your audio input and it will split it across both channels. Then you can set your Internal Trim and External Trim to suit. I usually run one channel at the "desired" setting and run the other one a little hotter or softer, depending on what my subject matter happens to be. That way, I have a "safety" track to work with in case I need it.
Chad Johnson December 21st, 2009 05:45 PM
Yes, what Dave said. In the audio menu you can have ch1 go to both channels. But I think that's only for ch1. Ch2 alone may not work.
Remember to keep your audio levels (the dials on the outside of the camera) at 6 or below. Otherwise you will introduce noise unnecessarily.
Dave Morrison December 21st, 2009 05:51 PM
The only thing I do differently from Chad is that I put the external trim dials at "5" to begin my settings as that is essentially "0", or no gain or cut. Once I get the internal Trim set so that I get decent levels, then I use the external to boost and cut as needed. I usually carry a "cheat sheet" with me all the time that has the basic settings I need for all my mics. They ALL have different output levels so they each need their own internal Trim setting.
Adam Reuter December 23rd, 2009 03:17 PM
Ahh...let me correct my views on this issue.
A MIXER is not as essential with the EX1 IMO if you only need two channels. But an EXTERNAL RECORDER is a better option if you have it. 24-bit/96kHz (or insert your sampling rate here) may be a placebo effect but I'd rather err on the side of quality than regret it later.
That being said, the circuitry/preamp built into the EX cameras are fantastic at 16-bit/48kHz.
Denny Kyser December 23rd, 2009 04:44 PM
I have decided to keep the SD 302 mixer, I like the option of being able to record to the Camera and my Sony PCM-D50 at the same time. I also like how easy it is to visually see the audio levels.
For now I will keep the mixer and use it when audio is critical.
Thanks everyone for the input, I will skip the mixer on occasion and enjoy the freedom of less equipment and simplicity for less important events.
