-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   USB-bottleneck gone in EX1R - full SDHC-overcrank?! (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/470175-usb-bottleneck-gone-ex1r-full-sdhc-overcrank.html)
Ola Christoffersson December 29th, 2009 04:53 PM
Today I accidently used my Sandisk Ultra II with MxR-adapter when overcranking 50@25 fps. To my surprise I did not get an error. With my old EX1 I have not been able to go beyond 43 fps on the Ultra cards.
As most of you know the limiting factor for data speed using SDHC-cards with the camera is not the adaptor or the cards themselves. It is the USB-interface of the EX1/EX3 that is limiting data speed.
After todays experience I am suspecting that this bottleneck is gone!!!
After coming home I tried maximum overcranking 60@25 fps. This worked as well!! I have just completed recording one 7 minute and one 8 minute clip at 60@25 fps onto my SDHC-card!
I have not had time to do any extensive testing beyond this but the results are very promising. The EX1R also prevents trying to record to quickly after finishing a recording. It gives an error message stating that it is finishing the previous recording and is not ready to record (or something similar). This also gives me more confidence in using SDHC.
I think these improvements are there to increase stability when using the Sony Memory sticks but it seems like SDHC-users are benefitting as well.
I'd be very interested to see if anyone can confirm my findings!
Marcus Durham December 29th, 2009 05:36 PM
It wouldn't surprise me. As reported a few weeks back I've been able to fill a card at 48fps with a new MxM and ATP combo and the new Sandisks are supposed to be faster than the ATP cards.
Can you fill a card at full 50 or 60 fps though? MxM claim for their cards 48fps is the maximum reliable limit no matter what your choice of card. I've managed 50fps with ATP cards but not reliably for more than a couple of minutes.
Ola Christoffersson December 29th, 2009 05:43 PM
That's interesting. I assume that these reults come from an EX1R? Is there another thread where this has been reported? If so - maybe they should be merged.
Marcus Durham December 29th, 2009 05:53 PM
No, on a normal EX1.
I reported this on the forum and here: Further Adventures with SDHC and the EX1 | Media2u Video Production Blog
Ola Christoffersson December 29th, 2009 06:07 PM
Ok! Just read your article. Interesting results. Kind of contradict the common opinion that it is the USB-bus of the camera that is the bottle neck.
Regarding the Sandisk card I used - it is not new. The Ultra II I was using is well over a year old.
Ray Bell December 29th, 2009 10:45 PM
Just wondering if it might be that the new EX1r has more buffering memory than the
original EX1 and the USB handshake is more robust...
Ola Christoffersson December 30th, 2009 04:33 AM
Well - maybe it uses the new cache record memory in a clever way?
Anyway - I will do more tests when I get the time. Meanwhile - anyone with an EX1R and an SDHC-adaptor - please see if you can confirm my results!
Doug Jensen December 30th, 2009 06:43 AM
Hi Ola,
I can confirm your results. I am able to record at 60 fps using a SDHC card in my EX1R.
I've recorded clips from 10 seconds to 15 minutes long without any errors or anything unusual happening.
HQ 1280 /30P @ 60fps
EX1R with firmware V1.00
Hoodman RAW-SDHC16GB card
Hoodman SxSxSDHC adapter
I don't normally shoot on SDHC cards, so this is the only card and adapter I have to test.
The same card in the same adapter causes an error on my EX1 within 5 seconds after recording starts.
Matt Davis December 30th, 2009 07:00 AM
Okay, that explains something that struck me only after I'd packed up for the day. I was filming tests comparing 720p25 and 720p50 down to SD, and native DV recording. And, yes, the 720p50 was in an MxR adaptor with a 16GB 'Old' Transcend (if it were an MGB, it's the chrome bumper version, not the rubber bumper one).
But those were short(ish) clips - 60-90 secs or so.
So I've just fired it up again in S&Q mode. Got 1-2 mins at 60fps on the MxR-Transcend (Old card, folks, not new card! I repeat, OLD card, YMMV) before recording drops out with Media Restore message (so pop card out, pop card in, press Execute, everything fine). Which is maybe twice to three times what I could get away with on the EX1 at 720p60 (and all I personally need on most jobs, frankly).
At 50 fps, it's conking out at about 5-6 minutes. I may stick with this setting as I'll reliably get any slomo shot done in a minute or two.
At 45 fps, it's filled the entire card without missing a beat.
At 48 fps, it copped out after 8 minutes.
I really had better get back to work...
On my EX1, I could go up to 38-40 fps on filling a card, but would be lucky to record 15-30 seconds at 60fps. So there DOES appear to be an improvement, but not a full scale revolution.
Addendum: Filled a card at 720p50.
PS: A colleague has just taken delivery of a couple of Transcends - the 'High End Video' ones - and put them into his new EX1R. When we'd finished our phone call, he'd recorded 11 minutes in 60fps S&Q mode using his original Kensington ('KxS') adaptors, and from record-off to green light was about 4.5 seconds. I've left him doing more soak testing.
Marcus Durham December 30th, 2009 01:42 PM
Just remember folks, when testing your overcranking you should ensure you have moving material in the viewfinder. Pointing the camera at a wall or a non moving image doesn't stress the codec and my initial results showed that you might get the wrong impression of how far you can push a card if the VBR codec isn't being stressed.
It was perfectly possible to get the camera to bomb out when it was on "the edge" by doing a whip pan or other things that ensured much of the scene was changing frame to frame.
I'm wondering what impact the EX1 firmware update will have on SDHC solutions for owners of the older camera.
Matt Davis December 30th, 2009 01:49 PM
Don't worry, Marcus - I was also testing my Zoom at the same time as the stress tests. The 720p50 tests were recording a locked off shot of Michael in his Lego nest. Not particularly stressful, but enough.
The best example of how efficient VBR is would be to record bars. :)
But I do see possibly a 20-25% increase in speed in off-to-green performance between the EX1 and the EX1R using SDHC.
Marcus Durham December 30th, 2009 02:04 PM
I can't help but think that is is something to do with Sony implementing their own adaptor solution. They are going to want their adaptors to be as reliable as possible if they are to add them as a "supported" option.
If you want to borrow one of my MxM's for research purposes, just email me. I'm wondering if an EX1R will also see the same kind of performance increase I saw between the MxM and the MxR or if this is a EX1 specific thing.
Doug Jensen December 30th, 2009 03:00 PM
Good point.
My successful tests with the EX1R were done hand-held with lots of motion. I should have said that in the first place.
Ola Christoffersson December 30th, 2009 05:22 PM
Hi again everybody!
Great to hear that you can confirm my findings. This makes me even more comfortable using my MxR-adapters and SDHC-cards with my new camera. Although I could not resist to get one of the new 32 GB SXS-1 cards with the camera so I will probably be using the SDHC-cards less now than before.
Anyway - we seem to have established that there is an improvement in the speed of the cameras USB-bus and since several people have achieved maximum overcrank the bus no longer seems to be the bottle neck. This calls for more testing of the different adaptors and cards. Maybe we can find the best combination that can safely record in all modes onto SDHC.
Keep the tests coming!
Marty Welk January 7th, 2010 03:46 PM
I dont have anything to compare. I only have the EX1r. Craig Seeman told me how to test it (thanks Craig)
and i cannot get it to have a problem with any of my adapted SDHC cards using a LCK type adapation.
All my cards were purchaced from trusted sources, and tested long before i used them in the camera, they are all true class6 operating cards.
all i did was test, eventually i will be using the camera when my bottom is on the line, then i will know more.
Steve Nelson January 7th, 2010 09:22 PM
We can only hope that this can be addressed via a firmware upgrade on the EX-1. If anyone with connections to Sony can confirm or deny it's tied to firmware that would be most appreciated!
Andrew Stone January 7th, 2010 10:26 PM
I am thinking it is the buffering. It would be interesting to know how long it takes for SDHC card to go into standby mode after the overcranking is complete. Have any of the testers noted this?
Marty Welk January 7th, 2010 10:40 PM
i looked Loosly, and at the most it went from ~3 seconds for the normal data rate to ~5 for the 2x data rate.
now i time it and it took ~3.26 seconds for the 720 60/24p recording was about 18seconds.
and it was relative ammount of time for both SxS and SDHC.
Zsolt Gordos January 8th, 2010 10:45 PM
ATP 8 and 16 with MxM works full overcranking on EX1r, I have moved the camera around to get more stress for the system.
Older cards have issues, even without overcranking.
Can someone explain why I see the indicator light red while recording slomo on SDHC card (no error msg, record fine, playback fine, indicator red and turns green after the clip finished)
I think the card is close to its limits...?
Anyone?
Marty Welk January 9th, 2010 02:13 AM
the indicator for the chip memory does turn red when the data is going to the chip and not finished going to the chip, this is normal, it turns green when the memory is finished being written to.
THe Red on the chip writer led thing itself doesnt indicate that it is full or empty, just that it is presentally being written to.
i guess the idea would be, certannly dont pull any memory out when the light is RED :-)
