-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   clip browser version (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/474848-clip-browser-version.html)
Ed Kukla March 15th, 2010 07:27 PM
new laptop...downloaded clip browser...version 2.6...looks like the old version.
Isn't 2.6 the later, newer look version?
Olof Ekbergh March 15th, 2010 07:52 PM
2 Attachment(s)
2.6 is the latest. and 2.11.0 is the latest transfer.
And they work great on OS 10.6.2.
Ed Kukla March 15th, 2010 08:05 PM
this is on a PC. I deleted it and went back to the sony site & re-loaded. For sure it says vers 2.6 but it is definitely the old version!
Simon Denny March 16th, 2010 04:02 AM
I have Snow Leopard and cant get the XDCAM Transfer to work at all.
I have to use my Laptop with Leopard on it to get my XDCAM files.
Where can I find the latest XDCAM transfer that works for Snow Leopard? I have looked everywhere and can't find a link to the download.
Cheers
Olof Ekbergh March 16th, 2010 07:02 AM
Simon, here are some links:
Sony | Micro Site - XDCAM EX
Sony of Canada E-support
http://www.sony.co.uk/biz/view/ShowC...c-xdcamex-0807
Simon Denny March 16th, 2010 12:53 PM
Thank you so much Olof.
Cheers
Ed Kukla March 16th, 2010 07:11 PM
Could this be some sort of Windows 7 issue? I'm running into other software hangups with win 7 64
Paul Gale March 17th, 2010 01:41 AM
Can you post a screen shot of what you're seeing and I can compare it to what I see on win 7 x64. My clip browser seems to work fine though.
Paul.
Ed Kukla March 17th, 2010 05:05 AM
Paul
Have you seen the old version of clip browser? That is exactly what it looks like. The new clip browser has a totally different look vs the old one that I see. Yet it says version 2.6!
Paul Gale March 17th, 2010 05:45 AM
Not sure I have seen the old one - well, I have seen a few versions now but can't remember a huge difference.
It's not Windows 7 reverting to basic display mode is it? Is the Aero interface still enabled?
Piotr Wozniacki March 17th, 2010 09:05 AM
1 Attachment(s)
Originally Posted by Ed Kukla (Post 1500818)
Paul
Both side by side (the jpg file name explains which is which).
Paul Gale March 17th, 2010 09:12 AM
Ah yes - Ed, are you definately seeing the old version then?
I've recently installed yet another copy on Win 7 x64 - and it definately looks as it should.
You say that the old ver has never been installed on this laptop?
Have you uninstalled and installed fresh again?
Tuy Le March 17th, 2010 10:45 AM
You can check the ClipBrowser version:
click on Help(H) - About Version
It will open a small window with this info: V2.06.00.201 Last update: 2009/10/14
I have it run good on both systems: winXP SP3 & win7 x64
Ed Kukla March 17th, 2010 06:28 PM
new computer with win 7
I did install the old version accidentally. I did a complete delete before loading the correct version.
The current version says 2.6 but it is the old version.
Simon Denny March 18th, 2010 01:16 AM
Still no luck for me on Snow leopard. The program loads but I cant mount my Sony PDW F350.
What is strange is I installed an old version which was 2.5 or something around that and the camera mounted but the program would not load.
Any Ideas for those Mac users on Snow Leopard.
Cheers
Paul Gale March 18th, 2010 01:21 AM
Sounds like the old version hasn't been removed properly then. I wonder if it picks up the version info from the registry rather than version info held in the program files themselves (hence running the old code but showing the latest version).
When you say you did a "complete delete" what exactly did you do, step by step?
Maybe try uninstalling (using the app's uninstaller) and then navigating to the program directory to make sure it has been deleted properly. You need to check both the "program files" and "program files (x86)" directories. In fact, I wonder if that could be contributing to the problem - I wonder if the old app is being installed in the 32 bit directory and the new app is being installed in the 64bit directory. See what you have in both.
Personally, I would also check the registry to check all signs of the program have also been removed there, but this is a dangerous step unless you're happy using regedit.
Ed Kukla March 18th, 2010 04:41 AM
I did use the uninstaller. Going beyond that is not in my usual capability, I don't do this often. I miss XP!
Ed Kukla March 18th, 2010 05:19 AM
I went back into this again.
Did an uninstall.
Then did a search of all files named Clip Browser, XDCAM or Sony. Deleted all recent files from hard drive connected to those names. Rebooted and reinstalled 2.6.
Still get the old version with new version number.
Ed Kukla March 22nd, 2010 07:13 AM
Sony support's answer is to do a roll back to before clip browser installation. That would work BUT...I installed CB first then installed many other programs and data. I will loose most if not all of that work and have to start over again.
I installed Wise Registry Cleaner. Did an uninstall and then ran the Registry Cleaner. Still no luck. also did a disc clean.
There has to be a solution besides the troublesome sony solution.
