Latest firmware is v1.15
Hello Andy, I'll give them a ring again and as you advised, I then might ring Sony. I only emailed and rang once since this happened. It isn't their fault either. I know its silly but I almost feel I'm pestering by ringing, I don't want to bother them but I had my share of bother that weekend. No way will I use this SxS card,.. for anything. Lucky enough I don't have a wedding this weekend so I have a little time to get it sorted. Thanks Andy. . |
I don't see anything in the symptoms you've described which would make me think it's more likely to be one over the other. |
Would you use that card for recording a wedding? If you would, your a braver man than I, especially after the way it behaved when inserted in to the laptop and desktop. Say for instance nothing happen at this wedding. Everything went as usual, no problems at all regarding this SxS card. Then, when I arrived home and inserted the card into the laptop and nothing happened. Laptop didn't see the SxS card, card out and in again still nothing showing up in My Computer and again the same happening in the Desktop, would you not think, there must be something wrong with this card (especially when the other SxS card copied 100% first time to the PC's) and would be very brave to use it at my next wedding. Now, I could be completely wrong here but it looks like card problem to me. May be its the camera. Could it be? If someone thinks different please say. Quote:
I would not be prepared just yet, to use the NF on its own without the camera recording, a backup. I hope to use the NF as an independent recording device, along with the EX3. Again thanks David for your thoughts, thanks. |
You say "the way it behaved when inserted in ......" - but what I'm asking is what if the CARD behaved perfectly, it was the way the CAMERA wrote data to it that was the problem? By the sound of it, it was probably a one-off event. In practical terms, what I would do is check, check, and check again the equipment, in exactly the configuration (with NF etc) you'll next be using it for real. And do it with both the card you are suspicious of, and other cards. |
Hi David and thanks,
You could very well be right, it could be the camera, I just don't know. I intend to test again, as you suggested and see what happens. Thanks again. Anthony. |
Re: Sony 32GB SxS card problem.
I'm getting the faulty card replaced.
When I insert the new card (SBS-32G1A) into the camera slot will i get the message saying i need to format the card in order to use it or are these new SBS-32G1A cards ready to go and don't need formating. Thanks in advance. |
Hi Tony.
Always format |
What I also want to know is. If its a brand new unused SBS-32G1A card and I put it into the camera will it say in the VF that it has to be formated first. |
- Don |
I got a new card out from the package (toren a bit) and inserted it into the camera. I didn't get the "you need to format the card" message and immediately thought "its not a new card". I just thought,... if its a brand new, I need to format and if it doesn't need formating, its not new. So, if its already formated by Sony it looks like its a new, unused card after all. Thank you. |
| All times are GMT -6. The time now is 05:02 PM. |
