How do you import multiple files from the EX1r Camera? XDCAM
Ok, so I took a TON of quick video snippets with the Sony Ex1r camera and now I need to import those into Adobe CS3. I can go to the BPAV folder and then inside that folder manually go to each folder and import the video file, but there must be a faster way to import hundreds of clips. Please let me know!
figured it out........just import the CLPR folder and all the individual clips come in
There is a faster way:
You can select the BPAV folder and click 'import folder'. The folder with the video files will appaer in your project window. You can rename the folder in the project folder (this doesn't change the actual name on disk, but in Premiere only) so you know which folder it is, in case younported multiple BPAV folders. (yes, when importing the folder you will probably get a messages that some files are not supported video-files: that are the xml files... this won't effect the videofiles) |
| All times are GMT -6. The time now is 02:29 AM. |
