Ex1r questions
I am ready to buy the sony PMW EX1R and i have some questions:
I have no money for SxS cards that's why i will use only SxS to SD adapter. Is it safe? I want to record in 2 storages at the same time for safety. Can the camera do it in both SxS drives with SD adapters? Is it better to record in one SxS drive and for backup in other storage type and if yes in which storage type? The sony dealer told me that if you use the camera in handheld mode then don't try to back up with Hard discs because it is not safe for the hard disc because of the vibrations. Is that correct? Which is the best set up for recording in 2 storage types at the same time? which adapter is better for the camera and which SD cards? thanks in advance Kostas |
Re: Ex1r questions
You may be tempted to buy cheap SDHC cards. That's your call. Many cards work but I prefer to put my trust in premium brands who publish specifications about their cards operating parameters. Remember a good card will last you years. Don't be tempted by the Sony SDHC adaptor as they are overpriced and seem to offer nothing over other brands other than a sticker saying "Sony". If you are looking for a hard disk recorder, MxM sell a solution which uses a SSD. Again I have been using this unit for about 4 months now and it's been a joy to use. The only consideration with a SSD unit is extra weight on the camera when handheld. I prefer to only use mine on a tripod. If you do need a backup, you'll need something like the Nanoflash or one of the cheaper variants that now seem to be cropping up. You shouldn't really need it though. The Nanoflash (and variants) are the only way to simultaneously record to two devices at once. |
Re: Ex1r questions
before some minutes sony dealer call me and told me that the adaptors are MxR and free as a gift from him but i must buy the new sandisk cards and are faster than class 10.
Re: Ex1r questions
Re: Ex1r questions
In my opinion, you are making a mistake. SxS cards are very reliable and the EX1R comes with a 16GB SxS Pro card to get you going.
You cannot record to both slots at the same time. To get a second HD recording, you need a device that hooks up via the HD SDI output. Those devices also need power and a place to mount. Take the money you are going to spend on a second device/battery/accessories and purchase used SxS cards on eBay or an SxS-1 32GB card which are less expensive than the SxS Pro. The only SDHC that sees my EX1R is a Hoodman Raw 32GB (made by MxM) which is for emergency backup only. It is not flawless like my SxS cards have been. |
Re: Ex1r questions
so the only way to record in a second storage type at the same time is only nanoflash or datavideo etc.?
Camera can't wright at the same time in both slots? |
Re: Ex1r questions
Correct. Simultaneous recording is done via the HD SDI output port.
Re: Ex1r questions
Les - could you please expand on the recording failures you've had with the Hoodman RAW? I'm using a couple of the 16GB RAW cards in the Hoodman branded adapters. Perfect so far. Anything we should watch out for? Thanks.
Re: Ex1r questions
Keith,
Hoodman is also a good choice - in fact, they are rebranded MxM! I concur with what Markus says: MxM adapters never fail; not with class 6 or class 10 cards at least. Piotr |
Re: Ex1r questions
I formated the Hoodman card in the EX1r. My uses of the card were either to
1) Copy SxS cards onto the Hoodman which I then backed up on a Nexto DI 2700 via the SDHC. This was for footage that I wanted to have two copies of. 2) Record onto the Hoodman if I ran out of SxS Once or twice I had to record onto the Hoodman and maybe 5 or 6 times, I did the shuttle of data off of an SxS card. Over the course of my trip, one time the EX1r complained of the Hoodman being unrecognized media. My memory is faded on this but I got around it. Probably by restarting the camera and then reinserting the card. The other glitch was the second or third time I shuttled data to the Hoodman, it wasn't storing a full 32GB. Somehow, it only had a capacity of a 16GB card. I reformatted and went on. I realize putting the SDHC into the Nexto is a variable treating it as an SxS card only won't have and could be why I had the glitches I did. Furthermore, just having it be an SDHC design enabled me the piece of mind to shuttle the data to the Nexto 2700 for extra backup. I was glad to buy the Hoodman instead of the much more expensive Nexto that stores SxS cards via the USB or the outrageously more expensive Nexto that takes SxS directly. The Hoodman served as an emergency SxS, emergency SDHC for my TM-700 and a shuttle to the Nexto. I lost no data whatsoever and the only glitch that bothered me was the unrecognized media. Unfortunately, I can't say for sure that it happened without the SDHC card having been inserted into the Nexto which in theory should be entirely read only but ....... I'm of the opinion that MxM/Hoodman are the best non-SxS choice but I would not depend on them like I do SxS. I kept my SxS costs down by getting the MxM SSD recorder with a spinning disk to wrangle cards to at the end of the day as backup #1. Shuttling the data via the Hoodman to the Nexto was backup #2 for photographer, my Ex1R and my TM-700. YMMV |
Re: Ex1r questions
Well, of course I cannot deny that what you're describing might happen. But my $0.03 would be that the Expresscard adapter + SDHC card combos are most reliable when used as such, i.e. as an Expresscard with USB interface. This is how I copy, transfer, etc. - never remove the SDHC card for those purposes.
Frequent inserting/removing the SDHC card might bring about some additional problems, which should be avoided to minimize any risk of disaster. Piotr |
Re: Ex1r questions
Re: Ex1r questions
And in anycase, the system is designed for SDHC. Sony have even released their own overpriced adaptor. All we ever seem to hear is SxS is worth the money because it doesn't go wrong yet we still see posts with people having problems. It's all flash memory, it all can go wrong and the only difference is low manufacturing volumes and some hefty mark-up mean that SxS costs twice as much as it should. Somehow SxS going wrong still means the media is worth the money. SDHC going wrong is seen as proof that it is unreliable. All things being equal they actually seem about the same when you use the latest cards with the latest adaptors. And if someone uses a cheap SDHC card in an old adaptor and comes to grief it doesn't mean that SDHC is unreliable. It means they can't follow best practice and are out on their own. |
Re: Ex1r questions
I've had an EX1 for over 3 years now, and never a problem with my SxS cards.
I also have some Hoodman adapters / RAW cards - which I use if I need additional recording beyond my 5 hours of SxS. They have also performed properly. I've tried placing other brands of SDHC cards in the Hoodman adapter, and have at times received 'unrecognized card' messages, and even had a card that started recording and after about 15 seconds just stopped. (Luckily I was testing on my time in my office, and not on a client's shoot.) But having said all that, the thing that I like best about the SxS cards is their offloading speed. I'm doing my own data wrangling on most productions, sometimes for an additional camera as well when the producer decides to 'get creative', and the idea that I can offload a 16GB SxS card to my Nexto drive in 3 minutes means that much more time that I don't need to be dealing with data at the end of the day! Long story short, I just added 2 - 32GB SxS-G1a cards to the 88GB of SxS cards I already own. |
Re: Ex1r questions
Remember the days of VHS tape? They all said "VHS" on the box and worked in the machine, but the cheap own brand tapes from Tandy/Radio Shack gave an awful picture while the premium Scotch tapes gave a good picture. If you did your research you'd know that the premium tapes gave better performance than the budget tapes. It's the same with SDHC. Not all cards are the same despite what the label claims. There are large performance differences. Just because a card says "Class 6" or "Class 10" on it doesn't mean its any good. The only cards that go near my camera are ATP Pro Max and Sandisk Extreme. Two of the more expensive SDHC cards. They are tested, they work, they haven't given me any problems at all. |
Re: Ex1r questions
XDCAM EX was never designed to work with SD cards. It was discovered by me and a couple of others however that it was possible to get the USB interface in the express card slot to work with various adapters and other cards. Then when third parties started releasing custom adapters Sony also released their own, following market pressure. To do this they had to modify the cameras firmware to get some degree of stability.
As I always say, you pay's your money, you make your choice. The number of posts on this and other forums with people having issues with SD cards far outweigh the small number of SxS problems. Most of the SxS problems, when you dig deeper are operator error, people pulling out just the mp4's or not reconnecting spanned clips. It is extremely rare to find a true faulty SxS card. If your doing amateur productions then SD is fantastic, as a backup or reserve for unexpected situations it also has a place. But as a professional camera operator I am not prepared to take a chance with my clients valuable, sometimes irreplaceable material. It's like buying a Porsche and then fitting the brake pads from a Yugo. Over the several years that you are likely to own your EX how much will a couple of 32Gb SxS pro cards cost? What value do you give to peace of mind? there is enough stress in this industry and on a shoot as it is. The last thing I want is a little niggle in the back of my mind about the reliability of my media. Tape is very different. A bit of corruption or a few drop outs on a tape might spoil a shot. A bit of corruption on a solid state media card might make everything un recoverable. |
Re: Ex1r questions
Hi All,
This may seem like a silly question but as I already have some sony memory stick pro HG cards for my NX5 I was thinking of getting an adapter for my EX1r that takes them. I have been using SXS cards and so far no issues for my wedding business but want more memory for the times at the end of the night to get the throwing of the carter etc. Has anyone used those in SxS adapters? if so what was ur opinion. Many thanks |
Re: Ex1r questions
I'm going to bow out here as my thoughts are well known on these issues and SDHC solutions are perfectly stable and reliable if implemented and used correctly. |
Re: Ex1r questions
My opinion -- in weddings there are no re-do's. Start with 5 hours of SxS cards. If it turns into a marathon, then go to your backup data. As stated earlier, if you use SDHC cards, go with ones that are fast, reliable, and fully tested by you. Within my comfort level, I'd always rather be using SxS cards, and I'm even happier when I'm running a backup recording to a Nanoflash at the same time. I started buying SxS cards when they were more expensive, I've spent almost as much on memory as on my EX1 (I now have 160GB of SxS), and I've never regretted it for a second. |
| All times are GMT -6. The time now is 09:25 PM. |
