-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   EX1 / EX3 Tripod Plate VERY prone to Crack or Break (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/497731-ex1-ex3-tripod-plate-very-prone-crack-break.html)
Chad Johnson June 27th, 2011 04:49 PM
Hello fellow EX1/3 users!
I just wanted to share a story in order to potentially save you a lot of money and headaches.
Broke one of my EX1s recently. After shooting a show in a movie theater, some joker kicked over my tripod and it fell, hitting the back of a theater seat. The base plate (part that you screw in the tripod plate to) broke and the camera hit the cement floor hard. The screws that held the plate in, stripped the holes in the frame, so I couldn't just replace the plate. I have a protection plan at B&H that was sold as "No questions asked" that covers everything luckily.
Well 2 months later I got my camera back. It turns out that the lens, front frame, and mic assembly needed to be replaced as a cost of 2,700.00. I didn't have to pay because of the PP, but man I was without my camera for 2 months, and you just don't want to deal with any of this. These plates break easily, and when they do you are screwed.
Anyway I found a solution: Juiced Designs EX1 base plate replacements. They are much more solid than the stock plate and even allow for an optional accessory arm to attach whatever to your camera.
juicedesigns.com
Here's a little video I made about the experience, in hopes that you may find this and save yourselves some major headaches.
Alister Chapman June 27th, 2011 07:34 PM
re: EX1 / EX3 Tripod Plate VERY prone to Crack or Break
This is a well known and well documented issue with the EX1 and EX3's. Just do a search for cracked base plate and you find several threads.
The Juice Designs plates are nice, I have one on my EX1R and used to use one on my EX1. For the EX3 there are plates from DM Accessories and Olof at Westside Studios as well as others.
A more substantial tripod may have helped prevent the whole incident, the one in the image looks way to small (and thus unstable) for a camera the size and weight of an EX1. I would also say to anyone never to leave tripods un attended in public areas, people are clumsy and will knock them over, on top of that you run the risk of getting sued if you create a trip hazard that someone then falls over and gets injured as a result. Always try to keep the tripod legs surrounded by something such as seats, flight cases, tape or other barriers to prevent accidents like this.
Chad Johnson June 27th, 2011 08:23 PM
That tripod was for illustration purposes only. I have Sachtler fsb8 head and Gitzo 6x carbon fiber legs that are appropriate. It was part my bad for having the tripod unattended. I was asked a question as I was tearing down, and stepped 3 feet away. Also the theater stupidly didn't bring up the lights between acts, so it was very dark. And though I knew about the issue, I figured I'd just be careful... Well you can't do that 100% of the time! Lesson learned.
John Peterson June 28th, 2011 04:44 AM
This is why I always put my tripod in the seat rows instead of the aisle. I don't care if I am off center. I just adjust it. One leg of the tripod goes in between the folded seat and the seat back. The other two go up against the back of the seats of the row in front of the tripod. If I need to I hang a weight from the center column.
John
Gary Brun June 28th, 2011 05:36 AM
and a great free advert for the manufacturers :-)
Dave Sperling June 28th, 2011 01:37 PM
Re: EX1 / EX3 Tripod Plate VERY prone to Crack or Break
John,
A couple of things to watch out with this tripod positioning system -- Many of the Broadway houses (particularly ones with newer seats) frown on this, since tripods that have pointed bottoms can often do damage going through the tight clearance between seat and cushion. In some theatres we've taken the opposite approach: tie back the seat in front of you and send a tripod leg over the seat to straddle the two rows. It seems to work best in some of the houses with the least room between the rows.
Also, remember that any time your tripod touches a seat, it may be affected by body movements by persons sitting in nearby seats in the row. Be particularly careful with comedies (laughing movememts) and music shows (some audience members litterally bounce in their seats.) In older theatres, when someone of substatntial size moves in their nearby seats, I've seen seat movement of as much as 1/2", so I always try to have more clearance than that.
Best,
Dave S
Chad Johnson June 29th, 2011 08:01 PM
"send a tripod leg over the seat to straddle the two rows."
That's how I had mine. I have rubber feet though. It worked fine, and I had room to stand behind my camera. I just had one leg on the outside with the 5 inches on the bottom sticking a tad into the isle while I was tearing down. Just enough for the guy to kick when he was finding his way around me as I dealt with the other guy asking me questions.
Dave Sperling June 29th, 2011 09:51 PM
you're right... I should have specified running a ground spreader under the seat to lock in the legs. Though not 100% safe, it does help maintain stability if the tripod is bumped or kicked, especially if used in conjunction with a sand bag.
John Peterson July 15th, 2011 07:47 AM
Originally Posted by Dave Sperling (Post 1662537)
John,
Best,
Dave S
I'll try that next time.
John
Nick Wilcox-Brown July 16th, 2011 03:04 PM
Glad the camera is up and running again Chad!!
I've only had my EX3 for a few of weeks and I was looking for a robust solution. An ENG colleague, Dan Chung, suggested the tripod plate by Westside A V.
I cannot speak highly enough of the service I received: all options (shoulder bracket, nanoflash & battery mounts) were discussed with Olof on a skype video call and the unti was shipped to me in the UK, in less than a week, for a great price.
Steve Kalle July 23rd, 2011 03:37 PM
I am in the same situation but my EX3 plate is not completely broken....yet; although, it is cracked thanks to my Zacuto shoulder rig and my assistant moving the camera by the EX3's handle without holding it from the bottom :(
Does anyone know the part number for the EX3 base plate because Sony's website shows the plate for an EX1 and Abel Cine cannot seem to find anything other than what Sony shows. FYI, the EX3 has 2 threaded holes and the EX1 has only 1 threaded and 1 non-threaded.
I have the VF Gadgets plate but cannot figure out how to screw it into my EX3. Part of the reason is that no screws were included as it was given to me for free and I cannot find a manual.
Mitchell Lewis July 27th, 2011 10:14 PM
We use the Chroziel plate with rods for our EX3. It's not a flat plate, it curves and fits the bottom of the EX3 perfect. We haven't had any issues and we've mounted A LOT of stuff to it. (teleprompter, Steadicam, wireless mics, etc...) We actually bought the kit that comes with their matte box as well. Not cheap, but it's holding up great after 1.5 years of use.
http://www.bhphotovideo.com/c/product/681153-REG/Chrosziel_AC_401_422_401_422_Lightweight_Support_System.html
Philip Howells August 6th, 2011 04:42 AM
We rightly condemn poor service so I think it's appropriate to post this report of first class service. I was attracted to the concept of adding an additional plate to my EX1R that would spread the load more evenly as a precaution against possible damage as described in this thread. Since we already have J-rod supports to sling the gun and radio microphone receivers near the front of the lens, I ordered only the basic plate from Westside.
When it arrived I realised that it did nothing that my existing tripod plate - the Manfrotto 501pLong does already, in fact the Manfrotto has two bolts plus an alignment lug whereas the Westside plate has merely two bolts.
Since it was an International purchase it wasn't covered by the UK Distance Selling Regulations which would have permitted me to return the item for a full refund. Accordingly I reported my disappointment to Westside and resolved to sell the plate on eBay and put the inevitable financial hit down to experience.
I was surprised when Westside responded extremely positively. expressing their disappointment at my unsuitable purchase and immediately refunded the full cost and the return purchase to them.
I'm sure neither of the owners want to get into this situation again so let me first suggest that if your need is simply for a stronger plate the Manfrotto item will do as good a job at a fraction of the price. It's mass produced, certainly not as fine a piece of engineering as the Westside item but it does exactly the same job.
Second I'd not hesitate in recommending the company's business ethics - rare qualities, difficult to earn, easy to lose.
Chad Johnson August 6th, 2011 10:28 AM
But doesn't the manfrotto just attach to the existing EX1 base late?
Philip Howells August 6th, 2011 11:04 AM
Yes, exactly as the Westside product does.
Garrett Low August 6th, 2011 12:07 PM
I thought the Westside plate screwed into additional locations as well as the 1/4 x20 for the EX1/r. At least for my EX3 plate it does.
In any case, I agree that Olof and Westside are very good people.
-Garrett
Olof Ekbergh August 6th, 2011 04:10 PM
1 Attachment(s)
On the EX1 there is good reason to add the 3 2mm screws further back on the base of the camera for added stability as with the EX3, the EX3 is much stronger than the EX1 or EX1R with the addition of the 2 4mm screws on the angled part of the base.
The EX1R is a little different, the 2mm screws back of the double 1/4" screws are attached to the same bracket as the 1/4" screws, so nothing is gained by adding those 2mm screws. The 1/4" screws are plenty strong. The problem is really the studs that the plate attaches to, they are not very rugged.
My plate addition on all the different models have the added advantage of allowing for multiple accessories to be mounted to my plate, not the camera, so the additional stress of NanoFlash wireless receivers etc. are now attached to the plate not the camera, and I also offer the shoulder brace systems and large brick battery attachments without adding stress to the weak connection to the camera body frame.
If anyone has questions feel free to contact me directly.
olof@westsideav.com
603-383-9283
Steve Kalle August 6th, 2011 04:55 PM
Hi Olof,
Would you be willing to accept a check from a city gov't (who is my main client)?
Thx
John DuMontelle August 7th, 2011 08:20 AM
For what it's worth...a couple of my freelance buddies have the EX3 as one of their cameras, I just bought one for myself. I've known about the base plate concerns for some time and they recommended I get this plate designed for the EX3.
EX3 Teleplate
Just another option since I didn't see a plate for the E3 listed on the Juice Design web site.
