-   Sony XDCAM EX Pro Handhelds (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/)
-   -   sony sxs 64gb cards (https://www.dvinfo.net/forum/sony-xdcam-ex-pro-handhelds/498893-sony-sxs-64gb-cards.html)
Philip Howells July 30th, 2011 10:46 PM
Re: sony sxs 64gb cards
Les, unless I'm misunderstanding the term wrangling applied to memory cards, isn't this what I've addressed?
Les Wilson July 31st, 2011 05:45 AM
Originally Posted by Philip Howells (Post 1671340)
...I can't relate to DSLRs because I don't and wouldn't use one.
This seemed to indicate you thought it was related to DSLRs.
Philip Howells July 31st, 2011 10:55 AM
Originally Posted by Les Wilson (Post 1670733)
snipped. At least that's how it was presented by Shane Hurlbut ASC in B&H's series on DSLRs.
Les, as you see, it was you who first introduced DSLRs into this thread, not me.
Les Wilson July 31st, 2011 11:05 AM
That was the name of the tutorial where the issue of card size philosophy was presented by Shane Hurlbut that I was summarizing for you.
Thierry Humeau August 4th, 2011 08:31 PM
I use Sony 64GB G1A SxS cards on my F3 and these have been flowless.
My 2 cents.
T.
Steve Kalle August 6th, 2011 01:40 PM
Originally Posted by Mike Marriage (Post 1670705)
In regards the lifespan of the SXS-1 cards, it doesn't concern me at all. Even if there is any truth in it, in 5 years the cards will almost certainly be far cheaper to replace than the price difference between SXS and SXS-1 is now.
Maybe I'm cynical but it strikes me as more of a marketing ploy to justify suddenly having to halve the cost of SXS media in response to Panasonic releasing cheaper P2 cards.
I understand the cynicism but the reason behind both Sony's and P2 E's cheaper price is due to the use of MLC NAND Flash which has a much lower number of write cycles than the expensive SLC flash. WIth the 32nm flash chips, MLC has about 10,000 write cycles whereas SLC has 100,000 - this explains the 1/10 life cycle. However, with the newer 25nm flash, the # of write cycles has decreased to ~8,000. This reduced write cycles is a major problem as the size of flash chips decreases. With the next size reduction (20 or 22nm), the # of write cycles will decrease again.
The only way to see significant reductions in the price of NAND chips is by size reduction. Thus, I do not expect a significant reduction in SxS prices in the next 5 years.
