Follow focus options for F3 and zeis cp.2
If the Zeis CP.2 will be primarilly used with the F3, would a chorsziel dv studio rig suit it just fine? I have read and heard that the Arri ff-4 is the industry standard but is it really that much better than the studio rig given the price difference?
Also considering the Zacuto among other FF systems. I would like to keep the cost under $2000. bang for the buck type deal. Thanks in advance everyone. |
Re: Follow focus options for F3 and zeis cp.2
A new version of the Redrock Micro Follow Focus is expected by the end of May.
Its the Redrock Follow Focus Blue (V3). |
Best bang for buck seems to be the shoot 35 for round $600. if you need a reversing gear for Nikon or hard stops (esp for still zoom lenses with continuous focus rings) then you need a an Arri MFF-1 at 1750 . Don't know if zacuto offers hard stops. That's what I've seen anyway.
Thank you for the quick replies. I will be waiting for the RR follow focus. With the Chorsziel will I have issues with the PL lenses I intend to use? at about $1600 is looks like a good deal. I just want something that feels sturdy and actually is sturdy. minimal play.
Also, Im trying to figure out why some of the other follow focus sytems cost so much more. |
Beware - Redrock has had a "no return" policy . sounds good tho maybe I should have waited
The Redrock sounds terrific but be careful - Redrock has had an alarming "no return" policy . Negotiate that option ahead of purchase if you can.
Below is a link to a series of video reviews of most of the common follow focus units available (a few of the newer ones are absent). The review goes over the lash in most of the units. The Chrosziel is in there.
ProVideo Coalition.com: VIDEO: FRESHDV by Matthew Jeppsen & Kendal Miller |
Thank you Andrew! Yes I was taking a look at those reviews not to long ago. Will be doing further research.
I had the chrosziel DV Follow focus, and it worked fine for the prime lenses I had.
However, I used an older angenieux zoom lens, and the lens didn't have an internal focus barrel, so you could only spin the lens a little bit. I needed the bigger gear and unfortunately alot of the FF gears aren't availible for the DV follow focus unit. So I upgraded to the studio cine rig, and man I love it. |
That's the more expensive double sided system correct? I took a look it one but it is $4000 and I can't really budget for that. Other than than that experience did you feel it was a reliable unit and recommend it?
Btw, the new RR looks pretty good and I will keep in mind the no return policy. |
It was definately a reliable, well built unit, just like most chrosziel items.. If I recall the DV follow focus is a 1:1 gearing I believe the terminology is, meaning for however many times you spin the FF, it spins the gear at the same rotation. The stuido is a 2:1, so you are spinning the handle alot less. I hope that makes sense.. it makes sense in my head, but I don't know if the translation came thru. |
def. makes sense. Thanks! I will be looking out for a used system in that case as well. I wonder how the DV studio fares against the arri mff-1.
lemme know if you got it (just fire one back) Ryan |
The Genus Superior FF is a good unit. You can reverse it by putting the pitch gear on the opposite end of the drive spindle. No hard stops though.
I think it's more down to the riser and rails, but I can see that the slider could cause problems on some set ups. I have a different riser so it fits under my lenses.
| All times are GMT -6. The time now is 06:24 AM. |
