-   Sony XDCAM PMW-F3 CineAlta (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/)
-   -   Firmware 1.1 and S-log available June 1 (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/496657-firmware-1-1-s-log-available-june-1-a.html)
Chris Medico June 6th, 2011 09:45 PM
Re: Firmware 1.1 and S-log available June 1
Want to report that the firmware update went well and the MxM SDHC adapters with the ATP memory cards are working fine.
WHEW!
Leonard Levy June 7th, 2011 10:34 PM
Just upgraded and all is well. Jog wheel is great and no problem with Hoodman Raw adapter and 16G raw Steel SDHC card.
Sam Painter June 11th, 2011 02:51 PM
A flashing "Rec 2" comes up screen left of the HD SDI output while I am recording.
I can not get it to go away with display mode. It stays on flashing all the time while in record.
Distracting and annoying.
Anybody have any ideas on how to disable this?
Why does it flash Rec "2" ?
It does not change depending on what card I am recording onto or what record button I push.
Thanks Sam
Alister Chapman June 11th, 2011 03:13 PM
You have SDI Rec Control enabled in the Video Set menu. The camera can send a "record" signal down the SDI to trigger external recorders.
Sam Painter June 11th, 2011 03:43 PM
Thank you!
