External Recorder Choice
Hi guys...
I'm new to the forum so thought this would be the best place for my question.... Am just about to purchase an F3 and have some extra cash to spend so my question is this... Which would produce a better image and give more latitude stop wise for roughly the same price- the S-Log upgrade with a Ki Pro Mini(4:2:2) -or- Convergent Designs Gemini(4:4:4)?? I am aware that buying the Gemini would cost more when you add on the cost of the internal drives and also what type of shooting I would be doing would factor on my decision but just wanted to know which option would produce the best actual image(I'm also kinda leaning toward the Gemini as I think the 4:4:4 output would probably best future proof me against the onset of 4K imaging but then again S-Log looks fantastic too)... Your thoughts and views??? Cheers.... |
Re: External Recorder Choice
Convergent Design has an excellent history of support for their products. I have the NanaFlash and have been quite happy with it and the upgrades. You can't go wrong with the Gemini ... it will prove to be a valuable product.
I think all of this new batch of 10 bit recorders has minor growing up issues. Firmware upgrades and minor tweaking to get everything right.
That's always the case.
You have to realise that S-log recordings need much more (grading) time in post. So match your investment to the 80% of your type of work (final product). Else spend it on a nice lens, if it's a good glass, it'll be there forever.
I'm told my samurai will be shipping this Monday November 7.
I would definitely go for the Cinedeck EX. It can record to Pro Res, DNxHD, Cineform 422, Cineform 444 and uncompressed (using their faster SSDs).
On a budget, I would get the PIX240 which records to Pro Res and DNxHD 422. I like the PIX because it gives you options of recording to CF cards or SSDs in addition to their caddy system which offers various connections such as USB 3, FW800 and eSata. The F3 has a Bayer sensor which means it cannot output a true 444 signal; so, I don't see any value in recording the 444 output. However, the S-Log output is definitely worth every penny. I like the PIX240 more than the Aja because the Aja is formatted with HFS which is Apple only; so, you need a Mac to download from it or you must buy extra software to read it on a Windows PC. The PIX240 can be read on any computer. Also, the Aja must stop recording when the CF card fills up in order to switch to the other CF card; so, you must constantly be aware of how much space is left and how long the current shot will take. The PIX has a good LCD so shot review is fast and easy. FYI, grading S-Log footage takes no time at all. A simple S curve makes the image look normal. In another thread, I posted 2 images of S-Log ungraded and S-Log with a Curves effect applied to demonstrate how easy it is to grade. |
Hi,
I am looking into investing into an external recorder for my sony f3...I would love the recorder to do 2 main things, recording of s-log in 4:2:2 in prores codec and recording of 1080p 60frames...is the PIX240 capable of doing that? if not...what are the current external recorders that are able to do that apart from gemini and cinedeck which are both a bit too expensive for my taste.... |
When you say slog and ki pro mini or gemini 4:4:4 are your aging not getting the slog upgrade with the gemini?
I think owning a gemini without having the slog/444 upgrade is a lot like having a sports car but not being able to drive. If it comes down to slog and a recorder and no slog with a recorder, I would go with the slog upgrade without a doubt. |
The PIX240 does work well with the LOG on the F3. Once v1.3 of the Sony firmware comes out it will work even better. |
Aaron,
What about 60p with Pro Res HQ or DNxHD? |
Anyone who owns a Convergent Design XDR (like me), has to agree with me on this point. It's a fact that CD promised a number of features for the XDR and simply never delivered. There's no apologies or explanations. It is what it is. They've moved on from the XDR and that's that. I actually understand a bit about why they'd just abandon the product for upgrades, so I'm not sore about it. Ordinarily, I probably wouldn't have a reason to mention CD in a post at all but when I see something like this, I can't help but say something. Again, any XDR owner would agree with me. |
I did just get a phone call from Cinedeck this morning though, telling me about the new 2.5 version. How's that for excellent support. A phone call, from a human?! Maybe the new 2.5 version can do other 1080p60 codecs. I won't be able to check it out for a bit though. Currently on a show. |
While the cinedeck is an excellent device, like the PIX-240 these are significantly bulkier than the Gemini and that should be considered when making your choice. The Gemini mounts very nicely on the handle of the F3 and can be powered along with the camera with a single Swit battery for a couple of hours.
If your are handheld, or on the move a lot the Gemini is a lot easier to work with. If your working on a set where portability is not so critical then perhaps the Cinedeck or PIX-240 (422 only) will be better. |
To add my 2 cents while on the topic: I have stated before that I believe the Cinedeck to be much better suited than the Gemini, and when total operational costs are included, the Cinedeck is faster and cheaper to use. Uncompressed uses a TON of space and there is no ability to upgrade the Gemini to record anything but uncompressed whereas the Cinedeck can currently record to Cineform 422, Cineform 444, Pro Res 422, Pro Res 444, DNxHD 422 (probably will add DNxHD 444), uncompressed 444 & 422.
With that said, I am still waiting for someone to explain the need to record 444 from the F3 when it doesn't have enough pixels to output an actual 444 signal. Aaron, I would appreciate your thoughts on the Cinedeck. I have access to one and plan to conduct some tests with a F3 + S-Log soon. Do you record to Cineform, Pro Res or DNxHD and do you have a preference - if so, why? |
If I didn't own a Cinedeck, I'd probably give Gemini a serious look, even after they abandoned the only product I ever bought from them. |
My choice of whether to shoot Cineform or ProRes on Cinedeck is always a struggle. Every single time I start a project, it's painstaking to figure which one to use. Cineform is a much better codec, with an unmatched meta-data system, but ProRes edits so much easier for me since I use FCP studio. It's a struggle every time. If I choose to shoot 4:4:4 though, my choice is made for me. The only camera I have that shoots 4:4:4 is the Viper and the Cinedeck can't record the Viper 4:4:4 in ProRes. So if I'm shooting 4:4:4, it's always Cineform on the Cinedeck. Also, the Cinedeck chews through batteries like no other. A lot of the stuff I do, the Cinedeck won't work on at all. Like the show I'm on now, we use nano flash and XDR. The Cinedeck battery life would be a showstopper for sure. |
While the F3 does not have a R or B pixel for every sample in the 1920 x1080 frame the way Bayer works means that there is still more colour information in 4:4:4 than 4:2:2. Bayer calculates each individual colour based on all 4 pixels in the matrix (2 green, one red, one blue). Even the calculation for Green will take into account the amount of light falling on the Blue and Red pixels. A certain amount of colour cross talk is built into the system, so for example pure Blue will be detected by not only the blue pixel, but also (by a small amount) the R and G pixels and this is taken into account in the de-bayer algorithm and calculations.
You also have to consider that it is very rare for the colours in a scene to only contain the three primaries. More commonly there is a multitude of colours, so a purple object is going to be sampled by the red and blue pixels primarily, but possibly a bit of green as well. So while there isn't a discreet R, G and B sample for every point in the 1920 x 1080 image, the bayer calculations will build something not all that far from full RGB, so 4:4:4 will have more colour information than 4:2:2. Is it essential to record 4:4:4? No, not at all. 4:2:2 will work very well indeed, but the data overhead for 4:4:4 isn't that all that great (it's only about 35% more data) and it will give you more to work with. You don't have to record 444 with the Gemini, it will record 422 as well. Recording uncompressed is very nice, there are no compression artefacts, period. But very light compression would be almost as good. Avid will be releasing a 444 version of DNxHD along with Avid MC6 next month. The idea behind the Gemini is that you shoot native 444 uncompressed and then choose how to work with the material when you offload the cards. You can offload and keep the footage as uncompressed DPX or transcode to the codec of your choice. It takes around the same amount of time either way, with a reasonably powerful computer such as an i7 or higher. As the original is not compressed the computer doesn't need to "uncompress" it's purely a single compression stage. |
Dear Friends,
Technically, the best way to record S-Log or any Log footage is to record full uncompressed. And recording 4:4:4 is better than recording 4:2:2 if at all possible. Of course, with the Sony F3 + S-Log + Gemini 4:4:4 all of this is possible. Recording it to any compressed codec is a compromise, but, of course, one may be willing to accept those compromises. There are no artifacts of any kind, or any loss of any kind when recording full uncompressed. For the F3, one can use CineGamma 1, CineGamma 4, and record to a compressed codec. We know for a fact that many are using our nanoFlash with great success with the Sony F3. But, taking the technical high road, we do not recommend recording S-Log to the nanoFlash. It is not that we have tested it, we have not. But someone is about to run such a test and report back to us. S-Log is a great addition to the F3. And to record S-Log, we recommend the Gemini 4:4:4, for the reasons outlined above, as well as the fact that the Gemini 4:4:4 has built-in viewing Sony S-Log LUT support. While the Gemini 4:4:4 is a full uncompressed recorder, it is very practical to take our full uncompressed files (in DPX format), and perform a "First Encode" to whatever codec you wish. This is very important. Using this approach, you can have the full uncompressed footage (if you wish to save it) and still use any compressed workflow of you choosing: ProRes HQ, ProRes 4:4:4:4, Sony XDCam 422, and many others. We choose to build the Gemini 4:4:4 as a full uncompressed unit. This keeps the weight down, the power low, and the quality high. Just compare the Gemini 4:4:4 to any other recorder. It can easily be mounted on the hot shoe of the F3, or mounted using a Noga arm, as the Gemini 4:4:4 is about the size and weight of the Small HD DP6 Monitor. The actual weight is 1.26 pounds, a little heavier than the DP6. Other full uncompressed recorders are much more difficult to mount on the front of a camera so that the monitor (if available) is in a usable viewing position. |
| All times are GMT -6. The time now is 09:54 AM. |
