-   Sony XDCAM PMW-F3 CineAlta (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/)
-   -   One card, multiple cameras (https://www.dvinfo.net/forum/sony-xdcam-pmw-f3-cinealta/518376-one-card-multiple-cameras.html)
Bill Ward August 17th, 2013 02:32 PM
Is there any solid reason that a single SxS card cannot be used on back to back shoots by different cameras?
I've got a series of double camera interviews in the next few days. Due to a just completed two day double camera shoot, I am running a bit short of SxS cards. I have a couple of 64 gig cards left, one for my camera, one for the EX-3 and F3 cameras to be provided by local DPs. Most of the interviews are 30-60 mins, so they all might fit on one card. Can I format the card, use it in an EX-3, then take the same card and record the next two shoots on two different F3 cameras, as long as the camera resolution is the same, and the card is not reformatted?
I know it is not ideal, but any potential issues I might encounter?
Dave Sperling August 17th, 2013 11:51 PM
Re: One card, multiple cameras
Can't think of any reason it wouldn't work, unless there were an issue with one or another of the cameras not being on the latest firmware. My preference if doing this would be to format the card on an F3, but that's just me... At one point or another I've tried recording onto same card from EX1, PMW200 and F3 and all were fine and visible in XDcam Browser (data from all 3 on card at same time).
The main caveat is to make sure you're not duplicating file numbers, which though unlikely could theoretically be possible. I'd also really try to avoid spanning cards if possible, though I can't think of any reason this would be a problem - just never tried it...
Also, make extra sure that the card doesn't get formatted by mistake!
John Cummings August 18th, 2013 08:15 PM
I don't think I'd rely on it for a paying gig...but I'm a nervous nelly.
Bill Ward August 25th, 2013 09:35 AM
Partial follow up: I did test it fairly vigorously before the shoot, going back and forth between an EX-3 camera and an F3. There appeared to be no issues...it recorded and played back flawlessly.
Our only other option on this last shoot would have been to use my disaster scenario 30mbs SDHC cards in a card adapter. We were able to record without issue in the field. But the final test is when they download the cards into post on Monday and we see for sure.
Bill Ward August 31st, 2013 09:47 AM
And, final follow up: card was able to be downloaded with mixed video from an Ex-3 and two different F3 cameras, without issue.
YMMV.
James Kuhn August 31st, 2013 10:14 AM
Bill Ward...thanks! I know I can copy from memory a camera's programmed settings on an SxS card and use it with another of the same model camera. What I didn't know, but you've shown, is you can use the SxS card with different camera platforms. Interesting. I am presuming, as in this case, these cameras all need to be within the XDCAM family? I wonder if you can do the same using 'XQD cards and adapters'? Hmmm?
Regards,
J.
John Cummings August 31st, 2013 12:02 PM
Good to hear!
Leonard Levy September 1st, 2013 04:27 PM
I've used the expresscard adapters for SDHC cards and formatted them on both a Canon t2i and the Sony EX-1.
The formatting information seems to remain for both cameras regardless of whether I reformat in either camera to erase footage so its on some deeper level of the card. Neither camera seems to care that format info for the other is on the card. Thus I can switch the same SDHC card in both cameras without erasing anything. Presumably similar for XQD.
(The T2i doesn't use the expresscard adapter BTW - that's for the Sony. )
