Lightest Light Stands 2.5 lbs or less
As a single person crew I'm finding that light stands are the hardest thing to cut weight on. My current stands weigh about 3 lbs each so carrying three weighs a hefty 9 lbs. Here's a list so light stands under 2.5 lbs.
Testrite 100-3 Light Stand (7.25') 1 lb 9 oz http://www.bhphotovideo.com/c/product/53819-REG/Testrite_100_3_100_3_Light_Stand.html Manfrotto 5001B Nano Black Light Stand - 6.2' (1.9m) 2.0 lbs http://www.bhphotovideo.com/c/product/612771-REG/Manfrotto_5001B_5001B_Nano_Black_Light.html Avenger A625B Light Stand (Black, 7.8') 2.2 lbs http://www.bhphotovideo.com/c/product/67812-REG/Avenger_A625B_A625B_Midi_Kit_Stand.html |
Re: Lightest Light Stands 2.5 lbs or less
I have a pair of the Manfrottos and like them a lot, Craig. They're fairly sturdy, too. I use them in conjunction with several Impact 6' and 8' stands, or can pack them in a Pelican 1510 case with camera, mics and small lights for air travel.
Thanks for that. B&H specs say they support up to 3.3 lbs. Curious what lights are you using with that?
I'm concerned that an Aputure Amaran HR672 and batteries with small softbox might be too much weight. |
I have a handful of Manfrotto 5001B stands and wouldn't trade them for anything. I have two Aputure 672 lights and they're are no problem on these stands. I also put a boom pole/griphead/boom-holder/microphone on one and use a backpack as a sandbag.
Cheers - Slavik |
#5 |
I use Aputure Amaran 672 lights on the Manfrotto stands with no problems. Sometimes I'll use a flex arm screwed into the 1/4" 20 stud to hang a collapsible diffusion disc. A 672S is then attached lower on the stand shaft by a super clamp so it shoots through the diffusion disc for a soft key light.
#6 |
Thanks. Aputure will be coming out with a Diffuser and 50° Grid that will mount directly on the the light so I was concerned about total weight.
#7 |
Westcott Light Stand (Black, 8') 2.2 lbs
http://www.bhphotovideo.com/c/product/356270-REG/Westcott_9908_Lightweight_Black_Light_Stand.html Adding to the list. Impressive height for the light weight and only 35$ as well. Apparently in heavy use with over 60 reviews at B&H and a 4.4 out of 5 stars with all that. |
#8 |
I have the Lite Panels 1x1 kit that comes with one flood and one spot. The kit includes two Manfrotto NANO tripods.
#9 |
Thanks for that. Litepanels 1x1 weight about 3 lbs. I wonder if the Nano handles the additional weight of modifiers such as a soft-box.
#10 |
I use the Chimera softbox on mine. I have also used the LitePanels barn doors on the 1x1s on the NANO.
#11 |
Anyone making carbon fibre? I have Manfrotto Master stands but they are 6.6lb - they are however very sturdy (I use them for mounting Sony small handycams)
#12 |
Promaster LS-CT Compact Travel Light Stand
#13 |
I have three of the Manfrotto 5001B Nano stands. I use them with my Aputure Amaran 672 lights with no problems, including the Aputure diffusion and softbox accessories. All three stands fit in a cheap, small soft tripod case (http://www.bhphotovideo.com/c/product/883672-REG/Ruggard_bp_2022_Padded_Tripod_Case_22.html) for a very compact package.
I have also put my old Lowel Tota and Omni tungsten lights on these stands before (with no or minimal accessories), but probably wouldn't trust them for anything much heavier. - Greg |
#14 |
Don't forget about Norman light stands. I have two of then that have lasted me well over ten years. I hang everything Lowel on them including Riffa soft boxes.
http://www.bhphotovideo.com/c/product/38348-REG/Norman_812255_812255_Mini_Compact_Light.html 2.6 LB for this one. Steve
www.CorporateShow.com Been at this so long I'm rounding my years of experience down...not up! |
#15 |
@Steven looks like it's actually 2.3 lbs, Very light for something that can go to 7.6" Air cushioned too.
