better then having a not working rig, i would say. guess i will have to be more careful buying stuff from the net, next time.
anyway, i still think it is a good investment. ed |
Magiqcam on it's way
Hi all, our Magiqcam rig is on it's way, we just received notiforcation. We have been watching with baited breath, the comments on this forum. looking forward to your support in getting it all up and running.
BTW we have the low dog as well. Trevor. |
<<<-- Originally posted by Ed Liew : the pics will be there.
the new price on ebay is $18++ without the hard case if i'm not mistaken. it was selling for $15++ before with hard case. one question - after balancing with the new gimbal and have it mounted on the arm, the sled tend to tilt to the right. what could be causing this? appreciate all the help. ed -->>> Hey Guys ! Where can I get one of those Gimbals ?? Thanks !!! |
Again, this sounds like what Ed was experiencing with is new gimbal - Mis-alignment of the tilt bearing axis. I could be wrong. Rebalance and test the rig again.
I know that John has a much more expensive gimbal assembly as well as some other improvements. $18++ is cheap for a good stabilizer system even though it's not cheap.
Regarding the tilt, does it balance correctly on the balancing stand and then change when put on the arm? Is the angle from arm to sled the same as when balanced on the stand. I know it's not supposed to make any difference however it would help in figuring out the problem. Tery |
i think anthony was asking the question where he can buy the new gimbal and not the balancing problem which i was having. i'm way past this problem and now with a new problem, if you guys remember ;o(
ed |
<<<-- Originally posted by Ed Liew : i think anthony was asking the question where he can buy the new gimbal and not the balancing problem which i was having. i'm way past this problem and now with a new problem, if you guys remember ;o(
ed -->>> Hello, Yes, I would like to know how I can get one of those gimbals. Thanks !! |
Do you own a magiqcam? if you do all you have to do is contact john and he can probably set you up.
Sarah |
Hello Sarah,
I don't own a magiqcam, I just want the gimbal. I don't know John, but I am going to Google "magiqcam" right now. Do you know if one could purchase that gimbal separately? Thanks !! |
www.magiqcam.com
Owner name: John (he is a real nice guy) |
anthony,
take a look a this gimbal - http://pg.photos.yahoo.com/ph/digiperalta/album?.dir=/5bd8&.src=ph&.tok=phq3sZCBXcqUuC0p almost the same design but very well made. there are more great stuff for reference over at http://p200.ezboard.com/bhomebuiltstabilizers good luck. ed |
| All times are GMT -6. The time now is 05:59 AM. |
