Magiqcam shreeking arm
Hi all,
A problem with the Magiqcam Rig. The bottom part of the dual arm is shreeking a lot. I think it is not the spring but the arm itself. Anyone else with this problem ? I have already mailed to John from Animagique.. so I keep you posted.. Erik |
sorry for my ignorant, what does "shreeking" mean?
ed |
Sorry, I'm from the Netherlands.. so some words in english.., ok :
I mean ' ieeeee' ieeee' sound. Like the springs needs some oil to move smoother.. Or some cracking sound.. ? Erik |
no worry, my english is not that good either. have you try doing a search on the subject matter. if i'm not mistaken, there was another owner having the same problem - squeaky sound coming from the arm.
in term of performance, what would you say? i don't have problem with the arm at the moment flying a panasonic dvc200, except for the spongy thing have drop off. small matter that is. one thing for sure, the arm seems to be working at it maximum with this setup (less then 6 kg) even though it claimed to be able to handle up to 14 or 16 lb, about 7 kg. or maybe i have it wrong. 16lb camera or 16lb with camera, camera base, monitor, battery and sled? anyone? ed |
hi erik,
found the link http://www.dvinfo.net/conf/showthread.php?s=&threadid=15464&perpage=15&highlight=magiqcam%20squeaky&pagenumber=4 not sure what was the outcome:( anyway, good luck. ed |
You are right Ed..., same situation : My Magiqcam got really squeaky.
Hope John will answer mine email soon.. Erik |
Btw Ed.., I have several hours of flying the rig with the JVC GY-DV500 camera. I will describe the complete package :
On top : JVC camera with 1 np1 accu + viewfinder + microphone. On bot : 1 x marshall battery + 1 np1 battery and at front some marshall monitor. With the sled extended at max below and both the springs at almost maxium.. it was steady balanced and easy to fly. I think it is almost 7 kg. at the top and the same at the bottom. I have put a question on this board about this weight. According to John answers on mine emails with this situation and his info on the website.. 15 lbs should be possible so DV500 and your DVC200 should be no problem. I think it is the max. possible. The Sony DVCAM camera's are to heavy for this rig. Now I have sold the jvc and will switch to a Panasonic DVX100A camera. This should be at least 4 kg. less weight. Regards, Erik |
let just hope it will not break.
from john last mail, he said he is "extremely busy". might be a while before you get a reply from him. good thing is he do check into this forum. ed |
Now.. nice and fast response from John :
' Hello Erik, You can use a little light household oil in the arm joints. If you look between the sheet metal top and bottom pieces, and the upright arm sections, you should see some nylon bushings. Just put a drop or two of oil on these areas, and work the arm a bit. That should take care of it. Thank you John ' Have asked John if possible to receive photo with some pointers for visualize his explaination.. So far so good.. Erik |
good to know that you are getting fast feedback. i'm still waiting for my sled to come back before i can fly again. hope it will reach me before christmas, working on a mtv for a local rock band.
ed |
I had the same problem and found that the adjustment screw, (the allen key one) is hitting the side of the slot, it stopped when the powder coating wore away...
In all a great unit, well designed, well built, and servicable. The 'webbing straps' on the vest, departed company from the rivets, ours has now been modified with a plate on the inside and bolts with 'acorn' nuts on the outside. Looks better as well. XL1s rig... Trevor |
hi trevor,
not sure which part you are refering to but would help if you can post some picture of the modification;) ed |
OK Mods have been photographed and placed on site for viewing, just scroll down till you fine the Magiqcam Mods.
http://www.progalleries.com.au/PureEmotion Trevor Crump Pure Emotion |
trevor, do you have a close up of that monitor you are using?
ahh.. you shorten the straps.
a few question, is this the new moving gimbal sled? the sled post, does it still have two section? what is the orange color pieces of material on the docking station? fyi, i think you got it wrong hanging the arm this way. hang it through the arm opening, where the spring is. thanks for the pics. ed |
The set up IS the new sliding gimbal, and yes it does have two sections.
The arm is only hanging that way due to the whole setup being placed so close to the door behind it. The two orange bits are pieces of plastic tubing clues to the top of the 'pickle fork' so the paint is protected on both the dock and the head of the sled.... The straps were not shortened, that was the size sent to us. |
The Monitor is a colour TV/monitor, brand is Lennox, it's alright, but does not refresh very well, in other words the image blurs when you move too fast..
The light shield is made of photo album material glued together with a hot gun. Hope this helps Trevor |
| All times are GMT -6. The time now is 12:19 AM. |
