-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   Hollywood Lite VS-1 with a VX2000: Too heavy? (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/39382-hollywood-lite-vs-1-vx2000-too-heavy.html)
Dave Largent February 13th, 2005 11:20 AM
Just wondering if anyone has tried this? Is the
VX too heavy for the VS-1?
John C. Chu February 14th, 2005 11:08 AM
I think the VS-1 will work ideallly with a cameras up to 3lbs. (that's what the specification says.)
Most photographs of the VS-1 have it shown with tiny a ZR-10.
You can push it a little bit past that...but you would have to add more weight to the bottom somehow...
The VS-1 has a "quick release" plate mounts that onto the "stage" with just two handtighten thumbscrews.
So, it might loosen a bit with a really heavy camera. Some locktite should do the trick though...
Yoou are generating a huge amounts of innertial/g-forces on that thing when you stop and go and you just don't want the camera pulling flying off from it with a really heavy camera.
You will know immediately if it is too heavy for it(after adjusting the gimble location on the shaft)---the camera will want to tip downwards.
I used a Hitachi Digital 8 with a Century Optics 16:9 lens...which made it just around 4 pounds and it worked okay.
