-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   making my own steadicam (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/45462-making-my-own-steadicam.html)
Martijn Scholte May 31st, 2005 10:53 AM
Hi there, i in the middle of making my own steadicam(for my fx1 so low weight). It's going ok but i have some difficulty with the iso arm it tents to not completly remove me walking i saw on an SKII there is sort of a steel cable that is wound op a double wheel one smal diam. one bigger. is this only to make ajusting easyer or does this also improve the stability? I am now working with one spring-arm like SKII. and i was wondering if adding one extra spring arm would also improve improve the stability or only extend the range. On this page most of the builders use two spring arms:
http://homebuiltstabilizers.com/
is there any tips out there?
thanks in advance
Martijn
Mikko Wilson May 31st, 2005 02:07 PM
Couple of things about arms...
FIrst off, a Steadicam's arm's main job is to hold the camera up in a way that doesn't transmit the bumps. - But it is yoru arms job to do that final little bit to trim out any bigger bumbs, and basically dempen the "bounce" of the arm.
The trick to goign towards an Iso-elastic (less bouncy) arm is to somehow reduce the work done by the spring by 1/3. The big rigs use 3 springs in series. The lighter rigs (SK/SK2/Provid) use only one spring connected to a reduction pully (with a ratio of 1:3) to the lifting cable. And the new generation arms (Flyer, G-40, G-50 use only one spring, but instead of connecteing accross the diagonal, they only connect 1 3rd the way up the end peice of the arm section.
An arm will perfom best with the springs operating very close to their maximum tension.
All these meathods will work to improve the perfomance of an arm.
And of course then there is the element of practice, practice, practice..
- Mikko
Martijn Scholte May 31st, 2005 02:37 PM
so a reduction pully (with a ratio of 1:3) is good?
a reduction pully (with a ratio of 1:3) is a good thing i guess? i.a.w. the flyer uses 2 springs one is each arm what do you recomend.
a ) a reduction pully (with a ratio of 1:3)
b ) 2 springs
I would like to send you some pic's see what you think
ok?
Cheers Martijn
Mikko Wilson May 31st, 2005 03:33 PM
Regarding springs in teh arm, i am of the oppinion that the Flyer arm design is bar far the best design out there. Period.
It's very simple, light weight, uses few parts (cheaper) and works like a charm!
As for the pictures you sent me. my first reaction was: "wow these are big!" - please (all of you) this is the internet, small file sizes are prefered, most monitors are 1024x768 - there is no need for pictures that are 3 megapixels. Please folks, make your pictures something aroun 600x500 at the biggest so they fit on a screen!
Now that that's done with...
I am VERY impressed with the workmanship in your gimble and stage.
It's a little shiny, but other than that it looks abotu as good as a dencet commercial rig. I hope that your gimble works nice and smooth for you.
I have 2 sugestions:
First is roudn off the handle of yoru gimble. It's jsut nicer to hodl somethign round than square when operating.
and Secondly, do you have some sort of safty stop mechanism on your dovetail mount to stop it from accidentally sliding all the way off. - no wait i think i may see a small pull-down release knob under the stage?
ok, so one sugestion then, the gimbel handle round!
- You will also want somethign ont eh gimbel to give your operating hand some grip. ..liek grip tape!
Gutsy shot of the FX1 onthe stage just ballanced on the post.
May i sugest you post your pictures somewhere where we can all see them? (at a smaller size of course)
I'm sure others would have pleanty of coments too.
- Mikko.
Martijn Scholte June 6th, 2005 08:58 AM
where could i place pic's?
i would like to place some pic's
any place you'd recomend?
martijn
Jean-Philippe Archibald June 6th, 2005 09:27 AM
Martijn,
I am intersted by your pictures too! If you haven't any space available somewhere on the web to post them, please send them to me (email jparchib_at_archeprod_dot_net) and I will host them for you.
In the mean time, some pictures of my stabilizer: http://sunens.uqac.ca/~jparchib/stab
Jean-Philippe Archibald June 7th, 2005 12:17 PM
Pictures of Martijn's Steadicam!
Pictures of Martijn's Steadicam here: http://sunens.uqac.ca/~jparchib/martijn/
Great work Martijn!!! How do you manage to do this fantastic gimbal?!? Do you have some plans to share?
Martijn Scholte June 14th, 2005 03:06 PM
not my credit only :)
Hi there,
basicly a friend of mine i very handy :) i have to pay him a little also i think it will be finist in a month or so. Im thinking of asking him to make it a dual spring arm lyke the flyer. He's not very keen on making it dual spring (a lot of work i guess :))
so mabey i keep it single for now just like the SK2
the only thing im woried about is that until now there is now ajustment build to ajust the arm to the vest like on the flyer. (the sk2 doesn't have this option either) i wonder if it's important
sorry no plans available :(
Mikko Wilson June 14th, 2005 03:13 PM
If you are building a single section arm, then make sure that the sprung section si closest to yoru vest, and the solid section is at the sled end - this will prevent the arm from hitting the battery and monitor when shooting. (notice the SK2 compared to the SK(1))
Yes the vest-arm connection is important. you use that to trim the lift angle of the arm to the way you stand. This will aloow you to stand up straight (properly) and have the sled float in place without falling away in some direction.
Anyone with any good ideas on this connection, speak up, i'm dooing a little work on a homebuilt rig and about to tackle this problem myself. I'll prolly jsut end up copying a regular connector.
- Mikko.
Martijn Scholte August 4th, 2005 11:45 PM
finisht (at least sort off :)
hi All
it's sort off finisht vest and gimball are ok arm is not :(
i wonder if i can buy a arm only ?
i'll try to put some vid's up here for reviewing
thanks again for all advice
about my arm it has no bearings i think this is giving me problems it's yust not real smooth to move the gimbal is good i think
i might try to make another spring section in the arm
cheers martijn
Terry Thompson August 5th, 2005 11:31 PM
Real nice work!
If you don't have bearings in the arm, what do you have?
I've built single and dual arms with bearings and bushings. The bearings are smoother but a lot more expensive. Whatever it takes...
Tery
Martijn Scholte August 22nd, 2005 01:38 PM
where could i place first movie
hi there all i was wondering what you all think of my first test with my steadicam and fx1
i have a h.264 clip about 25 mb big
www.groenewegen-av.nl/steadicam.3gp
i know i need a good course somewhere are there any for custom build steadicams?
cheers Martijn
Dan Selakovich August 25th, 2005 08:51 AM
Actually there are 2 arm adjustments where the arm connects to the vest on the Flyer. One trims the arm from the "hinge" so that the arm stays where you put it without drifting left or right. The other trims it at the vest to stay parallel. I love the Flyer design, but hate that vest!! It doesn't support your back at all, so things get sore awfully quick.
Dan
www.DVcameraRigs.com
Tom Wills August 25th, 2005 10:41 AM
Yeah, and unluckily that doohickey alone (the socket block) can run you thousands and thousands of dollars. People in the Homebuilt arena have been working on it for a while now, and I expect to see a decent solution come out of our camp soon enough. I know for a fact I've seen at least one socket block finished, but I don't know what the pricing was on that.
This is definetly coming along quickly. Stay tuned.
Oh, and Dan, are you a member of HomeBuiltStabilizers' forum? If not, definetly join in, your rigs have been a great way for a lot of new people to get into the world of operating Steadicams, and also cranes, dollies, and so much more. I'm sure everybody'd give you a warm welcome over there.
Dan Selakovich August 26th, 2005 07:49 AM
Thanks Tom. Maybe I will head over there soon. I was introduced to HBS by a customer a couple of years ago, but haven't done much skulking around. I wanted to wait until the plans for the full stabilizer rigs were finished and tested--I don't want someone to think I'm using their ideas in my book, so I tend to stay away from other builders. I'll have to post my socket block. I think it works pretty good so far. Have to do some more testing.
Dan
Charles Papert August 26th, 2005 10:25 AM
The 2-way adjustment is very important for production rigs and I am glad to see it is finally being integrated into recent models. For years I have been hearing of people experiencing fatigue while working with DV-sized cameras, which shouldn't be the case since these rigs are about a 1/4 of the weight of a 35mm rig, and you don't have to be a Superman to fly those. But if the rig is flying away from the body and one has to use one's arm strength to rein it in, it will quickly multiply the fatigue level over a properly trimmed rig.
However, for a homebuild that is (I would imagine) being used primarily by one person, it should be adequate for the pitch of the arm to be built into the design of the vest attachment--in other words, if you are making a connector that is a simple pin that drops into a hole, the pin should not be true vertical but biased back and to the opposite side that the rig flies on to allow for torque and play within the components of the arm.
Tom Wills August 26th, 2005 03:07 PM
I'm pretty positive that you'd get some help actually over on our forums, but don't worry about the whole stealing ideas thing. As long as you're not photocopying someone's plans and putting them in a book, you're basically going to be alright. We are all in the buisness of sharing ideas anyways. I know that I personally would really like to see some pictures, and maybe even a HBS review of the rig from your book.
I hope to see you over there soon.
Charles, thanks for saying that, I hadn't even remotely thought of doing that. I may just have to go try it out tonight. Any chance you know what causes those back pains that seem to be right on either side of your spine when you're operating? I seem to get those a ton. My rig isn't really top-notch yet though, so it might be that, but I think it might be my operating posture. If you could help me out with that, I'd be immensely grateful. I shot close to 4 hours of footage, having to lie down on my back after each half hour of operating, luckily I was at a Tae Kwon Do studio, so they had padded floors.
Mikko Wilson August 26th, 2005 03:14 PM
aah.. "That" muscle.
Tom, there is a muscle in your lower back that you only use when operating, it will take it a little while to gain a bit of strength. This is probably what youa re feeling.
however if it is hurting, stop. - this is the golden rule of operating.
It may be that you need practice, or if it is a different muscle, then it coudl be yoru posture. You shoudl always be standing up straight when you are operating. - This is why you really need that arm trimmed to you so you can stand properly.
- Mikko
Dan Selakovich August 27th, 2005 09:57 AM
I'd met a woman operator years ago (maybe 15 or 20 years now) that had totally redesigned the vest for her steadicam (they just aren't made for women's bodies she told me). She had formed metal and fiberglass to form fit her figure. She looked a little like a cross between Joan of Arc and Robocop in that thing. Anyway, because of the form fitting vest, she could go forever without too much back pain. Wish I could remember her name.
Dan
Charles Papert August 27th, 2005 11:33 AM
That would be Liz Zeigler (click here for pic).
Tom, what Mikko said plus make sure to keep the rig flying as close to your body as possible to reduce strain, and use the rest position when possible (tilt the camera back and rest the center post on your shoulder, and lean back on your heels--this will take the strain off "that muscle").
Tom Wills August 27th, 2005 03:27 PM
Thanks Charles and Mikko. I'll try that out Charles. I've been just putting it on my balancing stand between takes, but if that works, that'll be even easier.
Charles Papert August 27th, 2005 03:54 PM
Tom, don't get me wrong, if you can dock it, do so. The rest position is more for the standing around when you are just about to shoot and something needs to be adjusted that will "just take a second" and takes 30 seconds, but you need to be in standby mode, that sort of thing.
Dan Selakovich August 27th, 2005 09:43 PM
Holy Crap, that's her. Is there nothing that I can't find out on these threads? I had no idea I was in the presence of such greatness! Do you know if she is still operating, Charles?
Dan
www.DvcameraRigs.com
Charles Papert August 28th, 2005 01:26 AM
I bumped into her at Cinegear this spring. She is in fact still operating.
Terry Thompson August 29th, 2005 10:50 PM
A word of caution for newbies...Don't mess with the Charles'. They will always win in the trivia department especially Charles P.
By the way Charles', I have finally figured out the linearity thing and what part is out of whack for a particular "swing". It took a long time and now it just makes sense. Thanks for the clues and the need to make a good one.
Tery
Charles Papert August 29th, 2005 10:59 PM
Good to hear Terry. And I can tell you that I have been rewriting the instructional DVD script, it just might happen this time around...!
Terry Thompson August 29th, 2005 11:14 PM
Oh be still my heart---change that to steady,
You know that if you get your video done there will be many happy operators out here.
FYI, I'm having my gimbal CNC machined (Computer Numerical Control for newbies) this week "hopefully" and I'm looking at having some other parts shopped out. I might actually be close to marketing this dang thing.
Remember what I told you about needing a "grunt" for you project. I would be happy to do whatever I can in it's creation. In the voice of Igore, "Yes Master, I'll be happy to move that light"
Tery
